Old 07-14-2019, 12:19 AM   #1
seeko7
seeko7 is an unknown quantity at this point
S13 Headlights randomly go up and down individually
I just bought my S13 and it's an SR20DET swapped 1992 SE model with a few issues. Among them is the headlight issue... My lights will just pop up and down randomly while I'm driving, whether I mess with the switch or not. Could this be a bad switch, or something further?
Also, I'm new to modding and wiring is kinda intimidating to me. Where's a good place to start learning more about this so I can improve my knowedge and skills?
Thanks guys.
seeko7 is offline   Reply With Quote
Old 07-14-2019, 12:23 AM   #2
anthony_240
anthony_240's Avatar
anthony_240 is an unknown quantity at this point
Thanks guys.
You have a short, if I were you , pull out the switch, check for loose/ exposed wiring connections. Could be a bad switch, but start with looking for exposed wiring first
anthony_240 is offline   Reply With Quote
Old 07-14-2019, 12:29 AM   #3
seeko7
Thanks. Also, my cluster's speedometer and gas gauge both don't work. Does this have something to do with the SR swap? I've been reading around, and I feel like it does. I need to get in my dash and see how the wiring looks in it...
Old 07-15-2019, 08:01 AM   #4
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
If your car is lowered, check the wiring in the driver side wheel well. Probably rubbed through the harness.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 07-15-2019, 08:23 AM   #5
seeko7
Good advice. I'll check on this today.
Old 07-23-2019, 05:00 PM   #6
slider2828
slider2828's Avatar
Videos please..... sounds kind of cool
Turn and Burn!
Old 07-24-2019, 09:19 AM   #7
180sx_
180sx_'s Avatar
180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about180sx_ has a spectacular aura about
+1
Sent from my SM-G935F using Tapatalk
180sx_ is offline   Reply With Quote
Old 07-24-2019, 11:27 AM   #8
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
speedo isn't specifically sr20 related. its a sensor in the trans that sends a signal to the ecu. ecu sends the signal to the cluster
same with the fuel gauge. gauge sends a signal to the cluster. neither of these would be issues caused by a sr20 swap per se.
the FSM has a resistance test you can perform on the float for the fuel level gauge, gotta pull the fuel pump hanger out of the tank tho.
I believe the FSM has a diagnostics test for the speedo sensor too, iirc.
Old 07-24-2019, 12:25 PM   #9
KiDyNomiTe
KiDyNomiTe's Avatar
haha I thought everyone had gone through this once in their life??
Mine started off doing it maybe like once a week just going up and down. But at its worst even with the car off either one light would go up and down for a good minute, or they'd both do it in sequence. Quite funny to see.
PROCEED
Grip Gambler
