04-05-2010, 01:28 AM | #1021 |
on the j30 diff people complain it acts like an open after moderate performance driving(because i guess it gets hot), well if you get those diff covers that hold more oil. does it act the same? or does it perform better?
https://www.linkedin.com/in/hassanbakar |
04-05-2010, 10:29 AM | #1023 |
is there a difference between a zenki s14 and kouki s14 wiring harness(stock for ka)
@UpshiftEngineering |
04-05-2010, 11:17 AM | #1025 |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
how do you gents properly secure ur tucked harness on the driver side...?
im not asking about pulling the fender section...im talking about that half foot where it comes out of the fire wall to the fender area... i was thinking of getting some U shaped metal braces and screwing them on with self taping screws...and runnign the rest of the harness thru the fender frame area not just tucked along the side...thoughts?
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
04-05-2010, 11:42 AM | #1026 |
i've seen that done before but it's a lot of work and i think you have to extend the harness
i just moved it up and the part where it comes out from the well to the side i flattened the lip there and ziptied it up works pretty good |
04-05-2010, 12:03 PM | #1028 | |
it really depends on the style of the wheel and how much backspacing you have. your 16x8 could have no room behind it for bigger brakes to clear but at the same time ive got 17x8.5 +12 and 17x9.5 + 22 5zigens that i could fit f350 brakes behind just because of the style of the wheel. figure out your back spacing and how much room there is then youll be able to determine what will fit. another thing to take into consideration is the size of the rotor necessary for larger calipers to work properly
NO HANDS IN PANTS!! |
04-05-2010, 12:44 PM | #1030 |
No difference in ABS hubs, offset clearance will depend on brakes used and design of spokes, I had +36 offset 8.5's and they wouldn't clear 300zx front calipers without a spacer. However my 7.5 +44 cleared them ok. Depends on a lot of variables.
@MMyriad |
04-05-2010, 12:59 PM | #1032 |
ok hi im new to this so let see if i get it right.. i just got a s13 coupe and broke my front end off so i had to change it.. Ive seen alot of silvia around my house and i didnt want to be the same so i look around and saw some pics of a an s13 with an r32 front end my question is dose the r32 front end just bolt on or would i have to do more work... and if i would have to do more work dose anyone know some would do it.. thanks for your time and help...
04-05-2010, 01:27 PM | #1033 |
The R32 does not bolt on. The Skyline is physically wider then the 240SX.
Your fenders will not be flush with the doors, however someone does make a R32 conversion kit for the 240sx, I believe this would involve fiberglass fenders, hood, bumper and you can use R32 headlights. |
04-05-2010, 02:13 PM | #1035 | |
you should do a S14 Kouki Front end, looks sick!! |
04-05-2010, 06:03 PM | #1036 |
on a 97 ka what is the water line that is next to the oil filter pointing the same direction as it(to the strut tower)?? what does it go too?
04-05-2010, 11:03 PM | #1040 |
Question:
If I remove the HICAS vanes from the powersteering pump, does that still mean my rear axle is still "loose"?
"I'm a rage-aholic, I just can't live with rage-ahol!!!" |
04-06-2010, 11:22 AM | #1042 |
I have a question about the valve cover T Fitting thing. On my SR it has a threaded fitting the a vac line to a oil catch can and Im in the process of switching valve covers with my friend. I have a red one and im switching with his black one. His black one has the T fitting on it. The question is how can I get the threaded fitting on to the black valve cover to complete the valve cover swap? thank you for the help
04-06-2010, 05:36 PM | #1043 |
what connects to this (water Line)? i figure its for coolant. its a 97 ka. below intake mani, by starter/oilfilter.
04-06-2010, 06:19 PM | #1044 | ||
04-06-2010, 06:45 PM | #1045 |
04-06-2010, 07:11 PM | #1046 |
my heater core/return are elsewhere.........
04-06-2010, 09:09 PM | #1048 | |
And does anyone have this problem with their window, its my driver side. Goes down 2 inches and I hear the motor or whatever go errrrrrggghhh, and I let go of the switch, then I budge the window a little then it goes down like 4 inches, and the same sound comes again window won't move until I do the same process T_T I repeat the same steps if I wanna put the window all the way back up. Is the window off track or something? Can't be the motor right?
HI HATERS! from the left to the right |
