Old 02-01-2020, 02:05 PM   #1
ultimohero
ultimohero is an unknown quantity at this point
mazworx block breather plug
I just finished assembly on my block and then the machine shop told me they forgot to put a part back in my block. It's the rear crankcase vent tube. FML. There's no way to get that back into the block without removing the head again.
mazworx sells a block off plug for it. I asked them how it worked and they said as long as you have good ventilation, it's fine to run. Has anyone ran one of these plugs or have any suggestion for me?
ultimohero is offline   Reply With Quote
Old 02-01-2020, 03:34 PM   #2
S14rebuild
I ran one before, never had any issues. Just a little rtv on the orings n tap it in.
Old 02-01-2020, 05:07 PM   #3
Kingtal0n
Kingtal0n's Avatar
Any picture, I'm having trouble remembering what this part is and does.
Rear vent tube... hmmmm ???
Old 02-01-2020, 05:10 PM   #4
ultimohero
Thanks that's what I needed to hear. I have a redtop btw. I'm gonna add another vent to the valve cover to run to the catch can.
Old 02-01-2020, 05:30 PM   #5
ultimohero
It's the one under the exhaust manifold on the sr20det.
Old 02-01-2020, 05:31 PM   #6
ultimohero
ultimohero is online now Add to ultimohero's Reputation Report Post
Old 02-03-2020, 10:07 PM   #7
Kingtal0n
Kingtal0n's Avatar
Errr... you mean the oil pan return from the pseudo air/oil separator (black box) ?
Old 02-04-2020, 08:01 AM   #8
TheRealSy90
TheRealSy90's Avatar
So why doesn't the machine shop pay for new head studs and head gasket and fix their own mistake? Do it right the first time. If it's their fault they should fix it.
Such a good signature.
Old 02-04-2020, 11:39 AM   #9
ultimohero
I know they're not gonna do it. And it's their fault they didn't put it back on but I should have noticed it before assembly too.
Old 02-04-2020, 11:40 AM   #10
ultimohero
Correct. But I don't have the black box or anything. When I got mine it was already gone.
Old 02-05-2020, 09:44 AM   #11
jedi03
just tap it and thread your own fitting on...its inconvenient but not impossible to do w/head on...
Old 02-05-2020, 09:48 AM   #12
ultimohero
Actually I cut a "v" from the original fitting and got it to squeeze past the head on an angle. I grey rtv the hell out of it. And hopefully it will work.
Old 02-06-2020, 07:56 AM   #13
jedi03
that should work! I usually do a "ten pound test" and make sure it doesn't move with a little force...not to much tho lol
Old 02-06-2020, 08:00 AM   #14
ultimohero
I let it sit for a couple of days. I'm gonna go give it a little wiggle in a few minutes. I think it's good. I need it to be otherwise I'm gonna be tapping it. I do not want to take the head off again.
Old 02-06-2020, 08:31 AM   #15
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
You don't need to remove the head
Just tap the OEM fitting back into place, even with a smidge of sillicone to keep it 'secure'
Old 02-06-2020, 08:54 AM   #16
ultimohero
The issue was the fitting was too tall. I couldn't get it past the head. So I ended up trimming it some
