Old 02-13-2019, 03:19 AM   #4081
Noctophobia
Noctophobia is an unknown quantity at this point
Originally Posted by deolio View Post
yes it would probably be flush. maybe even poke a bit. depends on hight and camber. x10 could also work, just depends on offset etc. look through the wheel fitment whore thread a bit.
Thanks gonna check out that thread!
Noctophobia is offline   Reply With Quote
Old 03-11-2019, 02:45 PM   #4082
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
I want to change my autocross/lapping setup and want to know what will it take to fit. Spacers? Fender push? Just a roll?
Here's the setup:
Stock body S13 hatch
Apexi coilovers with moderate 1.2" drop.
Front: S14 LCA and 5lug knuckles with 300zx brakes
Rear: S14 subframe with aftermarket arms and 5 lugs
Wheel/Tires: 17x9 +35 Koya CR-TEK with 255/40r17 RE71R
I'm not 100% on the offset but I think it's +35.
Crazyced is offline   Reply With Quote
Old 03-12-2019, 06:59 PM   #4083
derass
Here's the setup:
That'll fit. Just need to get the offset down to +15, and pull the fenders.
https://zilvia.net/f/showpost.php?p=...postcount=3609
https://zilvia.net/f/showpost.php?p=...postcount=3632
https://zilvia.net/f/showpost.php?p=...postcount=3640
Old 03-30-2019, 12:35 AM   #4084
TheDrunkenFist
TheDrunkenFist is an unknown quantity at this point
Hello, i have a set of ccw classics
17x10 -36 front
17x11 -36 rear
on coilovers lowered about 1"
caster alignment is around stock, no spacers,fenders will be widened.
With 245/45 r17 im having an issue where the tire rubs against the frame below the harness gromet. Weve already hammered the seams behind the wheel and it still gets hung on the frame.
About what tire size and caster angle can i get away with to have minimal rubbing in the front? I prefer a meaty tire with very little to no stretch.
thanks.
TheDrunkenFist is offline   Reply With Quote
Old 03-31-2019, 04:50 PM   #4085
danbarnett123
danbarnett123 is making a name for him/her selfdanbarnett123 is making a name for him/her selfdanbarnett123 is making a name for him/her self
S14
Rear 18x10 +18
255/35 or 265/35
Coilovers
Adjustable toe and camber arms
Streetable ride height (not slammed, maybe 1/2” gap between tire and fender line)
Do I need to roll fenders?
1991 Z32 NA t-tops 5 speed
1997 S14s KA24 5 speed and SR 6 speed
danbarnett123 is offline   Reply With Quote
Old 04-01-2019, 04:31 PM   #4086
deolio
deolio's Avatar
17x10 -36 front
17x11 -36 rear
it's the absurd offset and monster truck tires. dropping to a 40 series would help. going to a 235 would help more. getting wheels that fit would help the most.
yes.
Old 04-02-2019, 11:54 AM   #4087
Ginjuice
Ginjuice's Avatar
Ginjuice is an unknown quantity at this point
I am running on:
- Front: 17X9 ET35 + 10mm spacer w/235/40r17 (stock fenders)
- Rear: 17x10 (Don't remember the ET) w/245/40R17(rolled fenders)
Ginjuice is offline   Reply With Quote
Old 04-03-2019, 03:47 PM   #4088
NMcCabe2gX
NMcCabe2gX is an unknown quantity at this point
1991 240SX SE Wheel Fitment
New to the forum, but have plenty of questions as this is my first time owning a Nissan. I'm wanting to convert my S13 hatch to a Type X body; however, I'm curious as to whether or not a 18x9 40 inset 5x100 bolt pattern Enkei PF05 with 235/40/18 tires on the front and 265/40/18 tires on the rear would be clear. The plan is to put it on coil overs and get functional, yet tight fitment. Any help would be great.
NMcCabe2gX is offline   Reply With Quote
Old 04-03-2019, 04:35 PM   #4089
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
1) Stock S13 bolt pattern is 4x114.3, 5 lug conversion hubs are 5x114.3 so that 5x100 bolt pattern WILL NOT fit your car.
2) The tire sizes and offsets you are listing are not conducive to "fitment". a +40 offset upfront will require spacers. i run a 17x9.5 +38 in the rear just fine on a 245 with rolled fenders (no pull). a 265 WILL require camber to fit as it will be squared up on the wheel (meaning no stretch)
3) functional fitment is a bit difficult to pull off. i would suggest running 17x8.5 +35 in front and 17x9.5 +38 in the rear. if you want hotboi, 17x9.5 +12 to +15 all around with some rubber band stretched tires (like 215 or 225)
4) if you want S13 kouki aero, i make everything but the front bumper.
Old 04-03-2019, 07:28 PM   #4090
deolio
deolio's Avatar
5x114.3* 18x9 +28 front with a 10mm spacer and 225/40's, 18x9.5 +25 rear with 245/40's. just need a roll and maybe a slight pull in the rear.
if you're really trying to have the car be functional and not just look the part, i'd suggest running 17x9.5 +12's all around with some sticky 235 or 245/40's. keep it simple.
