Old 05-20-2020, 08:55 PM   #1
Jsvine
Jsvine is an unknown quantity at this point
SR Extreme overheat incident!
So yesterday I went to warm up my car with my electric fans off, per usual because I removed my thermostat. I had went inside my house to do something then got distracted and took longer than I had anticipated. When I had returned to my car the oil temp was around 150 Celsius which is ~300f (this is the highest temp I?ve ever heard of or seen a SR20DET reach). So I turned off my car and let it cool down to around 90 Celsius which is ~200f and refilled the coolant because it had all evaporated (the radiator pressure cap did not release but all my coolant was gone and no sign of coolant on the ground). Now after this event I have a backfire/misfire issue above 4k. What could overheating to that temp have damaged to cause this misfire issue?
Jsvine is offline   Reply With Quote
Old 05-20-2020, 11:25 PM   #2
Kingtal0n
Kingtal0n's Avatar
compression test look for bad Head gasket
check the wiring and electronics around and on the engine for burnt/crispy/melted
The high temp may have fried an electronic or blown the head gasket
Change the oil asap, heating it that high may have ruined it
post pictures of the plugs, and when you do the compression test use 2 different testers if the first one gives a bad result. Also write the numbers down to the nearest decimal. 145.5PSI for example.
Old 05-20-2020, 11:49 PM   #3
Jsvine
Thank you! I will do that when I get home today👍
Old 05-21-2020, 08:01 AM   #4
jedi03
GL...i accidentally overheated one of my sr's when fan wiring fried...only went to 250F thankfully but no damage was done, also thankfully!
Old 05-21-2020, 08:25 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
how do you know it didn't release? at that temp it would all be steam anyways.
1: if your head gasket DIDN'T blow i'd be amazed
2: check your oil for coolant contamination and vice versa
3: you may have done damage to coilpacks with that level of heat.
Old 05-23-2020, 02:31 AM   #6
Jsvine
Found the issue! 2 coil packs had cracked. Thank you for your help!
