09-25-2010, 03:00 PM | #1626 | |
Looks like an SRB Power Lip.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
09-25-2010, 09:06 PM | #1627 |
Negative.
That's Australian Spec OEM. Called Top Stage or "Luxury S14a lip." There is a recent thread about it on this very forum... I think it looks great and want one too, but good luck finding it. |
10-02-2010, 04:15 PM | #1629 |
i test fitted a 18x10 +50 offset BBS LM in the rear of my s14 with no tire the wheel clears all suspension components, the inner lip has about a pinky finger distance to coilover body as well as the threaded spring perch, i am going to try to get the seller, to allow me to test fit a tire & set it on the ground to see what clears & what does'nt etc.
I figured i'de ask if any one has fitted a high offset 10 inch wide rear & had any issues or suggestions |
10-02-2010, 04:26 PM | #1631 | |
Hech yes Mitch! Idaho showing some rubber! - Kyle |
10-02-2010, 04:27 PM | #1632 | |
Trader Rating: (163)
Feedback Score: 163 reviews
10-02-2010, 04:45 PM | #1633 | |
did you have the o.e. trailing arms? i kinda figured it would'nt work, without doing some extra work ;i assumed i would need a 10-15mm. spacer & longer studs to make it work, i guess i'll play it safe & source BBS LM 18x9 20offset all around thanks for the info |
10-02-2010, 05:33 PM | #1634 | |
10-03-2010, 07:00 PM | #1637 |
kept them for a little bit. They only rubbed the trailing arm when my suspension was really articulated, so like coming into a crappy drivewway. Therefore I didn't run spacers.
10-24-2010, 01:03 PM | #1643 |
Philosopher King
Does any one have the offsets on those?
I would consider running four of the fronts on my fastback if they have the right offset.
G O L D E N B E A R R E P U B L I C |
10-28-2010, 08:26 PM | #1645 |
update of my pics.
Volk GT-N Front 17x8 +10 with 235/40-17 stock fenders rolled Rear 17x9 +24 with 255/40-17 rolled with slight pull I know its not the MAXIMUM fit but I do what i can with the wheel size i have, haha.
11-17-2010, 01:11 PM | #1646 |
Alright so I need some help guys. I came into possession of some Volk Racing EMU wheels in 17x8 +35 / 17x9 +40. If I run 20mm spacers what size tire would you recommend for mainly street and about 5 autox days per year? s13 coupe.
What brand tire do you guys prefer the most? |
11-17-2010, 02:08 PM | #1649 |
Nitto NTO5, Hankook RS-3, Kumho XS, Dunlop Z1 Star Spec
Those are the only tires worth looking into. |
11-17-2010, 11:11 PM | #1650 |
I have Hankook RS-3's on my car. 255/40/17's on my 9" wide advans. I really like them, im putting down about 390whp - 37x tq or so with my ls1 and ive got pretty good traction considering.
Although, ive never had any of the other tires listed so i cant really compare them to the others. |
