Old 11-18-2020, 01:32 PM   #601
TheRealSy90
TheRealSy90's Avatar
I know the factory S13 hoses off the vc T fitting have a restrictor "Pill" inside of them.
Do the S15 hoses have any restrictor? The rear vc to crank hose and the front vc to turbo intake hose.
Such a good signature.
Old 11-19-2020, 01:34 AM   #602
Kingtal0n
Kingtal0n's Avatar
All engines requires some restriction to fresh air inlet or the pcv will never reduce the pressure inside a crankcase.
In chemistry there is a condition known as dynamic equilibrium, which is where the pressure differential inside a container is made up for by the evaporation of liquid molecules to a gas phase. For example if a cylinder is de-compressed by a piston (larger volume from small volume) there will be a pressure drop, but if the cylinder contains liquid phase solution, some of that liquid can evaporate to restore the pressure. This is called dynamic equilibrium. There is a great picture of this example in a typical chemistry book.
The goal of PCV is to take advantage of the partial pressures of liquid phase molecules, as in the dynamic equilibrium condition, within a set pressure drop (difference) as a steady state, thereby pulling the lighter liquid phase molecules (oil is heavy and stays as a liquid, while partially burnt gasoline and unburnt gasoline is light compared to oil so it can become a gas or stay as a gas) into the crankcase gas/air, so it can be removed easily by the PCV system, constantly. thus maintaining the oil quality. To put this another way, the flow rate of the pcv system by itself is not enough to pull contaminants from engine oil and remove them; there MUST be some pressure drop in the crankcase to pull light molecules from engine oil, taking them from liquid to gas state. Simply hooking a pcv valve to the intake manifold and connecting the other end of the crankcase to the air filter tract is NOT enough unless the orifice has been adjusted to accommodate the flow rate and volume of the crankcase pcv system to give the necessary drop in pressure.
The pressure drop also assists the piston ring seal, thereby reducing blow-by, and improving compression (tightness) of the sealing rings. That is why PCV is ultimately the most important system on an engine to be functioning properly; and why I go through great lengths to stress the importance of measuring it when you modify the intake filter or duct work. Without a pressure drop, the piston rings performance will suffer, the oil quality will suffer, the engine will deteriorate more or less rapidly depending how poorly the pcv is setup. All the engine's oil seals will suffer when PCV is poorly setup, but oil leaks can be pressure washed and oil seals can be replaced, so that is a secondary concern to the engine internals cleanliness and engine longevity.
Note that in many engines, the "restrictor" is simply an orifice diameter. For example in Chevrolet LS engines the "restriction" is provided by the size of the hose on the valve cover (approx 10mm~) from what I can see visually. Since the hose on the sr20 is huge (20mm~ or more diameter) it needs that restrictor to reduce the orifice diameter to create the pressure drop.
tinyurl.com/4l80er
Old 11-19-2020, 10:44 AM   #603
TheRealSy90
My dog, I didn't need a term paper on fluid dynamics.
I'm asking if there is any factory restrictor in the two oem hoses on the exhaust side of the S14/15 valve cover. I don't have the oem hoses. I know S13 has them.
Care to show me how you personally have measured pressure drop in the sr20 crank case? You say this all the time but i've never seen you actually show how YOU do it.
Old 11-19-2020, 12:01 PM   #604
slider2828
slider2828's Avatar
S14 and S15 don't have that restrictor from crank case to valve cover.
The VC design is slightly different and the air oil separation is built in vs S13 needing that copper plug in the hose and the black box can.
Turn and Burn!
Old 11-19-2020, 12:01 PM   #605
S14rebuild
Nonono.... dont get him all riled up.... here come 8 paragraph post with no info ull actually need/use
Old 11-19-2020, 12:42 PM   #606
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
Lmao this man knows.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille
e30gangsta is offline   Reply With Quote
Old 11-23-2020, 11:15 AM   #607
Kingtal0n
Kingtal0n's Avatar
1. its not fluid dynamics, its high school chemistry from the entry level CHM1101 book. I Would never post fluid dynamics on an internet forum because nobody can use those PDE easily.
Dynamic equilibrium:
CHM1101 book:
2. It doesn't matter what kind of engine you have, they are all the same requirements designed by the OEM Engineers around the world.
You can measure using any 0-5v 2-Bar Map sensor, exactly the same way you measure intake manifold boost pressure.
So to recap, if you can measure boost pressure, you can measure crankcase pressure. If your ECU lacks the ability (OEM ecu or PFC) You can use Arduino ($22~) with any 2-bar map sensor (0-5v sensor). Since arduino can directly measure voltage, there is no need for resistor/voltage divider as with other resistance based sensors. If you'd like to see how I do it on my Chevrolet engine send a PM and I will give you instructions, videos, pictures, part numbers for all the components I Use to do this, In fact I even have extra Arduinos I can send you one for free.
Old 11-23-2020, 11:43 AM   #608
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
Thumbs up
I think I'm not the only one that appreciate your kindness and sharing.
Thank you and please post more pics and instruction here.
Ignore all haters.
cured13 is offline   Reply With Quote
Old 11-24-2020, 01:05 PM   #609
TheRealSy90
No I want to see your sr20 with perfect crank case pressure.
