10-26-2016, 09:17 AM | #1 |
S13 hatch, ca18det + goodies
Don't have the time or space to finish my project, so it needs to go.
13 fastback, clean title, non op, no back fees JDM ca18det New water pump & t-stat New timing belt kit New Stage 3 clutch New 750cc injectors New gt2860 New Custom oil/water ss lines with fire shield New Short ram intake and filter 255 fuel pump New Oil catch can New Custom boost controller 3" elbow back exhaust with skid plate New Greddy bov Custom big ass high mount inter cooler w/10" push fan New Aluminum radiator 14point7 diy wideband controller with LSU 4.9 sensor All wired to a Microsquirt ecu utilizing ford edis4 ignition New p/s lines, rubber & custom ss high pressure line Solid motor, trans, and steering bushings Tein coilovers 180sx center garnish 180sx 5 bolt lsd 17x9 str wheels w/ok tires New wheel studs 30mm front over fenders Bride rep seat with authentic bride rails Nrg short hub with quick release Grant wood wheel New battery I have all the interior pieces but not all installed, everything is there under the dash as well. Moon roof latch is broken. Gas door & hatch lever works. Motor/trans have no leaks. Motor runs but needs to be tuned. Pm me for more details or questions. Located in Oceanside, CA, 92056 $4000 https://vimeo.com/189005652 |
