07-30-2019, 09:22 AM | #31 | |
Trader Rating: (130)
Feedback Score: 130 reviews
Yeah, but to add issues on top of issues, I’m using the PBM rear knuckle, https://store.partsshopmax.com/shop/...ct-description which requires you to swap ebrake assemblies from left to right side, so now the ebrake cable inserts from the top of the backing plate instead of the bottom of the backing plate. The only way I could possibly route the cables made them run like this, So no matter what bracket/mount plate you use, it was still far too long. For me, the z32 2+2 cables fit perfectly, line up perfectly, mount perfectly, they’re just way more expensive than the GKTech ones were. |
07-30-2019, 09:59 AM | #32 | |
Ah, ok makes sense with the set up you are using, mine follow a similar path (green line) but no where near that far back. Ill snap a pic later when i get home.
07-30-2019, 10:26 AM | #33 | |
Yeah the green line is a bit exaggerated, it’s probably closer to the blue line, but I didn’t like having it routed further towards the rear of the car at all. With the z32 2+2 cables, it follows the red line and is the perfect length. |
07-30-2019, 11:53 AM | #34 |
300zx brake swap e-brake setup
Hmm weird, They should work even with PBM Drop knuckles. Well it worked for me at least. I just installed them on mine two weeks ago. I had used that little gold bracket the lines come with to bolt part of the line where the original e brake mounted at and then bolt the end of the line to the gktech bracket.
I should probably take a pic when I get a chance Sent from my iPhone using Tapatalk
Instagram: Nismo_Lk |
07-30-2019, 01:34 PM | #35 | |
for me the 2+2 cables were the perfect fit |
