Old 07-30-2019, 07:58 PM   #1
Speed Junkie
Speed Junkie is a well-known jackass
S14 OEM Manual Parts and More (Mine's, Blitz, Wiring Specialties & More)
All prices are negotiable. I will ship these but local pickup is welcome.
This is an infinity G20 throttle body that will fit SR20 engines. They have a second pulley for cruise control so They?re an easy way to retain cruise control on SR20-swapped 240s. The throttle body diameter is slightly larger than the SR20DET throttle body which will give you a slight improvement in throttle response.
$80
New Wiring Specialties S14/S15 Knock Sensor Pro Harness
$12
Wiring Specialties SR20 MAF Modular Connector
This is new and never used as I ended up using a 300ZX MAF
$12
Mine?s S13 ECU for the CA18DET engines. It came with my 240 but I never installed the ECU before swapping to the SR. It has been opened but I don?t know if anything was changed on it. I took closeups with the motherboard removed but if you want more closeup photos I can do that. These go for 150-300 dollars on ebay but I just don?t know if anything was done to it so my loss your gain.
SOLD
Blitz blow off valve and a new aluminum flange that?s been sitting in storage. The valve works fine but it could use a good cleaning.
$100
Brand new Turbosmart 38mm aluminum adapter. It came with my Vee Port Pro BOV but I ended up using a different adapter.
$10
S14 240SX Kouki front left turn signal housing. This is a Circuit Sport clear turn signal housing (front driver side) for 97-98 240SX. It has some surface scratches that are hardly noticeable 5 feet away.
$25
S14 240SX control arms.
These are oem rear links that include:
Upper control arm
Rear toe link
Forward link
These came off a 98 240sx and are in good condition. One has some rust but after some sanding and repainting it would be fine.
$80
This is an OEM ECU that came off of a running factory manual 1998 240sx. It?s in perfect working condition.
$150
SOLD
This is the Wiring Specialties pro interface harness for a factory manual S14. Keep in mind that this will only work with a wiring specialties engine harness. Three unneeded wires were cut. One of them idle up signal but can?t remember the other two. The harness works fine without them.
$80
SOLD
Kouki S14 240SX driver side headlight. Some of the reflective film is pealing and one of the screw bosses is cracked (4th photo) but overall it?s ok. Will ship anywhere in the continental US.
$90
SOLD
S14 240SX Morimoto HID kit. This is a Morimoto HID kit from The Retrofit Source and comes with 3k H1 bulbs, relay and 35w Morimoto ballasts. This is for the Kouki (97-98) 240SX (H1 Bulb) so I?m not sure if it will fit earlier S14s. The Kouki headlights come factory with projectors so it worked great and had a sharp cutoff. This is a great kit with nothing missing and cost $150 when I bought it new. It?s been sitting in storage since mid 2017.
95$
SOLD
Speed Junkie is offline   Reply With Quote
Old 08-05-2019, 02:01 PM   #2
Speed Junkie
Bump to the top.
Old 08-07-2019, 06:30 PM   #3
Speed Junkie
Bump. New parts added!
Old 08-12-2019, 06:23 AM   #4
Speed Junkie
Bump to the top. ECU sold!
Old 08-15-2019, 09:57 AM   #5
Speed Junkie
Bump to the top.
Old 08-20-2019, 06:11 AM   #6
Speed Junkie
Bump to the top.
Old 08-23-2019, 10:56 AM   #7
Speed Junkie
Headlight sold! Bump to top.
Old 08-27-2019, 06:48 AM   #8
Speed Junkie
Bump to the top!
Old 08-30-2019, 11:39 AM   #9
Speed Junkie
Bump to the top.
Old 09-03-2019, 09:37 AM   #10
Speed Junkie
Bump to the top!
Old 09-18-2019, 09:06 AM   #11
Speed Junkie
Bump to the top!
Old 09-18-2019, 12:39 PM   #12
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Updated thread, moved sold items to bottom of OP and updated your HID kit. That's a great price for quality HID kit.
Old 09-19-2019, 05:55 AM   #13
Speed Junkie
I appreciate it!
Old 09-26-2019, 09:49 PM   #14
Swagless
Swagless has made poor choicesSwagless has made poor choicesSwagless has made poor choicesSwagless has made poor choicesSwagless has made poor choicesSwagless has made poor choicesSwagless has made poor choices
I’m down to buy the hid set up pm me !
Swagless is offline   Reply With Quote
Old 09-27-2019, 12:20 PM   #15
Speed Junkie
Just sent PM
Old 10-04-2019, 08:00 AM   #16
Speed Junkie
HID kit sold!
Old 10-11-2019, 08:25 AM   #17
Speed Junkie
The throttle body is back for sale (ebay buyer returned it because it didn't fit their TPS).
Old 11-05-2019, 07:27 AM   #18
Speed Junkie
Bump to the top.
Old 11-05-2019, 10:51 AM   #19
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Originally Posted by Speed Junkie View Post
HID kit sold!
Hahaha you're welcome
