12-13-2020, 10:24 AM | #1 |
s13 uneven front camber
So , i was just changing some settings before going to the alignment shop so the car will only need minimal adjustments.
I put the top knuckle bolts all the way in , and the camber plates were at the same position. What i realized is that the driver's side (Left) has 1.5-2 more camber and wheel pokes out . I later adjusted only the right side to hopefully bring it to the same camber but still big difference. Car has : Stock lca with new ball joints and pu bush Daiyama coilovers Driftworks tension rods GK tech RCC At the moment , in the attached photos with my camber tool i see: Right : 4.5 Left: 5.5+ ( tool maxes at 5.5) https://ibb.co/0hjcrvC https://ibb.co/xfsjVJr https://ibb.co/w7Rfgq5
12-13-2020, 11:10 AM | #2 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
Your camber plates aren't set up the same.
Notice that this camber plate has 5 bolts? that fifth bolt and hole are moving one of your shocks over a good quarter of an inch or so.
12-13-2020, 11:25 AM | #3 |
Yes i know that.
But if adjust it to get the same camber numbers, both plates will be setup completely different. What i want to keep is the knuckle bolts all the way in so the dampers work on a more straight position and adjust the camber only from the plates which looks impossible. Am i thinking correct?
12-13-2020, 02:31 PM | #4 |
Super Moderator
Trader Rating: (73)
What difference does it make if the camber plates are set up differently or the same?
12-13-2020, 03:20 PM | #5 |
Is it just missing that Allan bolt?
Sorry if it?s a dumb question, I don?t really mess with those settings on the camber plates Sent from my iPhone using Tapatalk
