Old 02-13-2020, 10:27 AM   #1
boostin_jim
boostin_jim is an unknown quantity at this point
s13 1994 convertible 5spd!
Up for sale is a 94 240sx vert, car has been 5spd swapped clutch is good an grips fine, car is lowered on kyb struts with 2 inch drop springs, convertible top works manually an only leaks at the doors due to it have crank coupe doors which are lighter then the stock doors, motor an trans are great runs great shifts smooth, car has a switch panel an push to start ignition, car has welded diff an slides easily, as far as rust the car is extremely clean was originally from Texas only rust is 2 small spots on the windshield frame an small spot on rocker frame rails quarters wheel wells are spotless besides some scraps from being slammed at one point, all electrical works fine no issues car does need a alignment an muffler mechanically as far as body due to after market bumper an side skirts they need to be fitted better, driver fender has a crease at the bottom an center which cause the door to hit door, has nrg quick release with grip royal wheel. Im selling the car due to getting another Pics should be up soon for now txt +1 (860) 484-3597
boostin_jim is offline   Reply With Quote
