09-05-2018, 08:23 PM | #22171 |
Okay, someone please clarify this for me once and for all. Ive looked all over nico and zilvia and find very scant info on this. The so called Q45 interior chrome door handle swap. I bought a set of Q45 door handles off of ebay under the impression that they will work but I come to find out that the housing is too bulky and the prongs dont line up.
If at all possible, can someone PM me a link or show a photo of Q45 door handles that actually fit on a S14? Ive read numerous times that theyre a direct swap but obviously not since my pair didnt fit. Thanks!
Skurr Skurr |
09-05-2018, 08:28 PM | #22172 | |
So, undo battery, remove ECU and disconnect the harness, undo the bolts to open the ECU cover, then carefully inspect for any obvious burns. If youre not sure take photos and post here.
Skurr Skurr |
09-05-2018, 08:40 PM | #22173 | |
Dont be a pussy...Leave your name |
09-06-2018, 06:21 AM | #22175 |
The ECU looks clean, Id say look at the FSM and start figuring out whats on and off based on key position. If something is staying off/on that shouldnt be for that key position figure out why by tracing wires and testing with a multimeter. Use the EC/EL section of the FSM.
Skurr Skurr |
09-06-2018, 06:26 AM | #22176 | |
Skurr Skurr |
09-06-2018, 06:32 AM | #22177 | |
09-06-2018, 06:28 PM | #22178 |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
I have power to the injectors but there still not working. Any thoughts? Is a ka24e 1990 240sx s13, could it be the crank sensor and if so where is it and how u test it?
Sent from my iPhone using Tapatalk |
09-07-2018, 08:22 AM | #22179 | |
Check the following for engine diagnostics before you start replacing things, Fuel Air Spark Timing
Skurr Skurr |
09-07-2018, 09:48 PM | #22180 |
My car was smashed into by some random dude.
This can be repaired by buying a new OEM rear fender correct? I know it will cost a few thousand prob but I am ok with that. I have an extra door so I am fine on that part. Seems like a simple enough job for a body shop? Buy that part and replace? Last edited by imbored205; 09-29-2018 at 06:20 PM.. |
09-08-2018, 06:12 AM | #22181 | |
Or you can cut it all out, use some fat overs and say fuck it, because race car now Seriously, if his insurance is paying and YOUR choice of body shop is willing to do the work if they use your parts(door), quarter, and they are repainting to match, jump on it
09-08-2018, 12:37 PM | #22182 |
There’s the distributor I think there’s a crank position sensor in it from the wires coming up from the bottom instead of the plug would this stop it from firing the injectors? If it doesn’t work I do have good spark Sent from my iPhone using Tapatalk |
09-08-2018, 02:31 PM | #22183 | |
09-08-2018, 03:44 PM | #22184 | |
I do have another s14 of the same color but would like to fix this one just because.. I will just get the payout from the other party's insurance since I wasn't at fault and buy back. |
09-09-2018, 06:44 AM | #22185 | |
09-10-2018, 04:31 PM | #22186 | |
AFC #1
09-11-2018, 07:42 PM | #22187 |
Trader Rating: (18)
Feedback Score: 18 reviews
Does anyone know what pitch/thread allen bolt is used on the codyace ac brackets? I have somehow lost 2 screws on mine and I dont want the damn compressor falling out. I am talking about the allen bolts that go from adaptor to block.
I emailed codyace but no response. |
09-11-2018, 08:50 PM | #22188 |
Please help me. I want to drive my car.
What type of connector runs to this knock sensor harness and where do i get the connector for it i just researched for ten mins. I need the part that runs from harness to the plug that Goes to this. Sent from my iPhone using Tapatalk |
09-12-2018, 06:14 AM | #22189 |
Anyone know a good replacement OE clutch master cylinder for S14?
Reason why Im asking is that my clutch pedal never comes all the way up after depressing it unless I pull it up with my toe from underneath. Ive replaced the spring on the pedal thinking that was it, but turns out its not so Im starting to think the clutch master cylinder is the reason. Id love to hear some thoughts on this, thank you
Skurr Skurr |
09-12-2018, 06:51 AM | #22190 | |
09-12-2018, 07:06 AM | #22191 | |
Also bench bleed the master and slave before you install will save you some time. GL
(づ。◕‿‿◕。)づ T E A M B L O O M |
09-12-2018, 09:54 AM | #22193 | |
Trader Rating: (31)
Feedback Score: 31 reviews
Sent from my SM-G955U using Tapatalk |
09-15-2018, 01:27 PM | #22194 |
Just wondering, for those of you with an s13 who did a 5 lug swap. What do you guys run for a spare tire? A z32 or s14 spare tire or none at all. I’ve been reading the z32 spare is good because it obviously clears the brakes. Which i have done. But just was curious what other people used.
09-15-2018, 04:27 PM | #22195 |
Hey all, Im in a bit of a predicament here. I have an S14 with a ABS differential. I grabbed a spare diff from someone not knowing mine was ABS, the one I grabbed was a free S13 non-ABS.
Is there any way I can make the spare one work with my ABS pumpkin? Can I transfer in the internals from non-ABS into my ABS diff and use my ABS output shafts? Am I crazy?
Skurr Skurr |
09-15-2018, 05:55 PM | #22196 |
You you need to swap that diff in ASAP? I thought you grabbed it as a spare.
I would sell it and get the right one. Or if you're dead-set on using the S13 one, get an S14 non-ABS driveshaft instead of swapping the carrier between housings. |
09-15-2018, 05:58 PM | #22197 | |
Im starting to think what Im trying to do wont be possible.
Skurr Skurr |
09-17-2018, 04:49 AM | #22199 |
Option 4:
Rebuild YOUR diff with a OBX Racing Helical, Kaaz, or Cusco unit
09-17-2018, 07:59 AM | #22200 | |
