Old 07-31-2020, 05:50 PM   #1
rv_zenki
rv_zenki is an unknown quantity at this point
S13 / S14 under body differences
Hi,
So my S14 has some rust on the floor pan and the very underside of the rockers. I want to find a shell to cut up but finding a clean s14 shell is proving difficult. Would I be able to use an S13 shell? Could I make the rockers work? They would be behind a side skirt and on the very bottom so not totally visible.
Thanks
rv_zenki is offline   Reply With Quote
Old 07-31-2020, 05:59 PM   #2
S14rebuild
s14=s14. s13=s13
Unless ur good at fab n make what u need out of sheet metal...
Old 07-31-2020, 08:11 PM   #3
burnsauto
burnsauto's Avatar
don't cut up a clean shell to fix your rusty one. Just take it to a body shop and have the rust fixed. You live in MI, so it's just going to come back one day. Play the hand you've been dealt, lol.
Old 07-31-2020, 09:09 PM   #4
rv_zenki
I've had the car since 1996. Id cut up 10 shells to save this one. I dont care
Old 07-31-2020, 10:52 PM   #5
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
There's like a million dudes parting out cars, I'm sure somebody will sell you a cut of whatever you need.
collegekid is offline   Reply With Quote
Old 08-04-2020, 02:08 AM   #6
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
I could never find a clean shell, so had to make my own floor pans to save my S14. The drainplug thing behind the seat collected water and ate up the pans on both sides.
Old 08-04-2020, 06:51 PM   #7
S14rebuild
Fix the water leak and you wont have to worry bout that
Old 08-04-2020, 07:09 PM   #8
LoSt180
LoSt180's Avatar
Trader Rating: (18)
It's a design flaw. There's a hole from the factory assembly process and a metal piece is glued on. Water seeps in and since it's under the sound deadening it just sits and eats away at the metal.
Old 08-04-2020, 11:55 PM   #9
inopsey
is that a sunroof car? where is the water seeping in from ??
Old 08-05-2020, 12:54 AM   #10
Kingtal0n
Kingtal0n's Avatar
Yeah when I get a car now first thing I do is rip out the carpet, degreaser and wash all that floor board... gunk... out. Scrub it really good so its just the pseudo sticky sound deadener left in there. Fix any rust etc...
And then paint it with some good ol' rustoleum oil based paint. The paint sort of eats up any leftover oil residues and sort of soaks into the sound deadener, its pretty slick. And it keeps water off and out of the sound deadener and seals up any leftover metal exposed.
Friend gave me the idea, we did his car first and then I was like omg im doing that from now on
Old 08-05-2020, 03:11 AM   #11
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Water came up from the bottom. Since it was under the sound deadening, the carpet was never wet. Only noticed when I was under the car one day and started poking at it.
Here's where the factory hole is. There's only a silver stick on thing sealing it up.
Old 08-05-2020, 04:26 PM   #12
S14rebuild
owned 3 s14s never had water comen in there issue..huh
Old 08-05-2020, 06:39 PM   #13
inopsey
so i took back the carpet and peeled back the sound material and i saw the metal silver seal behind the seat mount, no rust there. i further peeled back the deadening and found an actual hole only sealed by the sound deadening (close to the transmission tunnel). this is where i got some surface ( i hope) rust started i dont see the same hole in your pics. thanks for pointing out this issue would of never found it until too late and a big rust job
WTF nissan
Old 08-05-2020, 06:42 PM   #14
inopsey
pull your carpet and sound deadening back you might be in for a surprise.
