Old 01-07-2020, 01:49 PM   #1
Citrus
Citrus will become famous soon enoughCitrus will become famous soon enoughCitrus will become famous soon enough
Fs:1988 RX-7 Convertible, 65k original miles, 5spd, exceptional condition
SOLD
Exceptionally clean car. Driven monthly. Annual maintenance. Garaged. No rust.
Selling to clear space in my garage and focus on my Nissan projects. Very minimal modifications using only high-quality or OEM parts. Zero mechanical issues. Jump in and drive it home anywhere in the US. Tags just renewed through Dec. 2020.
Full Gallery: https://imgur.com/a/P8x7WUy
Additional pics from November 2015 when I purchased the car in California. I drove it down the coast and across the Southwest out to Colorado. Leather bra was installed just for this drive to protect the front end. Was removed and sold soon as I got to Colorado.
https://imgur.com/a/xRpLlHn
Specs:
1988 RX7 Convertible
VIN: JM1FC3519J0102936
Clean Carfax
65,XXX miles
Original 5 Speed car
Original convertible top in mint condition
Past two owners have run premix
Always garaged with battery tender
Never driven in heavy rain or snow
Exceptionally clean chassis
Original manuals included
Fully optioned, including:
Blue leather interior (no cracks, no tears, seats conditioned twice a year)
Blue vinyl convertible top cover in excellent condition
3 Spoke Leather steering wheel
Tilt Steering wheel
Illuminated Ignition keyhole
Original (and fully working) A/C
Original (also fully working) Cruise Control
Other Standard features on the RX7 convertible:
15" BBS wheels
Color-matched electric vented mirrors
Power antenna
Power steering
Tinted windshield sunshade
Theft Deterrent System
Power windows
Power convertible top with removable Targa section (no tears, no leaks, no issues)
OEM Blue vinyl convertible cover (also no tears)
Larger Turbo II brakes standard on convertibles
Engine:
HKS panel air filter installed at 64,000 miles in 2017
All original and working emissions and exhaust, car has never failed an inspection. Just passed emissions inspection Dec 2019.
Oil + filter replaced annually
Most recent oil change in Fall of 2019 as well as full mechanical inspection at Mazda dealership
Thermowax Replaced @ Rotorsport in 2014
Fuel Pulsation Damper eliminated @ The Shop in San Bruno in 2014
4oz Idemitsu Rotary premix added with every fill up since 2015, prior owner also premixed. RotaryBum Premix bottle/funnel kit included.
Suspension/Brakes:
Replaced old squeaky shocks/springs with Japanese Cusco Street Zero A Red Coilovers (6k/8k) in 2018. These were built to spec and purchased through Cusco Japan via RHDJapan.
Racing Beat sway bars installed by a previous owner
OEM BBS Convertible wheels with caps and wrench
Sumitomo tires installed in 2014 @ 60k miles
OEM Turbo II brakes with red calipers
Brake rotors/pads replaced in 2014 at 60k miles
Exterior:
Rolled inner rear fenders
Used ?€˜89-?€™91 S5 Convertible tail lights in excellent condition installed in 2015
Original OEM S4 tail lights (excellent condition) included
New Raybrig Headlight housings installed in 2017
New Raybrig H4 RS-C clear white headlight bulbs installed in 2017
All original OEM glass, including windshield
Interior:
Used OEM ?€˜89-?€™91 S5 shifter installed in 2016
New OEM shifter bushings installed in 2016
New Weighted S5 Black RE-Amemiya shift knob in 2016
Original OEM S4 shifter and shift knob in excellent condition included
New Alpine CDE-170 CD/USB Head Unit installed 2019 (pics show an Alpine CDE-143BT, I just swapped that one into my 300zx and installed a new CDE-170 in the RX7 here)
New Door Speakers: Rockford Fosgate R1675X2 6.75in installed in 2016
New Dash Speakers: Rockford Fosgate (model unknown) installed by previous owner
New StockInteriors.com floormats in Steel Blue Plush cut installed in 2017
New Warm white (similar color to incandescent) LED map light installed in 2019
Replaced a few cracked dash vents & demister with new NOS OEM Blue Mazda pieces from Atkins Rotary in 2017.
Notes and nitpicky details:
- Minor (non-collision, see carfax) damage reported in 1992 to passenger side fender and small dent in A pillar (near mirror). I had the fender and dent near the mirror fully repaired and paint matched in 2019 at Precision Auto Works in Broomfield, CO (pic from before repairs in gallery).
- Small chips in paint & clear coat visible up close if you know where to look
- Rear passenger fender paint cracked under fender lip, not visible, not peeling
- Windshield wiper sprayer is weak (despite newly rebuilt relays and newly installed pump motor in 2019)
- Windshield wipers do not operate on intermittent mode for whatever reason (despite new relays). They work fine in regular mode.
