Old 07-16-2019, 06:52 PM   #1
Prince of Saiyans
Prince of Saiyans's Avatar
Prince of Saiyans is just really nicePrince of Saiyans is just really nicePrince of Saiyans is just really nicePrince of Saiyans is just really nicePrince of Saiyans is just really nicePrince of Saiyans is just really nicePrince of Saiyans is just really nicePrince of Saiyans is just really nice
1990 240sx s13 sr20det 356hp
Full picture album https://imgur.com/a/InpHBjl
Walk around and compression test video https://youtu.be/v5pKfBFUOmE
Carfax https://imgur.com/a/rQ3mGVD
$7k
271 on 91
301 on E85 with just wastegate
356 on E85 with EBC switched on
Compression
Cylinder 1 - 149 psi
Cylinder 2 - 150 psi
Cylinder 3 - 149 psi
Cylinder 4 - 151 psi
Looking to sell my 1990 S13 hatch. I'm in Phoenix AZ for school right now. So car is with me out here but it's registered in California. Clean title.
I bought the car all stock except someone had put a dual cam in it. I put a ton of time and parts into this car. Car runs great. Super torquey with the 4.6 final drive. It has a megasquirt ECU. Was tuned by Toby at Advanced Engine Dynamix in Corona, CA. It's a speed density tune, so no MAF. It makes 356hp on 15 psi of boost with E85. I'll post the dyno sheet. It has a flex fuel sensors. So it's tuned on both 91 and E85.
Everything electrical works. The seatbelts, the pop ups, all the lighting, power windows and power mirrors all work.
Frame is straight. Body is in great shape except the roof where someone put an larger than stock sunroof in. The car is an SE so it came stock with one. Someone just wanted it bigger i guess. So roof needs a little work. Though it really doesn't look that bad. The paint as a whole is ok. It's was a cheaply done job. Its has some chipping as well.
The Interior is also just ok. It's not the best or the worst. Headliner is a bit messed up. Again because of the sunroof. Dash is cracked. I got a NX cluster working with a heads up display. I've never seen it done before but I'm sure someone else has done it too.
PART LIST WITH SOME PART NUMBERS
BRAKES
z32 30mm aluminum front calipers and rotors
z32 rear calipers and rotors
z32 parking brakes w/ 2+2 cables
z32 master cylinder
z32 brake booster
Front and rear Diftech steel braided brake lines ----10443
SUSPENSION
Front and rear ISR sway bars ---- IS-SWY-S13
Megan street series coilovers ---- MR-CDK-NS13
SUSPENSION FRONT
Megan pillow tension rods ---- MRS-NS-1781
Megan tension rod support bar ---- MRS-NS-1791
Megan strut bar ---- MR-SB-NS13FU-1P
SUSPENSION REAR
Megan rear toe control arms ---- MRS-NS-1770
Megan rear lower traction rods ---- MRS-NS-1780
Megan lower contol arms ---- MRS-NS-1720
Megan upper control arms ---- MRS-NS-1710
Megan rear lower support bar ---- MRS-NS-1793
Rear strut bar
FINAL DRIVE
S15 helical LSD (s13 housing)
4.636 ring and pinion (from nissan xterra)
ENGINE
Brian crower cams 264°/264° ---- BC0201
Brian crower Ti valve springs & retainers ---- BC0200
ARP head studs ---- 102-4701
Tomei headgasket 87.0 - 1.2mm ---- TA4070-NS08B
Tomei rocker arm stoppers ---- 13220R300
Megan exhaust manifold ---- MR-SSH-NS13M
FUEL
JEGS injectors 1000cc
Fuelab fuel pressure regulators ---- 51502-3
AEM E85 340LPH fuel pump ---- 50-1200
TURBO
Garrett GT2871R .64 ---- 836026-5012S
GReddy FV blow-off valve ---- 11501665
Front mount intercooler
ENGINE ELECTRICAL
Megasquirt pnp2 ECU ---- 8994
GM flex fuel sensor
GM IAT sensor
14.7 spartan wideband controller
Bosch LSU 4.9 wideband
AEM Boost Control Solenoid ---- 30-2400
