Old 03-12-2019, 07:26 AM   #1
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
SR20 hates Cold Starts
My Sr20 hates starting in the cold. its fully built and utilizes an AEM V2 Ecu. the wideband broke a long time ago and it does not have an IACV.
Do you guys think that adding in the wideband and a Intake air temp sensor will help the ECU read the cold air to adjust so it will start. it takes 20 mins to start the engine and i have to continuously keep starting it.
JohnnyDrfiter22 is offline   Reply With Quote
Old 03-12-2019, 07:59 AM   #2
jedi03
you will still need to program it to re-add those parts...y don't you bump up the idle in the aem til temp reaches a certain point? I'm not super familiar with tuning software but i imagine it should be do-able...
Old 03-12-2019, 08:25 AM   #3
JohnnyDrfiter22
The idle is bumped up. So I dont know what else to do
Old 03-12-2019, 10:13 AM   #4
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
There is a wire from the ignition switch to ECU pin 34 that tells the ECU the starter is engaged, which puts the ECU in startup mode. Check the fuse for this wire.
OnTheChip is offline   Reply With Quote
Old 03-12-2019, 11:29 AM   #5
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
You need to speak to your tuner, and have him go over the cold start enrichment table. There's no reason why he shouldn't be able to get it to start easier.
e30gangsta is offline   Reply With Quote