Old 02-09-2021, 08:01 AM   #610
PoorMans180SX
PoorMans180SX's Avatar
This is pretty sweet... Radium has been developing cool parts for our rustbuckets for a while now! Their fuel line clamps and filter kit are dope as well as their fuel hanger!
http://www.radiumauto.com/Catch-Can-...S13-P2031.aspx
Old 02-09-2021, 10:40 AM   #611
e30gangsta
Pretty steep price, and cumbersome to have to run two catch cans. Neat non the less.
Old 02-09-2021, 12:22 PM   #612
PoorMans180SX
Necessary unless you delete the PCV valve or have lines running all over the engine bay. Yes, radium stuff is definitely pricey, but oh so nice, hah.
Old 02-09-2021, 02:38 PM   #613
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
I'm going to use the universal P/N for my PCV side (my bay is pretty packed). But I hadn't realized how compact their cans are.
Sent from my Note 20 Ultra using Tapatalk
mr.nismo. is offline   Reply With Quote
Old 02-09-2021, 11:55 PM   #614
slider2828
slider2828's Avatar
Wow that is really cool... I wish they had the option to run all the plumbing back to intake housing.... engine always like some extra vacuum under boost
Turn and Burn!
Old 03-06-2021, 11:06 PM   #615
MPIracing
MPIracing is an unknown quantity at this point
thanking from Aus!
actually I don't know how to upload a photo on here...lol
been following this thread for years, love it, Here is what I did way back when, I had major issues on the track days with over flowing oil, streets was fine, yet changed the catch can to what you guys developed I only drilled 8 or so holes under the fitting welded in. and now on the track days, I don't have more than a tea spoon of oil in there after the whole day. just going for a new turbo set up now, gxt2867r on the sr, thanks again from the land of Oz!
MPIracing is offline   Reply With Quote
Old 03-06-2021, 11:08 PM   #616
MPIracing
Old 03-08-2021, 02:36 PM   #617
slider2828
slider2828's Avatar
Glad it was helpful!
Just use imgur.com and upload a photo there and copy the picture URL back here... only free way to do it nowadays
Turn and Burn!
Old 02-21-2024, 09:51 PM   #618
e30gangsta
Question can I run the lines in the configuration of the red lines? Or should I keep it as is to help keep the oil in the head under hard cornering?
Read the entire thread but it's still unclear to me. Thank you for your help.
Old 02-22-2024, 02:09 PM   #619
slider2828
slider2828's Avatar
The reason we ran that back line vertically is because we don't want to pick up oil, technically just want to remove crank pressure...
If you use the front line, its going pull oil under load and cornering.... You don't want to be doing that...
Turn and Burn!
Old 02-23-2024, 06:11 PM   #620
inopsey
interesting thread, it seems that the general consensus is to run the pcv valve as nissan intended but a mazworx engine comes with a custom valve cover that does not allow a pcv valve to be installed, there is only a male -10 an fitting. combine that with the facts in this thread that there is a restictor in the pcv valve line, begs the question how much crankcase ventilation/vacuum does the pcv valve actually provide at idle or mid throttle? and is lowering the knock threshold (by decreasing the octane) for the engine by polluting the intake manifold with oil (by running the pcv valve) of any actual benefit to the engine longevity or efficency ?
Old 02-26-2024, 05:28 AM   #621
PoorMans180SX
The PCV valve should only be open at cruising where there is vacuum in the intake manifold. At cruising the octane doesn?t matter. The only time you should be concerned about that is when the PCV system is faulty and allowing the engine to pull/push a lot of oil into the intake manifold. You can still run a pcv valve, Radium makes an aftermarket -10 one.
Kingtalon has actually convinced me that a proper PCV system does belong on everything but a racecar with dry sump oiling.
Old 02-26-2024, 05:53 PM   #622
slider2828
slider2828's Avatar
I tried not to run a pcv.... I am on a linkecu g4x with very capable tuner. The idle was unstable. I tried everything, including replacing iacv, new tps, coolant sensors, everything that could affect an unstable idle.... In the end, I added by a pcv and it idled 100% fine....
we even bumped idle to 1100 rpm and all the tricks in the book...
I run a radium fuel rail, so all the pcv on the intake side is gone. I run a -10 AN along with the front valve cover (S13/14 hybrid cover) with PCV in to a Y right before a radium large Air / Oil separator with the drain plug...
At the bottom its pure water.... its nutz how much water is in an idling engine. Keep in my this is 90% track car and my only street driving is to the alignment / tuner and that is it.....
Either way a proper PCV is the way to go.... But like poor180sx said, Radium just released -10 pcv swivel. 6 months too late for me :/
Turn and Burn!
Old 03-09-2024, 11:28 AM   #623
inopsey
what kind of idle issue did you have? low vaccum or just stumbling/missing?
Old 03-09-2024, 03:52 PM   #624
slider2828
slider2828's Avatar
I have a velocity element manifold and a radium fuel rail so i dont have vacuum on the rail any more. Originally the pvc was replaced with a radium swivel fitting and piped Yed into my catch then into back intake. No mafs, all on map via link.
We tried everything on idle. 1100 rpm, raise warmup fuel trim, reduce fuel trim, change idle timing, replace iacv with genuine new one... all of that did not work. There was constant surging and buckling on idle.
Pissed me off so bad. I was like f...it and put a check valve after the Y before the catch. BAM idle at 950 rpm, steady. I am on hks step3 264/272 cams with reduced overlap. 0 changes to anything except added PCV.
https://vargasturbo.com/product/vtt-...=&gad_source=1
I used -10 barb cause my vacuum lines are pushlock and pretty big
Turn and Burn!
