Old 08-07-2012, 02:42 PM   #31
turbociv910
turbociv910 is an unknown quantity at this point
gapping plugs down looses power, wider gap = better burn. If your having to gap your plugs down to very small ammounts, you need to upgrade.
www.carolinadyno.com
s13 LSx turbo drag car- 1.42 60 ft, 6.32 1/8
turbociv910 is offline   Reply With Quote
Old 08-07-2012, 02:54 PM   #32
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
NGK iridium plugs and bosch wires because i didnt want to wait for ngk wires to come in
stock ka24de
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 08-07-2012, 06:29 PM   #33
supakat
supakat is an unknown quantity at this point
Wider gaps do not make a big difference in power, but burn more efficient which helps with idle, cruise and start up. It is the cylinder pressure (causes blowout) that decides if you need to close your gap so the spark can jump. I am running LS2 coils and could probably open up to .044 since they burn hot as hell. I get a blue spark from these bad boys.
Spark Plug Installation Instructions
12.96 @ 116.36 - Build Thread
supakat is offline   Reply With Quote
Old 08-08-2012, 03:38 PM   #34
qay2fotayesex
qay2fotayesex is an unknown quantity at this point
I run an NGK BKR8EIX gapped to .020
On an SR with a 3076r turbo making 477hp. works perfectly for me and i don't have to replace my plugs every other week as i would with copper ones.
qay2fotayesex is offline   Reply With Quote
Old 09-15-2012, 02:28 AM   #35
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
So much to learn. Im about to finish my build and was wondering what sparkplugs to get. Running built sr and gt3071 ( if it matters) 740 nismo inj. With a goal of +450. What kind of. Spark plug will work for me??
silviaNC is offline   Reply With Quote
Old 09-15-2012, 02:31 AM   #36
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
NGK Bkr7e coppers gapped at.26
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 09-15-2012, 02:32 AM   #37
rb25_s13*CHUKI
Not true, My dad ran .22 gap on his Evo 8 with buschar coilpacks which has plenty of spark
Obliterate
Old 09-15-2012, 03:22 AM   #38
OuTLaVvZ
OuTLaVvZ's Avatar
OuTLaVvZ is an unknown quantity at this point
if i get brk6e for mostly stock sr , do i need to regap or is it just plug and play?
OuTLaVvZ is offline   Reply With Quote
Old 09-15-2012, 09:24 AM   #39
Punished
Punished is an unknown quantity at this point
I have never bought spark plugs that didn't need to be properly gapped.
Punished is offline   Reply With Quote
Old 09-15-2012, 12:10 PM   #40
Neon_rain519
Neon_rain519's Avatar
Neon_rain519 is an unknown quantity at this point
NGK v-groove side gapped
Neon_rain519 is offline   Reply With Quote
Old 09-15-2012, 02:06 PM   #41
frabus
frabus's Avatar
frabus is an unknown quantity at this point
Bkr5e 11 NGK coppers on my n/a ka24de per the FSM. I just change them often about every 10k miles never had any issues.
frabus is offline   Reply With Quote
Old 09-15-2012, 02:19 PM   #42
s13mikesr20
s13mikesr20 is an unknown quantity at this point
bkr7e enough said
2 dollars a plug and im making over 450 hp thank you
s13mikesr20 is offline   Reply With Quote
Old 09-15-2012, 02:24 PM   #43
s13mikesr20
sr20det that is
Old 09-15-2012, 02:24 PM   #44
PureRush
PureRush is an unknown quantity at this point
Engines get better gas mileage and less emissions the hotter they are, that is why most cars have an operating temp of 200-220. Some iron blocks are 230!. Iridium increases heat increasing fuel mileage. Hotter everything is, the air the engine is consuming is less dense(= less fuel). Just like when its cold you expect more power right?
Copper runs cooler, has colder spark(naturally) to reduce detonation for higher horsepower and aftermarket applications. Many, countless times have i taken out iridium plugs in exchange for copper and gained power, or got rid of a miss fire.
never buy "iridium racing" plugs for your car, you will waste the $$ and i will say i told you so.
downside is that a copper plug wears out twice as fast, but who cares when they cost $3 a piece.
I'm sorry but I have correct this since you're wrong in so many ways.
The electrode which can be made of copper, iridium, platinum, etc does not effect the temperature inside the cylinder. The amount of insulation under the white ceramic shell on the spark plug determines the temperature of the spark plug (Heat Range can be a Hotter/Colder Spark plug). Thats why higher hp motors usually have one step or two step colder spark plugs. Different electrodes only determine longetivity of the spark plug. Top fuel drag cars use basic copper spark plugs that many of you use.
There's no such thing as a stronger/weaker/colder/hotter "spark". A spark is a spark and nothing else. What determines performance is the gap. Gap should be determined based on the engines OEM specifications or secondary ignition system output if aftermarket.
Also spark plugs (If using the correct ones) can NEVER cause detonation. The only way you can is if you use the incorrect spark plug that is a hotter heat rang or has a longer reach which will increase the compression (That is if it doesn't hit the top of the piston). I think the word that you're looking for is "misfire". Can be caused by usually incorrect gap. Spark plugs come already gapped to OEM specs but I always double check.
WARNING: IRIDIUM SPARK PLUGS SHOULD NOT BR GAPPED. THE ELECTRODE WILL GET DAMAGED!
PureRush is offline   Reply With Quote
Old 10-03-2012, 10:40 PM   #45
jamg
so...
NGK BKR8EIX
OR
BKR7EIX
Old 10-03-2012, 11:05 PM   #46
leung
leung's Avatar
Trader Rating: (73)
leung is an unknown quantity at this point
Feedback Score: 73 reviews
Originally Posted by jamg View Post
so...
