Old 07-18-2021, 09:31 AM   #1
spools420a
spools420a's Avatar
spools420a is a well-known jackass
1995+ maxima coil packs interchangable for sr20det retop
hey i found a old thread about interchangable parts and seen we can use z32 coil packs but those are just as expensive but then found another threat that showed we can use 1995+ nissan maxima coil packs and these run $15 each.
I noticed they have two different types though for front and rear of engine along with mounting points/clip in wrong spot.
has anyone in hear tried making these coil packs work?did you use the front or rear and what needed to be done to get them to fit?
spools420a is offline   Reply With Quote
Old 07-18-2021, 03:25 PM   #2
slider2828
slider2828's Avatar
You can put a lot of coilpacks on our cars. It just depends....
Are you trying to fit the cheapest coilpack possible? Best coilpack? All of them require just making a small clip bracket to hold it down.
Turn and Burn!
Copyright ©2000 - 2021, vBulletin Solutions Inc.
