Old 08-24-2020, 10:35 AM   #61
S14rebuild
How would yall compare it to a gt3071r? .63 rear housing
Old 08-24-2020, 10:38 AM   #62
PoorMans180SX
PoorMans180SX's Avatar
A standard, GT-series GT3071r? A g25-550 would absolute shit on it everywhere. Your whole powerband would just move up and to the left.
Originally Posted by RalliartRsX View Post
Poorman you pretty much sum up what I was thinking.
Garret, for years, have had an outdated turbine wheel. Shoot, the old outgoing wheels were coming along on 40+ years old and all they did was address the compressor wheel.
To be fair, a more efficient compressor wheel does mean the turbine has to do less work, so it's kind of a "rising tide raises all boats" kinda deal. Your point is definitely valid though, which is why EFR's just shit on everything when they were introduced. It's nice to see other manufacturers stepping up. The new Xona rotor stuff looks pretty cool too. Hard to find guys outside of drag racing using them though.
Old 09-03-2020, 10:24 AM   #63
PoorMans180SX
Found this on NRR. Told you so to all those people that think they need the big turbine housing.
Originally Posted by induetime;n172880
Here is a Dyno Graph on a local Dyno Pack Hub Dyno from UMS Tuning. It is a High Compression (I 10:1 believe) S14 Sr20, 0.72 EWG G550 turbo. 517whp & 447wtq at 25psi. E85 I believe. It still had more to go as well. Not my car BTW.
Old 09-03-2020, 02:12 PM   #64
jr_ss
It would be interesting to see it rev out more. 7500 isn't really that extreme, however, great power at 4K rpm. Also E85 though. Pump gas would be great to lay overtop to see the difference.
Old 09-03-2020, 03:27 PM   #65
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
excellent numbers. really making me reconsider the GTX3071 I have for my sr20vet. Might hafta toss that on the sr20det in the missile car and order a new setup for the other engine.
Old 09-03-2020, 03:34 PM   #66
S14rebuild
^just sold my old precision, and got a gt3071r for my sr setup..wonder if ill be replacing the turbo with one of these...hmmm
Old 09-03-2020, 07:02 PM   #67
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
I am curious if that motor had cams, or if the vct was engaged at all.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille
e30gangsta is offline   Reply With Quote
Old 09-03-2020, 09:57 PM   #68
Colorado S14
Colorado S14 is on the path to ruinColorado S14 is on the path to ruin
What do you guys think for an extreme response KA24DET set up? I am in Denver, assume a density altitude of 7000 feet, hard on turbos. In the process of rebuilding from a blown engine. Looking for a machine with the ultimate in response and an uncorrected 400whp on 91.
Colorado S14 is offline   Reply With Quote
Old 09-04-2020, 09:28 AM   #69
jr_ss
It is hard to tell from the picture if the VTC solenoid is intact. If it was, I would expect it helped decrease the spool. It really does help these motors make peak trq much sooner in the RPM band.
I took a better look, the solenoid is there.
Old 09-04-2020, 09:53 AM   #70
PoorMans180SX
It's impossible to tell spool from a dynapack dyno anyway. They always have parabolic torque curves which don't accurately reflect loading when on the road.
Regardless, this turbo is a phenomenal performer, and doesn't need the .92 housing to reach it's flow potential on a two liter. The G25-660 doesn't seem like it can flow much more with this turbine on the other hand, regardless of housing.
Here's another find, KA24 with a G30-660. I've asked him to post the dyno graph if he has it.
Originally Posted by Scores240;n173010
Almost finished engine bay setup, prior to the dyno session.
https://i.imgur.com/LoUaPC8.jpg
Originally Posted by Scores240;n173011
The car did great at the dyno session making 470hp 480tq on a mustang dyno...
A view of the course at Mid State Airport in Pennsylvania. The car felt like a new animal on my first run, much more responsive than the old GT2871 and the extra power would spin the 315's with ease. The trans 2nd gear ratio (2.077) is shorter than the stock S13 trans (1.902) which ended up having me doing 66mph at my redline of 7400 when i was used to doing 73mph. It sure felt like i was on limiter in a lot of places and I'm figuring with the response and power that i was just reaching 66 that quickly on this course (the clutch and TOB appeared to see a lot of heat : more in later posts).
On my last run, which ended up being a re-run is when all of the fun came to an end, with the engine blowing the #3 rod out of the block..
Old 09-05-2020, 07:41 AM   #71
tuzzio
tuzzio's Avatar
I have a LOT of questions about that KA set up. Thats fucking stout, for sure.
Sucks not having E85 conveniently available though. I'd turn my KA up for sure.
Edit: Poorman, can you start providing links to where you're finding this shit? I love forums and I'd definitely like to hear more about that setup
Old 09-05-2020, 08:40 AM   #72
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
https://www.nissanroadracing.com/for...011#post173011
Old 09-05-2020, 08:58 AM   #73
tb13
tb13's Avatar
tb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to beholdtb13 is a splendid one to behold
Sheesh, posts like that get me really excited to get my car running. Those numbers are really impressive, interested to know why they stopped at 7500rpm.
Tony at UMS will be tuning mine as well, my car is setup for flex fuel so I'll be able to show an pump gas and ethanol chart on an S13 SR.
tb13 is offline   Reply With Quote
Old 09-05-2020, 06:54 PM   #74
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Stop stealing posts from NRR hahahahahah!
Old 09-06-2020, 01:56 PM   #75
PoorMans180SX
Just doing what I can to spread the good news! Hahahaha
Old 09-08-2020, 05:47 AM   #76
PoorMans180SX
Stock block KA24DE .83 turbine G30-660
Comparison of G30-660 to the old SR hybrid manifold / GT2871R setup.
Old 09-08-2020, 06:19 AM   #77
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
You could just have this discussion on NRR where you're pulling all the info from, lol. Most people in this thread are on there as well.
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 09-08-2020, 07:00 AM   #78
PoorMans180SX
Meh, this forum has a lot more traffic, and these are mostly posts in different people's threads. It's nice to have it all in one location.
EDIT: I'll start a thread in the forced induction section.
