Old 02-02-2009, 11:57 AM   #3061
SoSideways
SoSideways's Avatar
Originally Posted by LA_phantom_240 View Post
I'm just worried that a 225 still won't have enough tread to really look 'right' on the car. The 215 looks like a bicycle tire, honestly.
Check out Federal 595s then. Those tires run wide in most sizes. The 225 will probably be as wide as some 235s from other companies.
Anything with a sidewall over 9" wide should look nice and square on your 8" rims.
Old 02-02-2009, 03:06 PM   #3062
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
I like meaty. Stretched isn't really my thing, and 215's are weak in general.
Might I recommend this thread;
http://zilvia.net/f/chat/166563-maxi...nt-thread.html
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 02-02-2009, 05:26 PM   #3063
jfandem
jfandem will become famous soon enoughjfandem will become famous soon enoughjfandem will become famous soon enoughjfandem will become famous soon enough
I really just need suggestions for tire size front and rear, and a way to get rid of some rear camber AND fill in the gap where the fenders are pulled/rolled. I put the new 235/40/18s up front and they rub too much and look too big to me, doesnt looked stretched and has way too much tire. Should i put those in the rear and would that allow me to remove some rear camber? And then get a 225 up front? Or should I go back to a 35 series up front and run wider rears? I can't stand this tire situation and can't seem to get it set how I want without killing my tires every 5-10k miles. I daily drive my s14, no drifting or track days yet, just some aggressive street driving. I want a somewhat 'normal' alignment for now so I can keep tires longer. specs again:
18x9.5 + 8
18x10.5 + 16
Stance coilovers
Front roll, rear roll and pretty good pull.
jfandem is offline   Reply With Quote
Old 02-02-2009, 08:13 PM   #3064
ross.cottrill
ross.cottrill's Avatar
ross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant future
here we go (again LOL).third set of wheels in a year.
work vs-mx
front 18x9 +5 effectively(+13 w/8m spacer)
rears 18x10.5 +/-0
again bad pics ,i will get some better ones soon..
" NEO VVL BABY FTMFW!"
Originally Posted by shagspeed
Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines
ross.cottrill is offline   Reply With Quote
Old 02-02-2009, 10:14 PM   #3065
luckky
luckky is an unknown quantity at this point
Originally Posted by 95KA-Turbo View Post
I have one extremely shitty picture from the side...it does not do it very good justice at all:
The rear was fresh off of being on a lift for 2-3 hours in near freezing temperatures, so it is not that high off the ground - but it definitely isn't how I want it to look. I just think the tires are way too small, I want to go up at least one size if not two.
MORE! please lol
luckky is offline   Reply With Quote
Old 02-02-2009, 10:15 PM   #3066
mondojackal
mondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choices
Send a message via AIM to mondojackal
I like those Works better than the old different-colored wheels!
mondojackal is offline   Reply With Quote
Old 02-02-2009, 11:16 PM   #3067
RPS13-604
RPS13-604's Avatar
RPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really nice
ross man u gotta put those work meisters back on!
RPS13-604 is offline   Reply With Quote
Old 02-02-2009, 11:40 PM   #3068
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
18x9.5 + 8
18x10.5 + 16
Stance coilovers
You have almost the exact same setup as me.lol
S14/stance/same size rims..
You are asking how to get rid of some camber? do you have camber arms installed? if so you can tweak those to help with perfect fitment..
you should definitley run 225's up front keep the 40 series though.....I have 225-40-18 up front..
I run 235 40 18 in rear on a same size rim and it looks pretty nice, no crazy stretch but a bit more than mild..comprende?
hope that helped!
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 02-02-2009, 11:43 PM   #3069
BRAIN_Z33
BRAIN_Z33's Avatar
BRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfection
Naaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
I think i like these wheels better
BRAIN_Z33 is offline   Reply With Quote
Old 02-03-2009, 01:59 AM   #3070
t1nabug
t1nabug is an unknown quantity at this point
t1nabug is offline   Reply With Quote
Old 02-03-2009, 02:51 AM   #3071
liv2drift045
liv2drift045's Avatar
liv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfection
Send a message via AIM to liv2drift045 Send a message via MSN to liv2drift045
specs?? front needs a little spacing imo at least 5-8mm if not 10mm. Looks dope though. Wish i could've put aero on my jzz30 before i got rid of it
StreetSliders.Blogspot.com
liv2drift045 is offline   Reply With Quote
Old 02-03-2009, 07:09 AM   #3072
TheRonTom31
TheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfection
Send a message via AIM to TheRonTom31
Those wheels look familliar.
Did you buy them from someone on here. If so the fitment is better than i thought it would be.
TheRonTom31 is offline   Reply With Quote
Old 02-03-2009, 03:04 PM   #3073
ZX88
ZX88's Avatar
haha word federals run so wide i put 215.45. on a 17x9.5 wheel and there is plenty of tread to go around. it funny cause they look alot like my 225.45 fk451 oh well.
