02-09-2016, 04:04 PM | #31 |
Badass man. Props to the man at maaco that laid down the paint too.
Overall looks rad!! Interior and brakes, then power? Or you going the opposite route?
02-10-2016, 12:07 AM | #32 |
Thank you, and most likely get a seat and maybe a few details, get some simple mods, get a hicas delete first aswell, then prob brakes.
10-12-2016, 12:43 PM | #33 |
New updates.. Not much but cool pictures
Went to good 6-7 shows driving around all over on the east coast in the past 6 months.. did some burnouts if you haven't seen already.. check this video out https://www.youtube.com/watch?v=5nz69n0CoS0 Threw my passenger zeta 3 of my fr-s into the driver side of my 180, looks cool (temporary until i get my new zeta 2's reupholstered) My trip to daytona from va crushed my bumper so now its completely wrecked.. too broke to fix it at the time but heres a pic of it, the whole bottom part of fiberglass ripped completely off on the highway. And a few pics from h2oi that i thought were nice. after all that driving (and i normally never drive this car) put on a few thousand miles within those trips, but wore the hell out of some suspension parts. Wheel bearing in my rear passenger wheel is now gone. so thats something i gotta get + my balljoints are pretty worn and i bent a tie rod.. so plenty of things are about to come. That lead to me ordering the villain drift angle kit hopefully by next week. Next up is hunting for an s15 turbo, intercooler piping, and new air filter. Maybe cams.. however money comes about |
03-21-2019, 10:44 AM | #34 |
Man has it been a while...
Well i'm going to start back up with this since 2 years later, i'm almost done. (Keyword ALMOST) First things first, I traded my FRS for a JZX100 chaser, with another 1jz + r154 added ontop. So my wild ass decided to swap the 180 with that 1jz. I decided that I was going to take my time, get quality parts as I go and make this car right. Additions to the build: 1JZ GTE (OEM turbo) Refreshed R154 Completely refreshed (Everything has been replaced with brand new parts) Wiring specialties harness Chase bays tucked brake lines + z32 conversion lines Chase bays power steering kit Chase bays tucked radiator (cut frame and welded to fit) + Fans Chase bays thermoswitch Chase bays raised waterneck Custom fuel lines (Cut fuel line next to transmission and fed over to avoid close connections with downpipe) Odyssey fab downpipe (custom to fit RHD) Custom exhaust with turndown Z32 Brakes (Powdercoated candy red/cosmic blue) Drilled/Slotted front rotors HICAS delete subframe (Powdercoated candy red) Megans Inner tie rod boots PBM Steering rack bushings PBM Coilovers 25mm Extended LCA'S (Painted red) Moog I30 Inner tie rods Moog S14 outer tie rods GKTECH roll center correction kit LS/JZ Swaybar from sikky Custom battery relocation kit Street faction battery box Street faction rear bash bar Custom front bash bar HKS Intake filter CX racing intercooler kit (LOL Quality right? Went cheap on this, plan on switching) Autostorm collect bumper kit Autostorm collect headlight relocation kit #2 Circuit Sports Coolant overflow Solid subframe bushings Custom driveshaft by driveshaft shop (R134 to ABS s13 DIFF) Got a full set of FLAT lip blitz 03's, full chrome, gold hardware. 18 X 9.5 +6 18 X 11 + 0 Tired ordered but not yet received, 225/40r18 for 9.5 255/40r18 for 11 Heres some pictures of progress but if you want to really keep up to date with my build follow me on instagram @MrMarinakos IMG_3749 IMG_4382 IMG_5164 IMG_4373 |
03-21-2019, 02:10 PM | #35 |
I'm hyped to see people keep reviving their build threads from the dead!
Nice work OP this thing is going to be sick. Subbed for updates
(づ。◕‿‿◕。)づ T E A M B L O O M |
05-27-2019, 08:31 PM | #36 |
Update:
Bought more parts Mach V is a local shop next to me that supports Prosport gauges, and I decided to get the full 60mm setup with the Revo style gauges. Also with that, I went and bought gauge pods for the ac vent replacement from street faction as well as a new front bash bar. (Come to find out the custom bash bar i purchased doesn't fit with my intercooler setup.) Also found this guy who makes custom dash pod setups for the steering column, so I went and ordered this cool setup linked: http://ortizcustompods.com/nissan.html Ok so down to the details, I got her almost all the way back together to start getting on all the tweaks. Bled everything, filled all the fluids. got her running again after a fresh waterpump install. Everything seemed to be fine but of course a huge project like this always has its flaws. My power steering setup was flipped, which in my case i'm still confused on whats the correct way to go about it because I have a RHD Hicas rack, and you can't find shit for details on them online. I have yet to start the car since so not sure if it fixed it yet. Outside of this, my other issue is that my chase bays fans are not turning on with the chase bays thermoswitch I have, so i'm trying to figure out what is causing it from turning on or if my dumbass has to wait longer for them to activate. Ontop of that my HKS filter doesn't fit within the space I want it to with my J-pipe delete so now I have to go filter searching... I don't have much time for this car so at this rate it'll be done by the end of summer(hopefully) On to the bright side I have the tires mounted, weld heat sink cover, and got a photoshoot of my jzx100 done recently. Heres some pictures IMG_5636 IMG_5651 IMG_5677 IMG_5681 IMG_5682 |