Old 04-04-2019, 01:08 PM   #4091
NMcCabe2gX
Gotcha. The car will hopefully be making 400-450hp when it's all said and done, so I'm trying to make sure I can have a reliable and functional set up if I decide to have some fun from time to time. Originally I was thinking I could roll 18s, because I have 17s on another car and felt they were too small. But thinking about it from a functional point of view like I mentioned 17s would probably make a lot more sense.
Old 04-24-2019, 11:40 PM   #4092
zhice
zhice is an unknown quantity at this point
S13
Front: 19x9.5 +40 245 40 19
Rear:19x10.5 +23 285 35 19
What would I need to do to make these fit?
zhice is offline   Reply With Quote
Old 04-28-2019, 09:15 AM   #4093
DriftingBrandon
DriftingBrandon's Avatar
DriftingBrandon is an unknown quantity at this point
S13 Front. What size spacer is required to clear Z32 brakes, specifically, with VSKF A Disk. I want to go ahead and get the spacers to dial fitment in before I upgrade to Z32.
DriftingBrandon is offline   Reply With Quote
Old 05-02-2019, 10:30 PM   #4094
ANVIL
ANVIL's Avatar
ANVIL can only hope to improve
Wheel fitment noob here. I am looking at a set of 17x8.5 +12 F 17x9.5 +13 R for my s13 hatch. +20mm F fenders. Stock r fenders. Ideally i want to run a 275 or 265 tire in the rear. Lowered on coils but not sure how much. Would a 275/35 fit? Id run whatever tire would fit w/o mods in F. What mods would i need to do to fit?
ANVIL is offline   Reply With Quote
Old 05-02-2019, 10:55 PM   #4095
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
17x9.5 +13 will not fit in the rear without over 3* camber and a stretched tire. Assuming your fenders are not rolled and pulled.
I'd strongly suggest going through the maximum tire thread to give yourself a better idea.
https://zilvia.net/f/showthread.php?t=166563
Posts may be old, but several still have photos for you to reference.
-Jspec-
Instagram/CrimsonRockett
Old 05-03-2019, 08:17 AM   #4096
ANVIL
ANVIL's Avatar
appreciate the reply.
Basically i want to get a wider tire in the rear without adding over fenders and crazy camber. Pull and roll im willing to do
What would you recommend? Is it the wheel specs that are preventing a 275 or is a 275 just too wide for stock body? Would that wheel work with a 255
Old 05-03-2019, 10:30 AM   #4097
CrimsonRockett
The Architect.
This was back in 2009. 17x10 +18 with a 235/40. I believe this was 3* camber when I got it aligned.
Comparing my 17x10 +18 to your 17x9.5 +13 rear, your wheel specs would only retract the wheel by 1mm.
As you can see, the wheel position is already pretty much at the max for factory body. If you run 17x9.5 +13, you may get away with a 245/40 or something along those lines, but not without a roll/pull or excessive camber. Considering the amount of tire you're looking to run, I would think the less camber you run, the better.
My recommendation would be to run a higher offset wheel (let's say 17x9.5 +30~). You should be able to run a meatier tire with only minor massage work on the fenders.
-Jspec-
Old 05-03-2019, 02:00 PM   #4098
ANVIL
ANVIL's Avatar
Awesome appreciate the input. Ill scratch those off the list and look for something with higher offset
Old 05-13-2019, 07:41 PM   #4099
marc-s13
marc-s13's Avatar
marc-s13 is on a distinguished road
marc-s13 is offline   Reply With Quote
Old 05-13-2019, 07:44 PM   #4100
marc-s13
marc-s13's Avatar
Hey, looking for a little help on figuring out my fitment.
Stock Body S13 Hatch
Fortune Auto 500 7k/6k
235/40/R17
17x9+15 all around
Toyo R1R
Looking for fitment like CrimsonRockett's (any rubbing issues on that car when you had it?). Wouldn't mind going higher.
Don't quite know if it'll fit yet because I don't have the tires in atm, and I've seen a lot of conflicting posts on +15 on a 9J, so I don't know if it'll have terrible poke or not.
thanks
Old 05-13-2019, 10:52 PM   #4101
CrimsonRockett
The Architect.
235/40/R17
17x9+15 all around
Toyo R1R
thanks
If you run 235/40 all around, I'd strongly recommend rolling/massaging the fenders a bit. It'll help to avoid running so much unnecessary camber. Also depends on your ride height.
I had very minor rubbing issues back then. I'll try to dig up pictures of a set up I had at one point that was 17x9 +15 all around.
-Jspec-
Old 05-13-2019, 10:53 PM   #4102
marc-s13
marc-s13's Avatar
Looking to run similar ride height to that photo or a bit higher. I do plan on hammering the lips flat all around but don’t want a visible flare. Also gonna tuck the front harness.
