Old 06-05-2019, 04:24 PM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
Exclamation TONS OF RACE CAR PARTS!!!!! Tial-Aeromotive-Precision-PROEFI-RacePak-ARE-Voltex-CP...
HUGE PRICE DROP ON ALL PARTS
So as my vehicle and myself progress, it unfortunately requires things to change over time. I'm adding a lot of my current parts up. They are already removed from the car and will not be getting anymore hours put on them.
- Everything was on the vehicle and used for 2 seasons (11 Events Total)
- Everything is in Perfect Working Order
TF-Works Ceramic Coated Custom SR-VE Dual Plenum Intake Manifold w/ Fuel Rail (no injectors)
- Dual intake plenum design
- Individual runner gasket design
- Dual Plenum Explained: A dual plenum allows the air to be calmed down in the first plenum and then move into the second plenum evenly, thus allowing all cylinders to get an equal amount of airflow. Most inline engines tend to get less air in the rear cylinders and this helps even it out. In the end, you get a lower chance of leaning out the last cylinder and you potentially get more power.
- NEW PRICE - $1,300
Billet 90mm Throttle Body
- NEW PRICE - $200
TF-Works Ceramic Coated SR VE Twin Scroll Dual Wastegate Exhaust Manifold
- Reason: Going to a V-Band connection with a large single wastegate
- NEW PRICE - $1,050
Precision 5862 Turbo Twin Scroll .84A/R Ceramic Coated
- Reason: Going with a large V-Band style turbo
- Price: $1,250
RacePak IQ3 Data Logger
- 250-DS-IQ3LD
- Includes GPS module
- $1,150
ProEFI Color CAN Display (non-logger)
- $350
Spa Design Dual Gauge (Boost/EGT)
- Comes with sensors
- $200
Spa Design Dual Gauge (Liquid Temp/Liquid Temp)
- $200
Spa Design Dual Gauge (Trans Temp/Rear End Temp)
- $200
Voltex Carbon Diffuser
- had 2 small cracks, which were repaired professionally by a shop in Illinois
- $400
WedsSport SA55M
- 18x9 + 20 and 18x10 +18 (5x114.3)
- WedsSport Center Caps
- WedsSport Valve Stems
- BRAND NEW...never had tires on them and have never been mounted on a car.
- Retail= $2,178 + Shipping
- Asking= $1,400
ARE Universal Remote Oil Filter Block
- $100
CP Pistons SR20VE-T 9.0:1 Compression
- 89mm
- $350
SuperTech P11 +2mm Intake Valves
- 5 Angle Valve Job
- $175
Supertech P11 +1mm Exhaust Valves
- 5 Angle Valve Job
- $175
Hydraulic Hand Brake
- Wilwood Master Cylinder
- Reservoir not included
- $80
R.J.S. Racing Equipment 5-Point Harness (Pink)
- BRAND NEW!
- Cam Lock
- $105
350z Doors
- $200
350z Door Panels
- $100
350z Master Cylinder
- $50
350z Brake Booster
- $50
350z Front Upper Arms
- $50
350z Front Lower Control Arms
- Have SPL Bushings (need a single replacement bushing spacers)
- $75
350z Dust Sheilds
- $40
350z Drivers Side Floor Mat
- $25
350z Drivers Side Door Sil
- $20
350z Wheel Speed Sensors
- $20
SR20DET Chain Tensioner
- $40
SR20DET Upper Oil Pan
- $35
SR20DET NEW Oil Pump gears and Cover
- $30
SR20DET Oil Block
- $15
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 06-05-2019, 04:50 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
are you parting out your z33 or something happened?
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 06-05-2019, 04:58 PM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
oh look at all these things I need!!!
Old 06-05-2019, 05:35 PM   #4
Imarvin240
Trader Rating: (18)
Nah, just changing things up a bit. Bigger turbo for the upgraded engine and switching to all motec. Should be done with the change in the coming months.
Old 06-10-2019, 10:23 AM   #5
Imarvin240
Trader Rating: (18)
Took money off all parts. Total combined price drops totaled over $1,600. These are great deals guys!
Old 06-11-2019, 11:24 PM   #6
SidewayzAsFck
SidewayzAsFck can only hope to improve
How much do the rims weigh each? Any pics with them mounted?
SidewayzAsFck is offline   Reply With Quote
Old 06-12-2019, 03:13 PM   #7
brndck
brndck's Avatar
Originally Posted by Imarvin240 View Post
WedsSport SA55M
reading is awesome.
Old 06-19-2019, 05:49 AM   #8
Imarvin240
Trader Rating: (18)
Bumping it up
Old 06-20-2019, 07:20 PM   #9
Imarvin240
Trader Rating: (18)
guys...COME ON!
Old 06-25-2019, 10:01 AM   #10
Imarvin240
Trader Rating: (18)
some parts sold...buy the rest...THANK YOU!
Old 06-25-2019, 12:07 PM   #11
TheRealSy90
TheRealSy90's Avatar
Metal or plastic screw IACV?
Such a good signature.
Old 07-15-2019, 06:58 PM   #12
Imarvin240
Trader Rating: (18)
BUMP! Take it away!
Old 08-01-2019, 12:22 PM   #13
Imarvin240
Trader Rating: (18)
Bumpity bump!
Old 08-15-2019, 06:04 PM   #14
Imarvin240
Trader Rating: (18)
Bumping it down the road!
Old 08-16-2019, 04:26 AM   #15
clever240sx
clever240sx is making a name for him/her selfclever240sx is making a name for him/her self
Pm sent!
Msglength
clever240sx is offline   Reply With Quote
Old 08-20-2019, 03:47 PM   #16
Imarvin240
Trader Rating: (18)
Some things sold...let's get more of this stuff out of my way!
Old 08-27-2019, 04:17 AM   #17
spud240
spud240 is an unknown quantity at this point
Pm sent on exhaust valves.
spud240 is offline   Reply With Quote
Old 08-27-2019, 04:29 AM   #18
1993fdrx7
Trader Rating: (32)
1993fdrx7 is an unknown quantity at this point
Feedback Score: 32 reviews
handbrake still available?
1993fdrx7 is offline   Reply With Quote
Old 09-03-2019, 12:20 PM   #19
Imarvin240
Trader Rating: (18)
some more parts gone and some more to go!
Old 09-28-2019, 10:03 PM   #20
jvladamir
jvladamir's Avatar
jvladamir is an unknown quantity at this point
PM sent on hydro brake
recovering from the wall....
Augusta, GA 706 832 4273
jvladamir is offline   Reply With Quote
Old 10-09-2019, 08:36 AM   #21
Imarvin240
Trader Rating: (18)
Bumping again!!!
Old 10-09-2019, 09:10 AM   #22
RalliartRsX
Trader Rating: (32)
Matt
Still got the IACV??
Old 10-17-2019, 04:58 PM   #23
Imarvin240
Trader Rating: (18)
Originally Posted by RalliartRsX View Post
Matt
Nah, that's gone.
