11-02-2012, 12:29 PM | #1 |
FS: 1992 240sx Hatchback / New SR20DET + Spares
Clean title, located in Memphis. Passes emissions and inspection without issue. Solid car.
$3099 for everything! $2899 for just the car! Engine SR20DET engine/trans Fresh build with 2000 miles New rings, new rod bearings, new main bearings OEM Nissan gaskets everywhere OEM t25 turbo, fresh build with 3000 miles OEM computer and tune 2.5" stainless downpipe with oxygen sensor and Y-pipe dump / bolt-on block off plate OEM 240sx exhaust from catalytic converter back OEM 240sx muffler New OEM o2 sensor Test pipe and OEM catalytic converter (passes emissions) 2.25" mandrel bent charge piping 24x12x3" bar and plate intercooler AEM Air filter Nismo adjustable fpr 300zx fuel filter Walbro 255lph fuel pump Spec stage 2 clutch OEM flywheel Welded differential CX Racing radiator / OEM fan 944 turbo recirculating blow off valve Runs like its brand new Chassis Radio removed, gauge holder in its place Oil pressure gauge Greddy profec B boost controller Megan rear swaybar Eibach sportline springs OEM front swaybar OEM shocks (good condition) Kumho ecsta in 155/50/15's with 70% tread OEM steel wheels Two OEM hubcaps New tie rod balljoints New tie rod boots New windshield New rear brake pads Carpet pulled Porsche 944 driver's floor mat Rear seats pulled Complete OEM spare tire kit with good tire Spares KA Transmission with 10k miles on fresh build Sr20det Block, Pistons, Rods, Crank, Oil pan/pickup/tray Complete head minus valve cover, fuel rail and throttle body Various OEM SR20 gaskets/seals All fasteners OEM KA computer OEM SR20DET computer Intake manifold with IACV New lower control arm balljoints Rear seatbelts Starter Working a/c compressor Working condenser A/c lines Driver's front turn signal $3099 for everything! $2899 for just the car! Spares!!! $3099 for everything! $2899 for just the car! Last edited by Shitfaced; 12-06-2012 at 12:23 PM.. |
11-06-2012, 05:31 PM | #4 |
drift, redtop, s13, spares, sr20det |
