Old 09-01-2020, 05:33 PM   #1
Goldhawg
Goldhawg is an unknown quantity at this point
SR20DE S15 coolant flow direction for heater valve?
I have an SR20DE S15 I'm swapping into a Datsun Roadster and I'm not sure I'm reading the FSM correctly on coolant flow. I think the hot out of the engine is the tube closest to the block (the larger 90 deg 3/4" hose) but I wanted to be sure. I need to put the heater valve in and I want to be sure on the coolant flow out of the engine. Can anybody confirm which of the two lines coming out of the block/thermostat housing is the hot out?
Thanks!
PS, love to attach a pic but site won't let me (I am approved and file is only 222kb).
Goldhawg is offline   Reply With Quote
Old 09-01-2020, 06:45 PM   #2
S14rebuild
Host images on imageshack or imgur
Need pics to help
Old 09-02-2020, 04:20 AM   #3
Goldhawg
Can you check out the picture on c/l I created (just to host the picture)
dayton.craigslist.org/wan/d/spring-valley-wanted-silicone-heater/7188741153.html
Old 09-02-2020, 05:27 AM   #4
S14rebuild
https://www.google.com/search?sxsrf=...nlo8bygBwNFL5M
Here u go
Old 01-31-2021, 08:45 PM   #5
Goldhawg
Bump as I still don't have an answer on this. Anybody know which direction the coolant flow coming out of the block goes?
Old 01-31-2021, 09:50 PM   #6
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
you talking about running into the heater core inside the car?
If I remember right, it doesn't matter. On my datsun swap at least
lexus baby
5t341tH is offline   Reply With Quote
Old 02-01-2021, 04:03 AM   #7
Goldhawg
Yes I am talking about the heater core. However, the valve that goes with my my aftermarket (Vintage Air) Evaporator/heater core has a direction to it for flow. So I want to mount the valve in the correct direction. I don't like only having a 50-50 chance of getting it right as it's kind of a pain to mount in my roadster (very little room) and I'd like not to have to go back in the future and take the intake all apart just to get down and reverse the valve so I can have heat.
Old 02-02-2021, 07:14 PM   #8
5t341tH
5t341tH's Avatar
I've found this
lexus baby
Old 02-02-2021, 08:30 PM   #9
Goldhawg
Thanks. But this is the FSM that I have, and its not clear to me how this matches my thermostat/block housing. See the picture of my setup here:
https://www.facebook.com/photo/?fbid...88586861345626
My problem is the FSM shows the line closest to the block as going into the thermostat. But you can see on the facebook page that the line closest to the block is not going into the thermostat. This FSM picture just isn't clear to me.
Old 02-03-2021, 09:19 AM   #10
5t341tH
5t341tH's Avatar
I’ll look at my swap and see. Although mines s13 sr20det with my stock heater core
lexus baby
Old 02-03-2021, 09:47 AM   #11
Goldhawg
Originally Posted by 5t341tH View Post
I?ll look at my swap and see. Although mines s13 sr20det with my stock heater core
Appreciate it!
Old 02-03-2021, 12:11 PM   #12
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
You want the line coming off the head. It feeds the heater core then goes back around to the thermostat housing. Under the intake manifold, it's the hard pipe with a small one coming off of it, looks kinda like a Y.
The smaller hose off Y part goes to the thermostat housing also, so it can be a bit confusing if you're not following that coolant circuit diagram closely.
Old 02-03-2021, 12:48 PM   #13
Goldhawg
Thanks so much....that was my initial read but I found the FSM confusing.
