Old 06-04-2019, 06:51 PM   #1
Hondamatic
Hondamatic's Avatar
Hondamatic will become famous soon enoughHondamatic will become famous soon enoughHondamatic will become famous soon enoughHondamatic will become famous soon enough
FS 2001 Lexus LS430 $8000
Super clean. 122,000 miles.
$8000
https://i.ibb.co/BgjczDV/IMG-0459.jpg
https://i.ibb.co/F0Pjq8s/IMG-0469.jpg
https://i.ibb.co/Km9mD0r/IMG-0465.jpg
https://i.ibb.co/ZS8jB4z/IMG-0472.jpg
https://i.ibb.co/tZ1SMGv/IMG-0466.jpg
https://i.ibb.co/sm81R5F/IMG-0467.jpg
Located in Indianapolis, north side.
I've owned it for a little over a year. 99% of it's life it was owned by an older gentleman in Florida.
The past 12 months the following has been replaced...
Timing belt / water pump
Radiator
Battery
Drive belt
Air filter
Cabin filter
Spark plugs
Transmission flushed and new filter
New synthetic diff fluid
Rotors pads calipers and hoses all around
New brake booster and master cylinder
Front and rear sway bar end links
Polyurethane front and rear sway bar bushings
Daizen tuning polyurethane steering rack bushings
Both inner and outer tie rods
Both front lower ball joints
25mm bolt on spacer up front
Parts Shop Max adjustable rear spacers
BC RACING coilovers with swift springs
Youzealand SS kit in rear
Amistad Grace wheels 19x8.5 19x9.5
New Federal Evoluzione tires all around
New rear deck 8 inch subwoofer
Paint polish/correction by Pristine Auto Spa
Headlights covered with Xpel film
All interior lights and puddle lights replaced with LED units
6k HID and 6k LED fog lights
Contact: [email protected] or PM on here
Thanks!
Hondamatic is offline   Reply With Quote
Old 06-05-2019, 02:25 PM   #2
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
is this the UL model? its hard to read the badge on the fender. excellent deal either way. i was looking at these prior to buying my IS300 and they were all 10k+.
jumpman2334 is offline   Reply With Quote
Old 06-05-2019, 05:29 PM   #3
Hondamatic
Hondamatic's Avatar
It's the Sport / Euro package. I believe it has thicker swaybars and stiffer bushings.
Old 06-06-2019, 08:50 PM   #4
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
emceetickles bumps
Drift Indy
Edgar is offline   Reply With Quote
