07-24-2020, 11:50 PM | #1 |
Who can build a custom chassis harness?
So...I tubbed my car and planned on relocating my fuse box to the glovebox, or somewhere in the car. Unfortunately, I have not been able to find anyone locally (Hawaii) who is willing to rebuild my chassis harness, and I am unable to do so myself, so I need your help, Zilvia. Basically, I'd like everything cruise control related removed, and the wiring for the headlights/signals extended. I'm also running the JDM digital climate control, so I believe some features need to be tied into the harness as well. This is one of the hardest and last hurdles for me to move forward with my build, so any help is appreciated.
07-25-2020, 01:07 AM | #2 |
That is a complex project in itself... I?ve been over my entire chassis harness, took months.
Things I learnt: There are so many interconnected systems, that you will need to be able to really understand the FSM electrical section, which is probably the bulk of the whole manual. There are many proprietary plugs and pinouts, and the FSM has already documented all this and made good design decisions. I removed 90% of my wiring and it?s external wrapping, and what I found underneath was excellent quality wires in very good condition. Most of this was done in place. In reviewing the FSM and requirements, namely, - bigger fuel pump wires - proper speaker wires - fuel pump cut kill switch and extra relay - immobiliser stuff - some ecu wiring for my haltech - probably other things... I researched and experimented to ensure all things I wanted to do could be done, e.g. central locking etc. I made all my changes, and with each one tested. Not doing the next until each piece of work was tested. Then when it was all done, more testing. A lot of testing as I got stuff wrong... Then I got a bunch of conduit and a shit ton of felt harness wrapping tape, velcro strapping and cable ties, including those funky push mount ones. Wrapped it all up and secured it. Then tested. The scope of this kind of project is large, and it?s scope is a lot more than say an engine harness, while that is in itself complex, its scope is well defined. Sent from my iPad using Tapatalk |
07-27-2020, 09:00 AM | #3 |
You'd need to provide some more information, hatch or coupe, power windows (Probably, since you have Cruise Control), what front end, etc etc. I've done quite a few tucks over the years, 1 or 2 bare-bones race chassis harnesses, but not a replacement street harness.
Building a custom chassis harness isn't an issue in itself; its retaining features since in a PnP fashion without leaving pigtails for a customer to splice on the old connectors. DCC would be a problem unless the person making it for you has all the components for testing. I've seen a lot of folks ask you to ship them your old chassis harness to salvage plugs while others convert to something modern like Deutsch or Weatherpack with a pigtail that need to be spliced on in place of the old connector for the end component. Luckily, most of the OEM chassis connectors are available still with a good bit of searching but unless buying in bulk, it becomes incredibly expensive...quick. |
07-27-2020, 08:33 PM | #4 | |
07-28-2020, 04:51 AM | #7 | |
08-05-2020, 10:21 AM | #8 |
First thing you need is the factory service manual for your year, and this is in case you misMatch wiring or have to depin and repin.
From my experience I ended up shortening wiring never extending, and that’s that I moved the entire fuse box on my s14 to where my airbag was on the passenger side dash. |
08-27-2020, 09:44 PM | #11 |
Dude ive done full harnesses on 5 cars now. Get your head in an FSM wiring diagram, make your own diagram for each system you need, then build it. Unless you want me to make you one then i need your harnesses, 6 months and $5000+paypal fees
If youre just trying to move the fuse box for the tubs, i figured out a neat little tuck into the corner behind the headlight. You can mount it below the battery tray if you make a water shroud for it. You remove the bracket for the fuse box. Cut a 2" hole behind the battery tray just above the frame rail and use a headlight gusset to protect the wires youll run through it. There's only a few wires that need to be extended: -The power for the fuse box can be routed with 8 gauge wire to the starter. -The power from the battery will wire directly to the starter. -The alternator wires from the fuse box can be extended to the alt. -the grey and brown chassis harness to engine harness connectors. -The speed sensor wires (2 wires) i lost the pictures a while ago, but some people have made youtube videos on how to do it. |
08-29-2020, 10:35 AM | #12 | |
08-29-2020, 10:46 AM | #13 | |
08-29-2020, 11:22 AM | #14 |
I did mine on my 97 s14... first time tackling a custom harness. Moved my fuse box to behing the glove box, deleted all unused wires/relays/fuses. Repinded everything to weather pack connectors and heat resistant braided loom. Came out super nice. And about 5-7hrs of true work. I wouldnt say im an electrical genius or guru. But have 15yrs ase master tech. Under my belt. I would say anyone that can read and understand a wiring diagram can tackle the job. Learn to soder, crimp terminal ends and fi d a good source for parts(amazon) and its easily doable over a long weekend. Just draw/write out what u want and what wires, buy everything in advance and plan for extras...u can do it!
08-29-2020, 02:57 PM | #16 | |
Can't spell solder... |
08-31-2020, 08:53 AM | #18 |
I relocated mine to the truck where the factory Jack mounts... Ot was a painstaking and arduous task. Don’t want to do it again. However, it is easily accessible and out of the way.
08-31-2020, 01:21 PM | #19 |
I could build you a brand new one... I just don't want to :devil:
08-31-2020, 11:45 PM | #20 |
09-01-2020, 03:57 PM | #22 |
I just got done pulling my harness as well. Planning on putting fuse boxes in glove box and reroute the wires as needed. Goal is to have just the wires to the headlights and horn going to the front and everything else would be cleaned up. I would probably at some point make my own custom wire harness but would like to be able to source all the connectors needed first.
Sent from my Pixel 4 XL using Tapatalk |
09-02-2020, 09:05 AM | #23 |
Concentric twisting. Most high end harnesses and industrial cabling is made this way. I've tried to wrap my head around it, even attempted it a few times without success; I just can't make it work and have never really needed it either.
I've love to drop the coin on HarnWare or RapidHarness but I'm not at that level yet. |
09-02-2020, 09:17 AM | #24 | |
Multiply that by how many are in the car (just end components) and you can see why most people making universal chassis harnesses either have you splice on your original connector or convert over to a newer Weatherpack/Deutsch and the like. I'm not being a dream killer, just letting you know it's a big endeavor. |
09-02-2020, 09:22 AM | #25 | |
https://connectorexperts.com/ag-1859243-nissan.html Sent from my Pixel 4 XL using Tapatalk |
09-02-2020, 09:54 AM | #26 | |
Another hurdle is any vendor associated with ASAP Semiconductor (a good 75% of the US-based companies I've found) will not sell to consumers directly, you HAVE to be a business; ya know..non-public domain name, email, business license, etc etc. They will ask you to verify. |
09-02-2020, 10:00 AM | #27 | |
