10-20-2009, 10:29 AM | #1 |
s13 shakes during idle in low rpms?!?!?!
i have a 1992 s13 fb
during idle my car will shake?.. nothing violent but a very noticable shake everyone who rides in my car comments about it and after driving around town i will start to get a head ache what makes this weird is its only during idle/low rpms while driving it smooths out and feels normal it shakes up to 1400rpm then goes smooth i have surched this problem and heard everything from sparks/misfire to exhaust clog..but to no avail nothing fixed it please help thanks ALOT!!!!! |
10-20-2009, 11:22 AM | #3 |
I had the same problem on my hatch one of the cylinders was misfiring check your distributor/replace or check sparks to see which one is misfiring. You should change your motor mounts as well mine were done.
10-20-2009, 12:52 PM | #5 | |
check your injectors one could be malfunctioning as in leaking or clogged. the o rings could also be messed up.
disconnect each injector while idling. if you see no change in rpm drop then thats your culprit
10-20-2009, 01:04 PM | #6 |
Mine did that for a while on my first S13 when the O2 sensor died.... have you checked for codes?
------------------------- www.carolinanissans.com ------------------------- |
10-20-2009, 01:30 PM | #7 |
i just changed all the spark plugs 3days ago
i bought the car 3 months ago and if it was the motor mounts wouldnt it shake hard as i decelerate or apply throttle? ill check the injectors asap stuff i forgot to mention: i have been burning oil (exhaust smells bad).... seems like from cylinder #2 because when i changed the sparks #2 was all gunkie n built up on the threads and even on the bolt part too one time i added injector cleaner and gas tank cleaner into my gas tank and the problem went away for a week or so?? |
10-21-2009, 09:38 AM | #9 |
OK i think the problem might be a misfire because......... last night i had to give my friend a ride to work and it was shaking while i was waiting for them and as i left my place...butttttttt after i dropped em off i went on a little cruz around town and when i started coming home i noticed at a light the shaking went away and it was smooth again????
yes its gone for now but how do i keep it away this is the second time its came n gone? |
10-21-2009, 10:18 AM | #10 |
Banned from the Marketplace
sea foam this thing, check the mounts, spark plugs, timing if you can. and might wanna check the fuel pump see the condition of the pump/tank i have rust in my tank and thats what my car does and my car is a fresh swap and it had NO problems in my s14
10-21-2009, 05:53 PM | #11 | |||
by checking your injectors and changing them if needed lol
10-21-2009, 08:21 PM | #12 | |
idle, shake |