Wiring specialties main engine harness ---- WRS-S13S13-MAIN
Wiring specialties trans harness ---- WRS-S13S13-TRN
Wiring specialties coil pack harness ---- WRS-SR20-COIL
TRANSMISSION
Stock SR20
Exedy stage 1 clutch ---- 06803B
Short shifter
INTERIOR
NX1600 cluster with working Heads Up Display
NRG bucket seats
NRG quick release steering wheel hub
WHEELS AND TIRES
AVID.1 AV-06 18x8.5 +35 5x114.3
225/40ZR18
MISCELLANEOUS
Chase bay power steering reservoir ---- CB-N-PSK4
Chase bays steering rack hard line kit ---- CB-N-S134RACK
Megan motor mounts and trans mount ---- MRS-NS-1740
Megan light weight pulley set ---- MR-PY-NS13SR20-S
GKTECH catch can
ISR radiator
Samco sport radiator hoses
Custom exhaust (comes with magnaflow muffler 11219)
Battery relocated to trunk
Aluminum Coolant Overflow Tank
5 lug hubs
Alarm system w/ FOB
Prince of Saiyans is offline
Old 07-17-2019, 11:33 AM   #2
CalebS13
CalebS13 is an unknown quantity at this point
Toby is an awesome dude and great tuner.... Nice car GLWS Free bump
CalebS13 is offline
Old 07-20-2019, 08:30 PM   #3
Prince of Saiyans
Open to all reasonable offers. Got to get this sold.
Old 07-20-2019, 10:55 PM   #4
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Are you heading back to CA soon?
DataXUnknown is offline
Old 07-20-2019, 11:20 PM   #5
Prince of Saiyans
I can take it out there. I'm from Temecula and go back there quite often. In fact if I can't sell it soon I was planing on taking it back there and leaving it. I just finished school and took a job in Texas and it cant come with me.
Old 07-26-2019, 07:03 PM   #6
Prince of Saiyans
Price drop to 7k. I need this car gone. If I don't sell it by next weekend this thing is going to sit in Cali for the next few years.
Old 07-29-2019, 07:38 PM   #7
Siksr
Siksr is an unknown quantity at this point
If you bring this car to california let me know im interested but cant go out to AZ. im in the Inland Empire
Siksr is offline
Old 05-11-2020, 11:39 AM   #8
SortaKindaFlushAlmost
SortaKindaFlushAlmost's Avatar
SortaKindaFlushAlmost is an unknown quantity at this point
do you still have it? im close enough to phoenix
SortaKindaFlushAlmost is offline
Old 05-15-2020, 12:49 PM   #9
Koala.the.z32
Koala.the.z32 is an unknown quantity at this point
Hey man PM me so that we can talk about this car a little bit. 9728383436
Koala.the.z32 is offline
Old 05-20-2020, 09:42 PM   #10
Shert73
Shert73 is an unknown quantity at this point
Is this still available?
Shert73 is offline
Old 05-28-2020, 04:18 PM   #11
lukesr20det
lukesr20det's Avatar
lukesr20det is an unknown quantity at this point
BUMP for a very well laid out and organized post.
lukesr20det is offline
Old 06-04-2020, 09:49 AM   #12
Future240
Future Moderator
Future240's Avatar
Bump for a legit car with a great price and very good sales ad.
Originally Posted by ThatGuy
Future240 is offline
Old 06-06-2020, 01:19 AM   #13
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
Out of curiosity, why can't it come to texas? Texas is great for cars; they never rot, our roads are fast and scenic, and our vehicle inspection and papering processes are much more reasonable, so far as I know.
mechanicalmoron is offline
Old 06-06-2020, 07:45 PM   #14
badicalradical
badicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of light
Am I the only one noticing the OP last posted 7-26-2019?
badicalradical is offline
Old 06-08-2020, 04:02 PM   #15
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
yeah this thread is like 10 months old.
next time ppl should just PM him.
brndck is offline
