Old 03-20-2019, 04:54 PM   #1
xGoggles88x
xGoggles88x's Avatar
xGoggles88x is an unknown quantity at this point
Ls1 turbo fd3s for 20k or trades
Price is 20k or trades.
Located in Chicago
-Chassis
It’s a 93 with under 80k miles. Has Tan and black interior that needs some tlc to be nice. -Most of the hard plastic parts are messed up in some way or another, either clips missing or cracked. The door panels and headliner are in decent shape other than needing some deep cleaning. The carpet is aftermarket so fitment basically sucks in some areas. The good stuff is the carbon cluster surround and all speedhut gauges and the odometer was set to match the original mileage.
Has feed 25mm origin fenders as well as 25mm rear feed over
Has 50mm origin over as well(not painted)
Carbon fiber hood and EVO R sleek headlights.
Front brakes are Pittit Racing outlaw brakes. Crossdrilled and slotted rotors on all 4 corners and wilwood adjustable proportioning valve.
Suspension consist of adjustable damping BC coilovers.
Drivetrain
Engine was built earlier this year and has right at 3000 miles on it. Consist of a forged LS1 with Callie’s Compstar rods and wiseco pistons .005 over to give a fresh bore. All Arp studs for main caps and heads and Arp balancer bolt and flywheel bolts. Heads are CNC ported LS3 small bore with BTR springs and retainers. Stock ls3 intake and a holley sniper 92mm throttle body and fuel rails feeding 80lb injectors. Cam is a custom grind turbo cam with 238/242 .605/.610 ground at 115+4. I do not have any dyno numbers at this time as it has been tuned on the street. If dyno numbers are important we can get it on the local dyno. I’d say it’s close to 700hp at 13lbs at this time. I’ve got it tuned on E85 as well as 93 pump gas.
Turbo kit runs with stock truck manifolds with 2.5” stainless hot side to a T4 76mm turbonetics turbo and a 44mm precision wastegate. All piping in engine bay is stainless all the way to the passenger foot well.
Engine mount kit is from Samberg performance
Transmission is a stock CTSV tr6060 and a monster stage 3 clutch.
Aluminum driveshaft
Rear end is a ford 8.8 aluminum housing with 3.08 gear mounted with Ronnin kit and axles.
Fuel system is ran with 2 aeromotive in tank 340 pumps with the second one programmed to come on as soon as boost reads on the map sensor.
Engine management is a Megasquirt MS3Pro with the plug and play lsx harness. 2 step, flat foot shift and anti lag have been wired up and work as they should. There is a line lock plumbed in line but is not hooked up yet.
I do have the stock front fenders also.
Wheels are rpf1 18x9.5 and 18x10.5. I have xxr as well that goes with the fd. Fronts are 255/35/18 and rear are 295/30/18
Battery is a yellow top optimal mounted in passenger rear bin and a 50amp breaker with a easy push button disconnect.
I will start at 20k and I will not respond to some lame lowball offers.
Fixing her up as I go to get everything situated. This is a well sorted car that can be driven and no issues.
Clean title in hand.
Looking for trades. Anything rwd,rhd and well suited for drifting. Four doors skyline or toyota chaser,is300 would be awesome as well. Any s14,s13 with mods will be considered.
Located in Chicago.
Sent from my SM-N960U using Tapatalk
xGoggles88x is offline   Reply With Quote
Old 03-20-2019, 05:13 PM   #2
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Man the want is so real, glws.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 03-20-2019, 05:21 PM   #3
nm240sx
nm240sx's Avatar
nm240sx is on the path to ruinnm240sx is on the path to ruin
Holy Shit
Sent from my moto z3 using Tapatalk
nm240sx is offline   Reply With Quote
Old 03-21-2019, 07:01 AM   #4
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
ugh... if it had a rotary i would trade -__-
nice car great price should sell fast!
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 03-21-2019, 07:19 AM   #5
xGoggles88x
Bump ,looking for the right trade!
