04-01-2016, 07:20 PM | #1 |
1988 Nissan Cefiro A31
Year: 1988
Make: Nissan Model: Cefiro A31 Price: $13,995 Mileage: 86,000 Color: pearl white Private or Dealer Listing: Private Listing Location (State): Springfield, VA Transmission: Manual Drivetrain: Rear Wheel Drive VA title call/ text at 7038648176 Description: Hey guys I'm selling my 1988 Nissan Cefiro that was imported thru Japanese classics llc and is 100% legal. The Cefiro came swapped from japan with an s14 sr20det in Japan but i replaced with a 1JZ vvti. The car runs great with no issues what so ever as its my daily driver. The car is running off the stock ecu. The car does have some rust on the rear fender wells but nothing major for its age. Frame rails are rust free and the paint still shines. The rear seats have been removed to accommodate an aluminium battery box but will be included with the sale. ENGINE: 1JZ VVTI from a Toyota Chaser Heat Shielding Gasket - BOTH Upper and Lower Gaskets intake manifold 1JZ/2JZ Mishimoto Thermostat 1JZ Denso Oxygen Sensor Custom engine and trans mount Tial 51mm BOV NGK Iridium IX spark plug 6418 / BKR6EIX K&N 4 inch Universal Filter, Short Version Freed Enginering Custom v band downpipe Freed Enginering Custom midpipe with Greedy axel back Custom engine and trans mount Chase bays fuel lines Walbro 255 Fuel pump Alumunium radiator (came with car from japan) HPS Radiator Hoses - Blue Greddy R34 Intercooler using 2.75" Intercooler Piping AEM Wideband ARC Switch panel Transmission/Suspension/Wheels: Dowel Pin For R154 And W58 Flywheel R154 transmission R154 OEM flywheel Marlin Crawler Shifter Socket R154 Marlin Crawler Urethane Shifter Bushing For R154 Transmission ARP Flywheel bolts 1JZ/2JZ Spec Stage 2+ clutch Custom power steering and clutch line Freed Enginering Custom shifter extension for r154 Freed Enginering Custom driveshaft Nismo Differential Front and rear Cusco strut bars Tiens Coilovers "super drift street coils" 5- lug conversion New front wheel hubs Z32 brakes all around with Z32 rear e-brake New power stop brakes all around and drums Tien inner and outer tie rods SIkkY sway bar Custom s14 steering knuckles from japan WORK VSXX 18x10.5 +15 4.5" with New lip 18x9.5 +22 3" lip New tires on the front. not even a month old. Achilles tires front 225/40R18 100% tire rear same size but other brand. 50% Interior: Defi BF advance "amber" boost, oil temp, water temp, 80mm 9k rpm tach Driver side has a replica Bride lowMax seat Street Faction seat rails R32 seat for the passenger side Nardi Steering wheel Tomei Shift knob Nismo shifter "Not short shifter" Xplod CD player Drift "buttion" for ebrake New window motor for driver rear door Aluminium re-locator battery box. back seat "will come with back lower seat" Exterior: Car came painted pearl white from japan Full ORIGIN body kit Black Plasti dipped door handles 8K HIDs LED blubs for the corners and lisence plate. 35% tint all around. carbon fiber trunk vinyl black vinyl roof. pealing off on the front. sucks i know. |
Tags |
1jz vvti, nissan, rhd |
