Old 05-12-2019, 11:48 PM   #1
sr vegas 240
sr vegas 240 is an unknown quantity at this point
Where to install oil pressure sensor
Hi everyone I am in the process of installing innovate oil pressure gauge and im in bit of a confusion. Its built sr20 I have I have ebay remote oil filter housing with plate. The innovate sensor only fits the housing which reads only pressure before the filter. So I just got a tomei oil block hoping it would fit the sensor but it doesn't. Sensor is 1/8-27npt tomei block is for factory sensor 1/8-28pt. So before i hack up my tomei and retread it should I leave the sensor in the remote housing. The only reason I'm asking car is not running yet so just cranking it slowly builds oil pressure to 45-48psi seems bit higher just cranking. Any help would be appreciated. Hoping to crank the car this month been down for almost 2 years
sr vegas 240 is offline   Reply With Quote
Old 05-13-2019, 08:56 AM   #2
jedi03
I'm not an expert on it but anywhere in line with the oil system should work...if you want to use the stock location either rethread it or get an adapter
Old 05-13-2019, 09:43 AM   #3
sr vegas 240
Yea stock location is post filter so I just purchased adapter for it
Old 12-26-2019, 10:31 AM   #4
JDM180SX92
JDM180SX92's Avatar
JDM180SX92 is an unknown quantity at this point
I really dont have a reply, mainly a question regarding this topic. I am currently putting new gauges on my 1992 180sx (oil temp, oil pressure, water temp and boost). My question would be, if i use the factory sensor location for the aftermarket one, would it throw a dash light? Also, where would I be able to put oil temp sensor?
JDM180SX92 is offline   Reply With Quote
Old 12-26-2019, 11:20 AM   #5
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
No dash lights wouldd come on. It's 1/8bspt so a defi sensor would work. Temp sensor would go into the oilpan. You need an aftermarket pan though.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille
e30gangsta is offline   Reply With Quote
Old 12-27-2019, 12:07 PM   #6
JDM180SX92
JDM180SX92's Avatar
I have all Auto Meter Gauges for these. I really do appreciate the info. Thanks
Old 12-27-2019, 08:48 PM   #7
e30gangsta
So you would need a 1/8 bspt adapter to 1/8 npt to make it work.
