Old 11-18-2019, 11:19 AM   #1
Shift n Drift
Shift n Drift has a little shameless behavior in the past
Z33 Pressure plates
Hey guys, I’m working on a vh swap with a cd009 and was wondering if it matters if I go with a 03-06 z clutch or 07+ clutch, I’m going to most likely use the Collins adapter and it says I use a z33 flywheel and clutch, and I found a good deal on a 07+ clutch... soo... yea?
Is the 07+ pressure plate the same or compatible with 06 cd009 trans?
Shift n Drift is offline   Reply With Quote
Old 11-18-2019, 11:33 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
this is a question that can easily be answered
https://lmgtfy.com/?q=350z+clutch
if theres a different part number for different years. . . . . .
Old 11-18-2019, 12:01 PM   #3
Shift n Drift
Oh thanks fuck face, I even called Z1 and talked to Matt, he said theirs will work but not sure about other brands, he said the toner ring on the flywheel is different because of the crank angle sensor, but isn’t 100% sure the pressure plates are different.
Old 11-18-2019, 04:25 PM   #4
brndck
brndck's Avatar
I mean, ya got options
http://collinsadapters.com/index.php/contacts/
Old 11-18-2019, 08:28 PM   #5
S14rebuild
Fuk face? This guy is scary
Old 11-18-2019, 09:11 PM   #6
Shift n Drift
Thanks man
Old 11-26-2019, 10:27 AM   #7
ultimateirving
ultimateirving's Avatar
I run the Newer style z Trans with the Z-speed HD Concentric slave and just used my SR flywheel with an SR Clutch and pressure plate. No issues yet.
Z32 with lq4 swap
Old 11-27-2019, 11:57 PM   #8
Shift n Drift
Thanks for the info ultimateirving! I went ahead and ordered the 07+ clutch and flywheel that found for a steal. I was told by Z1 that the throwout bearing has the the same throw distance in either 06 external or 07+ internal. So I don’t see why it won’t work.