Old 02-03-2009, 03:15 PM   #3074
smelly240
smelly240's Avatar
sc's dont need crazy offsets to fit nice. not as much so as s2k's but - less than a s chassis.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 02-03-2009, 03:58 PM   #3075
OBEEWON
OBEEWON's Avatar
Oh man those feddys are purdy. I think Ima try a set this spring.
That SC is nice but It could go a little lower and a little more sidewall.
Old 02-03-2009, 04:56 PM   #3076
ross.cottrill
thanx man!yeah i love the meisters but they get old real quick and almost everyone has them.im very fortunate to find these in this offset.in person these look really clean and match the nature of the car really nice...
Old 02-03-2009, 08:32 PM   #3077
94cc0rd
94cc0rd's Avatar
Originally Posted by t1nabug View Post
Nice first post!
94cc0rd is offline   Reply With Quote
Old 02-04-2009, 10:06 PM   #3078
jfandem
Ok so I'm planning on putting the new 235/40/18s in the rear, and then getting 2 new fronts.....debating between a 225/40/18 kumho SPT, or a 235/35/18 (if I can even find that size) or a federal 215/40/18? Since they run bigger than other brands? The federal 235/40s are up front right now and seriously rub so much, while the falken 245/35 never ever rubbed in front. Also you can tell my front sits too high now due to the larger sidewall, thats why im worried about running a 225/40 (wont be much smaller, correct?) thanks for any help,
Old 02-04-2009, 10:35 PM   #3079
kornaz
kornaz's Avatar
kornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfectionkornaz is close to perfection
Send a message via AIM to kornaz Send a message via Yahoo to kornaz
18X11+7. Max neg camber and still touching coilover on bumps and shit. 7 Mill spacer will go on very soon, so will be 0 offset. 265/35 Toyo Proxes R1R. Fenders are going to be pulled soon, so i can run no more than like 2° camber.
Still ghey ATM:
Ordered the fronts yesterday, so it'll be a bit of a wait till it's finished. Yes, it's dirty ( and even dirtier than any of yer girlfriends/wifes).
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fucking temperamental.
kornaz is offline   Reply With Quote
Old 02-04-2009, 10:46 PM   #3080
GabeS14
GabeS14's Avatar
Still ghey ATM:
Nice wheels Kornaz... can i have them???
haha
when did you get them?
Old 02-04-2009, 11:11 PM   #3081
kornaz
kornaz's Avatar
haha
Yes, shure. Just come scoop them up!! Lol.
I got them mid Nov. '08. Fronts will be here 8 - 12 weeks. ://
Rules:
Old 02-04-2009, 11:31 PM   #3082
kornaz
kornaz's Avatar
Couple more pics:
ROFL and i love it!!:
Old 02-05-2009, 10:31 AM   #3083
ONE80ESSEX
ONE80ESSEX's Avatar
ONE80ESSEX will become famous soon enoughONE80ESSEX will become famous soon enoughONE80ESSEX will become famous soon enoughONE80ESSEX will become famous soon enough
MB's 17 X 9.5 +15 with 215/40's all around
ONE80ESSEX is offline   Reply With Quote
Old 02-05-2009, 12:58 PM   #3084
kalypso123
(ノಠ益ಠ)ノ彡
gotta love the weapons...
Old 02-05-2009, 01:14 PM   #3085
Ofc. Dangle
Ofc. Dangle's Avatar
Ofc. Dangle is an unknown quantity at this point
Phil I saw the pics of your car on myspace. Looking fresh with the green rainbow vinyl.
BTW Kalypso those are Battles.
Ofc. Dangle is offline   Reply With Quote
Old 02-05-2009, 07:19 PM   #3086
viperbite
viperbite is on a distinguished road
figure id post mine up since i got tires.
1995 mustang cobra R wheels
bf goodrich 255 40 17 tires
megan coilovers, rucas, rear toe, tein tension rods.
viperbite is offline   Reply With Quote
Old 02-06-2009, 07:05 AM   #3087
TheRonTom31
The front in the first picture looks ok. The back needs to come down a lot more however
Old 02-06-2009, 08:14 AM   #3088
SoSideways
SoSideways's Avatar
Front and rear both need to come down, and once they do, I don't think the wheels will be "fitment whore" status due to the huge sidewalls and width of tires.
Old 02-06-2009, 11:44 AM   #3089
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
very simple. looks great. there must be a spacer on there though.
Left hand drive 240sx's ARE NOT SILVIAS.
Rapier46 is offline   Reply With Quote
Old 02-06-2009, 01:16 PM   #3090
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
Looks GREAT!! Idk what others are talking about. Your wheels fit flush with the body. People these days are running over flush wheels and cambering the piss out of them to bring them back in. I like the stance. Good job!
scottie is offline   Reply With Quote