NGK BKR8EIX
OR
BKR7EIX
That obviously depends on how much power you're making. I believe its one step colder for every 100hp up. 6 is stock.
leung is offline   Reply With Quote
Old 10-03-2012, 11:06 PM   #47
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
bkr7eix, i believe their pregapped .35 last time i checked myself lol
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 10-03-2012, 11:08 PM   #48
jamg
300whp
colder, as in going down in numbers?
Old 10-03-2012, 11:08 PM   #49
silviaNC
silviaNC's Avatar
Just got a set of bkr8 for my build. Shooting for 450-475hp
Old 10-04-2012, 09:08 AM   #50
AdamR
AdamR is an unknown quantity at this point
Just wanted to chime in to say that NGK says to not use anti-seize on their plugs.
AdamR is offline   Reply With Quote
Old 10-04-2012, 04:08 PM   #51
project-D180
project-D180's Avatar
project-D180 is an unknown quantity at this point
i use ngk or autolite ir ..i like them better than denso
project-D180 is offline   Reply With Quote
Old 10-25-2012, 02:24 PM   #52
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
+1 http://www.ngksparkplugs.com/pdf/TB-...1antisieze.pdf
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 10-25-2012, 02:58 PM   #53
Corbic
Corbic's Avatar
A/C Delco. At $1 a piece you can't beat it. I change plugs like I change socks anymore.
Old 10-25-2012, 03:15 PM   #54
!Zar!
!Zar!'s Avatar
I never knew that about the anti seize. OH WELL
Old 10-25-2012, 03:49 PM   #55
pewpew
pewpew's Avatar
pewpew is an unknown quantity at this point
Send a message via MSN to pewpew Send a message via Yahoo to pewpew
currently running bkr7e in my red top SR w/splitfire coilpacks, 425whp
should I change/stay the same, and suggestions on my gap setting?
Don't mix booze and car batteries...it gets expensive, quickly.
pewpew is offline   Reply With Quote
Old 01-13-2013, 07:08 PM   #56
Zed Nismo
Zed Nismo's Avatar
Zed Nismo is an unknown quantity at this point
Just to share some opinion and personal experiences with spark plugs, I think HKS Iridiums are the best spark plugs out there for turbo cars. I know many will chime in here and flame me saying otherwise. I am not saying that NGK Iridiums are not good (That's what I currently have in my S13 and I am not complaining) but yes, I have had experience with HKS Iridiums and they are just the BEST hands down. If you really look at the design of the HKS plugs, you will see that you get less vibration so the gaps don't change. Many will scratch your heads, but some people know what I am talking about. Just look at the HKS spark plugs and the NGK/Denso (whathaveyou) and you will see that the HKS spark plugs have a shorter electrode that is much more resistant to vibration. The insulation is much different and well, I don't have any pictures to back up my opinion at the moment, but I will take some pictures and post them up so people can see and understand where I'm coming from. It is also designed to take high boost. I'm sure the problem that many of you have with ignition/misfire/detonation is in regards to running a hotter plug then necessary for your application, but I will guarantee any of you, get the HKS plugs and you will never look back.
I have not had experience running the plugs in an S-chassis. However, I have had experience in a couple Supra's and IS300 with a VVTi 2JZGTE and the plugs make a world of difference compared to the Denso plugs or even the NGKs. The performance of the car is just amazing and smooth throughout the power band and does not sputter or "give out" at higher RPM's or under higher boost levels.
I will post picture and specifics of the HKS spark plugs. I should have a couple laying around the shop. The difference with running HKS plugs and NGK is instantly noticeable. Now I can't say that you will get 20whp just by upgrading to HKS nor am I a rep for HKS by any means. I am just stating my opinion and experience with this particular spark plug.
Many people don't want to "waste" $20/per plug for the HKS units, but I think it's a great investment. Especially when you are putting so much money into the motor, turbos, manifolds, front mounts etc. I think the $80 for a set of HKS plugs is well worth the outcome. Yes I will be getting these plugs in the near future and I am not telling everyone to go ahead and buy these. But I do believe in all of HKS products and think that these plugs are the absolute best for Boosted motors.
Zed Nismo is offline   Reply With Quote
Old 01-13-2013, 07:28 PM   #57
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
HKS sparkplugs are just rebranded NGK Iridiums.
CLICK HERE!!!
Old 01-13-2013, 07:30 PM   #58
TheZ31Guy
TheZ31Guy is an unknown quantity at this point
I use NGK V-powers on my L28E with a Turbo slapped on it, shooting at 10PSI gapped to .032 and I love it everyday. Not sure why I gapped it so low, but it does feel a bit nicer in boost now that I did. Stock gap is .044 but I remember some of the plugs not being gapped there, so I was thinking about regapping my plugs to .045 or so. She ran fine either way but seems smoother with a smaller gap
TheZ31Guy is offline   Reply With Quote
Old 01-13-2013, 07:34 PM   #59
Zed Nismo
Zed Nismo's Avatar
Find me NGK plugs with the same design as the HKS and I will believe that. Yes NGK does make the plugs for HKS but that does not mean it's the same thing as the NGK's. The design is different and better suited for boosted cars. I have the HKS plugs at the shop so I will take some pictures and get back to this thread when I have the chance.
Again, not hating on NGK or other brand of spark plugs out there.
Old 01-13-2013, 07:45 PM   #60
KoukiMonsta
KoukiMonsta's Avatar
Bkr7e at .28
Sr, not very stock at all
These plugs are cheap, change them often.
@UpshiftEngineering
