Off Topic Chat All non related chat goes here. |
04-12-2013, 07:58 AM | #31 | ||
Future Moderator
I'm not trying to troll or anything. I am genuinely curious on what kind of KA that makes.
04-12-2013, 08:58 AM | #32 |
05-15-2013, 10:29 PM | #34 |
im still curious though about what 9k later has given this guy.. sorry bout the late entry here just saw this die and wanted to revive it if it dies again i wont bother... ive been seeing 1uz swaps pop up more lately.. whats up with that. ive personally hear dof em but never knew much about them.. isnt a guy on here putting a 1uz in his s14?
05-15-2013, 10:38 PM | #35 |
2jz all day
this is in regards to a USDM 2jz Not only is it a proven motor, but because it was offered stateside makes it a hell of alot easier to get parts. Plus if done right, you have the option of getting it bar'd and not have to worry about smogs or getting reffed. 1000 hp on stock gte internals, other than arp studs and thicker hg... yea tell me another motor that can handle that. |
05-24-2013, 11:56 AM | #41 |
2jz-gte
Where else can you get 500-600 horsepower, 25mpg+(disclaimer: 3200lb vehicle or less), and 200,000 miles of reliability using OEM internals with easy access of affordable parts in the USA for under $10,000 ? Not going to happen with an sr, rb, ls, nope nope and nope. |
05-24-2013, 01:24 PM | #42 |
Man who run behind car get exhausted. Last edited by bob4020; 06-03-2013 at 03:02 PM.. |
05-24-2013, 01:41 PM | #43 | |
yeah.. tuners in japan kept frying ecu's trying to tune it when the car first came out. the computer running the car is literally too smart for its owngood when it comes to tuning. xD so i feel you there i wouldnt dare crack one of these open unless i was absolutley sure about what i was doing |
05-24-2013, 02:17 PM | #44 | |
But the same applies to say... an LSx engine. You can also get 25mpg out of that in the 240sx chassis... mainly for the same reason- final vehicle weight is around 3200lbs. It all adds up, Look at an SR20DET that nets 30mpg such as the s15 six speed swap. The low rotating mass (compared to the automatic transmission) and numerically low gearing (3.4x at the rear differential) help keep the energy lost to turning the internals of the sr20det low. In other words, it takes X horsepower to push a 3000lb car the same distance no matter what (forget wind resistance). Now as you reduce engine RPM, you reduce energy lost due to turning components. So as we lower and lower the cruise RPM of that 3000lb vehicle we use less and less fuel to go the same distance. Thats because you have to first calculate the HP required to move that 3000lb vehicle- and THEN add the HP required to turn every single drivetrain component at a given RPM. That cost decreases as RPM decreases, generally. but the cost to push the car remains the same. |
05-24-2013, 02:41 PM | #45 |
feels like i just studied some physics xD makes sense LSx motors give good power to weight ratio and with good light bolt ons can get pretty good mpgs..
hahaha come to think of it ive heard plenty of people state why theie rear seats and interior is gone and the answer includes gas milage. this also explains why i am usually pro sr20 because its weight to power ratio a long with its mpg fit a good dd/weekend track car |
05-24-2013, 03:59 PM | #46 | |
05-24-2013, 04:32 PM | #47 |
haha no demands bro i believe you but ive done the same thing taken all my rear components out for mpg.. strangely though my s13 sr blacktop was getting around 400 miles to the tank with everything still on the vehicle..0.0)/) then again i did a whole look around and fluid change as well as gasket replacement on the engine before even starting it up.. what boost were you running? stock 7psi?
05-24-2013, 04:53 PM | #48 | |
I also have a video of the dyno run somewhere. |
05-24-2013, 11:13 PM | #52 | |
My favorite swap is a plain ol' sr20, but the vq30 has my attention. |
05-25-2013, 12:25 AM | #54 |
05-25-2013, 07:13 AM | #55 |
I avoid V6 configurations. Mainly because you get all of the hassles of a V8 (two heads, two exhaust manifolds/gaskets, two sets of head hardware, two sides of stuff to fail basically) plus they are much harder to work on (change the plugs on a V8 and youll see what I mean)
And at the end of the day you dont even get V8 displacement. You may as well go V8. I see Inline 6, or V8, as viable options. The Inline 6 is a all of the torque and response of the V6 (there is nothing magical about a V configuration) with the added benefits of having only 1 single head gasket, 1 single exhaust manifold, etc... a much simpler design, and easy plug access. Easier to work on. |
05-25-2013, 08:04 AM | #56 |
heres an oem internals 2j I tuned with an upgraded turbo, injectors, exhaust, and power FC. Around 15psi of boost on pump gas. I didnt choose the turbo size I feel it was mismatched, but I am just the tuner for this one doing my job for paid.
anyways. The First run (blue) is the proper ignition timing. The red line is when you add 2* of ignition timing past optimal. The green is -2* of ignition timing. Notice when you add +2* of timing btdc it gains torque, but loses horsepower. notice when you pull -2* of timing it loses both torque AND horsepower. (but not as much horsepower) SO there is an optimal point, and it is +/- 2* btdc the "gains" in torque from the red line are not actually gains. They are indicating that there may be (most likely) damaging pressure spikes beginning to occur during combustion, giving rise to slightly inflated torque numbers. But that behavior leads to a blown head gasket, damaged rod bearings, and it can eat up the head and deck, and take small chunks/flakes of the piston apart. Especially being cast components. An experienced tuner could tell by the shape of the torque curve, see how it sort of meanders up and down? Years of experience is why I know this. |
05-25-2013, 10:40 AM | #57 | ||
I love the idea of the VQ30DET, but these days I'm all about simplicity. So I'll just stick with an S13 or S14 SR mated to a Z33 6spd trans. |
05-25-2013, 02:40 PM | #58 | |
Being coil on plug w/ the plugs in the middle of the heads, I don't know if this is really a valid point, although I have not changed spark plugs in a vq before and could be dead wrong. |
05-25-2013, 05:06 PM | #60 | |
K24 Miata swap... finally a reality |
