Old 05-20-2019, 02:22 PM   #1
Reyes_
Reyes_'s Avatar
Reyes_ is an unknown quantity at this point
s13 sr20det stall when warm issue!
ok so long story short, car ran perfect until i let it sit for a week, car was covered..
after sitting for a week i go to start car let it warm up take it out around the block driving normal, then it stalls out randomly and i tried starting it, cranking and getting fuel and spark and no start. i have to let the car cool down before i can start it again..boost,afr,engine temp look normal, no boost leaks, changed out cts and checked to see if maf has a change to idle when i unplug it and it does so that means maf is working. any recommendations on what it can be? or suggestions?
specs
red top sr20det 62 ecu
all stock except for
fmic
hks bov
isr fpr
tomei srm7960 turbo
tomei manifold
full 3 in straight pipe
and no i hardly drive car as it is not tuned yet running stock ecu, car always ran perfect when i drove it around
link on the bottom to see video of issue
https://youtu.be/LsULhE-vtOQ
Reyes_ is offline   Reply With Quote
Old 05-20-2019, 02:22 PM   #2
Reyes_
Reyes_'s Avatar
uploaded video twice my bad guys lol
Old 05-21-2019, 12:49 PM   #3
jedi03
check grounds and fuses, gfs car had issue where main fuse was blown but when cold the fuse would make contact then when hot would die like that...also check fuel pressure, ecu...sounds like something is expanding enough to keep car from going...also clean fuel filter
Old 05-22-2019, 07:36 AM   #4
Kingtal0n
Kingtal0n's Avatar
All the videos shows is sr20 idle lean.
Either it has a vacuum leak around the maf or a bad O2 sensor
-unplug the O2 sensor
-pressure test the plumbing from compressor to engine to 20psi of pressure
or a maintenance issue i.e.
-clogged/bad injectors
-bad tps/cts/maf
-bad pcv plumbing
or a maf placement issue involving the turbo (can't see the turbo in the pic or plumbing so guess)
i.e. maf is too close to the turbo or something
Old 05-23-2019, 08:02 PM   #5
Reyes_
Reyes_'s Avatar
update
replaced cts again
checked for vacuum leaks looks good
checked for loose grounds
checked spark plugs
took off turbo timer
checked to see if tps is getting correct voltage and yes 5
checked o2 sensor and it’s damaged & replaced with a working one
it did seem alittle better and took longer for it to stall out..
car is still stalling when at idle after 7 mins
when reving it temps bounces also rpm tach after finish revin it bounces down to 0
also checked all fuses and looks good
help plz...
also will be checking iacv?... dont think that it can be that maybe but
Old 05-23-2019, 08:03 PM   #6
Reyes_
Reyes_'s Avatar
will check w compression plumbing idea soon and will maf placement seems fine and accurate to where it should
Old 05-23-2019, 08:05 PM   #7
Reyes_
Reyes_'s Avatar
-bad tps/cts/maf
-bad pcv plumbing
excuse all the excess vacuum lines, was mocking up
Old 05-27-2019, 12:12 PM   #8
Reyes_
Reyes_'s Avatar
car is running perfect guys! replaced o2 sensor w oem one and disconnected battery terminals and ecu then repluged and runs perfect, thanks guys