- Car hasn?€™t been driven in rain for the past 5 years, so this hasn?€™t been an issue
- Headrest speakers non-functional - Wiring was cut by a previous owner. This is probably an improvement over having the tiny 30yr-old speakers blaring right behind your ears.
- Stereo runs on Door and Dash speakers (both newer Rockford Fosgate units)
- Drivers vinyl armrest in door just starting to get a bit wavy
- Minor carpet color fading on door panels
- Crack in passenger interior plastic behind seat (not noticeable unless you're looking for it)
- Passenger power window motor a little slower than drivers side, still fully functioning
- Brake booster leaked at some point prior to my ownership and created minor surface corrosion in driver's side rail of the engine bay (also not noticeable unless you're looking for it)
- Engine leaks a couple drops of oil each time it is parked, just haven't had to the time to locate and seal it up
- Shift return spring needs replaced (common 2nd gen RX7 issue, does not affect/impact shifting), replacement spring included
- File folder full of receipts and records included
Carfax History (latest report does not go all the way back to 1990, I still have the details):
  • 03/29/1990 LOS GATOS, CA
  • Motor Vehicle Dept. TITLE
  • 04/06/1992
  • Accident Source MINOR ACCIDENT OR VEHICLE DAMAGE REPORTED: NON-COLLISION
  • 02/24/1992 33,495 California Inspection Station Los Altos, CA
  • Passed emissions inspection
  • 03/15/1994 43,910 California Inspection Station Los Altos, CA
  • 03/11/1998 49,915 California Inspection Station Los Altos, CA
  • 03/17/2000 51,482 Service Facility Los Altos, CA
  • Vehicle serviced
  • 03/17/2000 California Inspection Station Los Altos, CA
  • 02/28/2002 52,570 Service Facility Los Altos, CA
  • Vehicle serviced
  • 02/28/2002 California Inspection Station Los Altos, CA
  • 01/16/2004 54,500 California Inspection Station
  • 03/14/2006 54,797 California Inspection Station
  • 10/03/2007 55,187 Online Listing Vehicle offered for sale
  • 10/09/2007 Vehicle Repair Center Vehicle serviced
  • 10/09/2007 55,189 California Inspection Station
  • 10/11/2007 AutoNation Acura Stevens Creek Santa Clara, CA
  • Tire repaired
  • Rear brake pads replaced
  • Safety inspection performed
  • Emissions inspection performed
  • 11/06/2007 55,329 California Motor Vehicle Dept. Livermore, CA
  • Odometer reading reported
  • 12/10/2007 California Motor Vehicle Dept. Livermore, CA
  • Title issued or updated
  • New owner reported
  • 02/20/2009 56,352 California Inspection Station Livermore, CA
  • 02/22/2011 56,912 California Inspection Station Livermore, CA
  • 07/05/2011 California Motor Vehicle Dept. Alamo, CA
  • Registration updated when owner moved the vehicle to a new location
  • 03/02/2013 57,534 California Inspection Station Danville, CA
  • 10/23/2013 57,649 Rotary Performance Pleasanton, CA 925-484-2324
  • Vehicle serviced
  • 02/26/2014 California Motor Vehicle Dept. San Mateo, CA
  • 11/18/2015 Colorado Motor Vehicle Dept.
  • Vehicle purchase reported
  • 12/03/2015 62,813 Colorado Inspection Station
  • 12/09/2015 Colorado Motor Vehicle Dept. Denver, CO
  • Title #01C422504
  • Title or registration issued
  • 12/20/2016 Colorado Motor Vehicle Dept. Arvada, CO
  • Title #01C422504
  • Registration issued or renewed
  • 12/28/2017 63,970 Colorado Inspection Station
  • 12/28/2017 Colorado Motor Vehicle Dept. Arvada, CO
  • Title #01C422504
  • 12/13/2018 Colorado Motor Vehicle Dept. Arvada, CO
  • Title #01C422504
  • 12/30/2019 65,144 Colorado Inspection Station
  • 12/31/2019 Colorado Motor Vehicle Dept. Arvada, CO
  • Title #01C422504
@mdnt_32 | Jan 1990 TH1 BNR32 | Jan 1990 TH1 Z32
Citrus is offline   Reply With Quote
Old 01-13-2020, 05:28 PM   #2
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
Very nice example of an oem+ car
lexus baby
5t341tH is offline   Reply With Quote
Old 01-20-2020, 08:32 AM   #3
Citrus
Price Reduced: $8,500
Old 01-23-2020, 07:05 AM   #4
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
WOW. Amazingly clean car! GLWS!
onehundredoctane is offline   Reply With Quote
Old 02-26-2020, 08:50 AM   #5
Citrus
Bump - want my garage space back so I can start my VH45 swap.
$8,000