Old 03-21-2019, 05:37 PM   #6
Jarom717
Jarom717's Avatar
Jarom717 is an unknown quantity at this point
Damn. That's an amazing price for an FD with that much power
Sent from my SAMSUNG-SM-G920A using Tapatalk
Jarom717 is offline   Reply With Quote
Old 03-21-2019, 09:24 PM   #7
RedSnow
RedSnow's Avatar
RedSnow is an unknown quantity at this point
There's always that one guy
RedSnow is offline   Reply With Quote
Old 03-22-2019, 10:28 AM   #8
xGoggles88x
Looking for a Toyota chaser or any manual rwd four door.
Old 03-23-2019, 06:37 PM   #9
whipschocolate
whipschocolate's Avatar
whipschocolate is an unknown quantity at this point
Interested in a 1993 RHD Toyota Supra 5 speed N/A 180000km? If so text me at 2149095360
whipschocolate is offline   Reply With Quote
Old 03-24-2019, 05:29 PM   #10
xGoggles88x
bump, still looking for the right deal.
Old 03-26-2019, 02:04 AM   #11
spoolinrb25det
spoolinrb25det's Avatar
spoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to behold
spoolinrb25det is offline   Reply With Quote
Old 03-26-2019, 09:00 AM   #12
nm240sx
nm240sx's Avatar
Originally Posted by spoolinrb25det View Post
Sick!!!!!!!!
Old 03-26-2019, 12:48 PM   #13
xGoggles88x
Is this only meant for off road use? Since it can't be titled in the U.S. correct?
Old 03-26-2019, 06:56 PM   #14
spoolinrb25det
Correct track use only
Old 03-27-2019, 02:17 AM   #15
M1992
M1992 is an unknown quantity at this point
Any interest in a built motor Evo 8 that needs some paint up front? makes 400/400 at the wheels on E85 but just needs a turbo and injector upgrade to go up to 900hp. Currently maxxed out on stock Evo 9 turbo.
M1992 is offline   Reply With Quote
Old 03-31-2019, 05:17 PM   #16
xGoggles88x
bump, still looking for a mark ii or toyota chaser.
Old 04-10-2019, 12:42 AM   #17
nycbeezk
nycbeezk is an unknown quantity at this point
Only Mark ii n chaser?
nycbeezk is offline   Reply With Quote
Old 04-10-2019, 07:54 AM   #18
240sxxtc
240sxxtc is an unknown quantity at this point
s13 ls swap for trade. Excellent condition
240sxxtc is offline   Reply With Quote
Old 04-12-2019, 06:55 AM   #19
NewTeacher2017
NewTeacher2017 is an unknown quantity at this point
3 pics? No video?
NewTeacher2017 is offline   Reply With Quote
Old 04-12-2019, 06:57 AM   #20
xGoggles88x
If you want more pictures you can PM me and I'll send you pic and videos of it running. Bump.
Old 04-21-2019, 08:00 AM   #21
2bar_silvia
2bar_silvia is an unknown quantity at this point
Trade?
2bar_silvia is offline   Reply With Quote
Old 04-25-2019, 02:31 PM   #22
bluz370
bluz370 is an unknown quantity at this point
https://zilvia.net/f/showthread.php?t=668498
Trade?
bluz370 is offline   Reply With Quote
Old 04-25-2019, 08:52 PM   #23
EPerez240
EPerez240 is an unknown quantity at this point
1jz swapped is300?
https://flic.kr/p/2fFcLjk
EPerez240 is offline   Reply With Quote
Old 04-25-2019, 08:54 PM   #24
xGoggles88x
Private messages me details on is300.
Old 04-25-2019, 08:55 PM   #25
xGoggles88x
Originally Posted by EPerez240 View Post
1jz swapped is300?
PM me more information and details.
Old 04-26-2019, 06:18 AM   #26
xGoggles88x
Originally Posted by bluz370 View Post
pm me more info,interested.
Old 05-05-2019, 05:01 PM   #27
xGoggles88x
Sold!!! Lock up thread.
Old 04-05-2020, 06:48 AM   #28
nburg
nburg is an unknown quantity at this point
idiot i am, didnt see sold
nburg is offline   Reply With Quote
