Old 11-05-2024, 11:07 PM   #1
skvngr
skvngr is an unknown quantity at this point
KA Abandoned KA-T S14 Project Parts Sale
Stuff for sale. Willing to ship smaller items. Located in Orlando Area.
1) KA/SR Nismo Slave Cylinder, New, $150
2) Nismo KA/SR Colder Thermostat, New, $80
3) KA starter, barely used, $70
4)ISR KA Silicone hoses and clamps, $50
5)Ka24de 7-layer exhaust manifold gasket, lightly used, $10
6)KA Oem alternator and bracket, used, $90
7)S14 OEM G70 maf, used, $30
8)32005-21u1b oem reverse switch, new, $15
9)32136-U010A KA/SR transmission tail oil seal, new, $10
10) OEM KA/SR throw out bearing, new, $30
11) New oem Ka24de upper and lower intake manifold gaskets, $20
12) ISR Clutch Line,new, $30
13) ISR steering rack braided lines,new,$50
14) ISR high pressure steering line,new,$75
15)Chase Bays steering rack 14mm to 6an fittings, new, $25
16) 17342-79900 S14 Fueltank O-ring,new $15
17) New Oem KA24de Oil Filter $5
18) New ES poly steering rack bushings, $15
19) New Exedy clutch master cylinder, $20
20) New Oem flywheel bolts KA 7x, $14
21) New Oem Driveshaft nuts and bolts, $20
22) New Oem KA oil pump gear, $20
23) gktech shifter boot, new $5
24) New ARP KA Pressure plate bolts, $12
25) ISR muffler hangars 3x, $12
26) J-Replace Motor/trans mount set, new, $sold
27) KA-T Oil Feed/Drain Kit, new $120
28) S13 Brake Booster/Z32 BMC/Braided lines/valve/locker $200
29) S14 KA motor, will need rebuild, $350
30) s14 KA 5spd transmission, $375
31) s14 SR 5spd transmission, $425
32) Built KA Long block, $3600
33) Artec KA24de Turbo Manifold, new $950
34) Precision 6062 Gen 2 Dual BB T3 Vband .82AR Turbo, new $1500.
35) S14 Oem 2pc driveshaft no carrier bracket, $30
36) ISR 1pc driveshaft S14 KA/SR Non-ABS $350.
37)Tial BOV, used $sold
38) Competition Clutch White Bunny Clutch Kit w/ performance pressure plate 505 ft/lbs rating, new $500.
39) NGK S13 KA24DE Spark plugs wires, $30
40) S14 KA TPS sensor, $40
41) KA transmission dust plate between engine & trans. $50
skvngr is offline   Reply With Quote
Old 11-05-2024, 11:37 PM   #2
240Zfunahollic
240Zfunahollic is an unknown quantity at this point
Sent you a pm.
http://zilvia.net/f/image.php?type=sigpic&userid=15347&dateline=123195  6786
Visit My Trader rating page
http://zilvia.net/f/traderratings.html?u=15347
240Zfunahollic is offline   Reply With Quote
Old 11-10-2024, 03:46 AM   #3
yung_matush
yung_matush is an unknown quantity at this point
4,5,7,9,11,12,13,14,17,19,20,21,22,24,28 would you split? i just need lines. Sending you PM with my number
yung_matush is offline   Reply With Quote
Old 11-10-2024, 07:59 PM   #4
coolsupermanfly
coolsupermanfly is an unknown quantity at this point
Was the ka rebuilt by a shop?
coolsupermanfly is offline   Reply With Quote
Old 11-13-2024, 01:05 PM   #5
Cash
Cash's Avatar
Cash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond reputeCash has a reputation beyond repute
Send a message via AIM to Cash
I would like two products. Specific prices are either fixed or negotiable in some sense. And, are you capable of completing the bigger parts with local meetups?
Cash is offline   Reply With Quote
