Old 10-10-2020, 04:18 PM   #1
jdmmatt
jdmmatt is an unknown quantity at this point
Strange electrical problems
Hello, brand new to forum, and s chassis's!
I have a ka-t s14 on a aem v1 ecu. if the ecu is in a weird position, the afr will read that it's leaning out. Same thing happens with the wiper stalk, when activated the car runs like shit. Any ideas if its, battery related or if I need a new harness?
jdmmatt is offline   Reply With Quote
Old 10-10-2020, 04:45 PM   #2
S14rebuild
Sounds like a harness/ground issue. Load test ur battery, check for draws and make sure ur grounds are clean, and bolted down tight. Battery to chassis, and motor to chassis
Btw welcome. We have a tech section or small question thread for such topics...
Old 10-10-2020, 08:11 PM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Disconnect the grounds, clean the wire ends and chassis with a wire brush, or wire wheel on a drill if corroded, then reconnect the grounds
GL
zombiewolf513 is offline   Reply With Quote