Also, that’d be great if you could send the photos. Thanks man
Old 05-15-2019, 02:15 AM   #4103
Jo_Galezo
Jo_Galezo's Avatar
Jo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant futureJo_Galezo has a brilliant future
235/40/R17
17x9+15 all around
Toyo R1R
thanks
This is 17x9 +22 on 235/40 all around.
Just rolled my fenders a bit & tucked my harness. I have no arms for added adjustment or anything. Everythings all stock except my lowered bc coilovers. If i had arms i could probably get lower by adding camber, but im content with this. Just wanted to add some visual aid for a similar spec you wanna run.
Federal All Seaons tires
Jo_Galezo is offline   Reply With Quote
Old 05-15-2019, 02:16 AM   #4104
marc-s13
marc-s13's Avatar
Thanks man. Very helpful. How do the 235s feel on a stock S13 by the way?
Just got my Toyos today.
Old 05-15-2019, 02:20 AM   #4105
Jo_Galezo
Jo_Galezo's Avatar
They feel really good, this was my set up before 225/35 18
& now with my new tires, they absorb impact wayyyy better & i dont have to worry about getting a flat every two seconds lol
Old 05-15-2019, 02:21 AM   #4106
marc-s13
marc-s13's Avatar
Yeah 35 series prob wasn’t the greatest idea haha
Thanks for the pics man, your car looks great
Old 06-02-2019, 05:44 AM   #4107
Remav
Remav is an unknown quantity at this point
Hey guys,
So I got stock granny spec S13 coupe and wanna get some wheels with the perfect hellflush fitment. The wheels I'm going to get are white Fifteen 52 Tarcmacs 17x9 ET45 5x100. I'm just curious what the perfect wheel and tyre specs to fit stock s13 guards without having to pull or flare the fenders.
So my question to you guys, from what I've seen, 17x9 +15 offset sits pefectly flush with the stock fenders and fits, is this true? if not what size will?
The only problems are that my Silvia is 4×114.3, and that I'll need to remove 30 offset. If I use a 114.3x4 to 5x100 30mm spacer adapter, this should then make the wheels' effective offset 17x9+15 (45-30=15). Is it okay to use the spacer adapter too?
Any help greatly appreciated, Thanks
Pic of my car for refernce
https://ibb.co/zssVwJV
Remav is offline   Reply With Quote
Old 06-02-2019, 04:03 PM   #4108
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
Originally Posted by Remav View Post
Hey guys,
no... just no! buy them the right bolt pattern and offset the first time
ok so a few things...
1, you will HAVE TO roll your fenders. if you dont know how to do this, find a body shop that does and tell them to heat the shit out of the rear metal prior to rolling otherwise youll wind up with pressure dents in the quarter panels above BOTH rear fenders. major S-Chassis issue when rolling fenders
2, 17x9 +35 is perfect fender fitment with factory camber. 17x9 +15 is perfect fitment for the hot boi/fitment crowd. you will have to run a good amount of negative camber front + rear as well as run stretched tires. if the stretched tired and tons of camber approach is what youre looking for, then by all means. but if you want contact patch + meatier tires to actually make the car handle well and keep the power going to the ground, consider going with a higher offset.
my car on 17x8.5 +30 on 225s and 17x9.5 +38 on 245s with rolled fenders and factory camber (though i am on coilovers and adjustable arms, camber is set to -1 deg front and rear)...
3, buy wheels that are the proper size the FIRST TIME!!! ie: bolt pattern, offset and width. i would HIGHLY recommend you not waste your money on 4 lug wheels and buy a 5 lug conversion right out of the gate... this will save you A LOT of hassle and time trying to find the wheels you want. unless you are going for the old school Dorisha look with small wide wheels and extremely stretched tires, got 5 lug and never look back! yes i know it costs money to do and you are probably impatient, but take it from someone whos owned 5 of these cars over 18 years... GO 5 LUG!!! ITS A WASTE OF TIME AND MONEY NOT TO!!!
i will forewarn you that you WILL get flamed for posting the kind of questions you just did as it shows exactly how inexperienced, young and early on to the scene you are.
Old 06-02-2019, 06:03 PM   #4109
BryanSayWhat
BryanSayWhat's Avatar
BryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud of
Hey guys,
My Coupe is stock body with no roll F&R (still running front liners) and It has 17x9 +20 FN01R-C's with 10mm spacers and 225/45's. Suspension is all adjustable except the LCA.
BryanSayWhat is offline   Reply With Quote
Old 06-03-2019, 03:19 AM   #4110
Remav
Yeah new to the game, so thought I'd see what some vets thought and took in some advice ahahaha
So just bought a 5 stud conversion for s13 to s14 oem ones.
So if I purchased these wheles in 17x9 +30 and ran 225/40, they should fit easy?
Is it worth ordering the wheels now or after I do the conversion?
Will Probably also get spacers after tyres
