Old 11-28-2012, 06:03 AM   #1
myndseye
myndseye is an unknown quantity at this point
6 used 750cc injectors - $210 shipped
This is for the guys that are six cylinder swapped!
They have about 300 miles on them in a e-managed 2jz swap on stock twins.
Siemens Deka 3145
Flow Rate: 750cc/min at 43.5 PSI / 72LBS/HR at 43.5 PSI
Resistance: 2.5 Ohms
Voltage: 8-15 Volts, Nominal 13.5 Volts
Amperage: Peak 4.0 Amps/ Hold 1.5 Amps
Pressure: Min. 36 PSI (2.5 bar), Max. 87 PSI (6 bar)
Complete set of 6 injectors with o-rings
Specs: Connector type: EV1 O-ring top: 14.5mm O-ring bottom:14.5mm Length: 74mm (center of o-ring to center of o-ring)
myndseye is offline   Reply With Quote
2jzgte, 750cc, injectors, siemens, swapped
