09-20-2010, 03:19 PM | #1 |
Cometic Gaskets at MVP Motorsports!!
Cometic offers a large variety of gaskets for your Nissan. Everything from Headgaskets, Valve Cover Sets, Intake Manifold Set, Exhaust Manifold Sets etc etc. Whatever you need whether it be KA, SR, RB or CA Cometic is sure to have what you need!!! S13 SR20DET Gasket Kit .045” MLS Head Gasket 87.5MM Bore .030” MLS Exhaust Gasket Intake Manifold Gasket Intake Valve Stem Seals Exhaust Valve Stem Seals T25 Turbo Flange Gasket Turbo Outlet Gasket Turbo Compressor Outlet Copper Eyebolt Washers (Medium) Copper Eyebolt Washers (Small) Turbo Oil Inlet Gasket Throttle Body Gasket Idle Air Control Gasket Sidemount Intercoller Gaskets Upper Injector O-Rings/CA Sensor O-Ring Lower Injector O-Rings Timing Chain Tensioner Gasket Intake Plenum Gasket S14 SR20DET Gasket Kit .045” MLS Head Gasket 87.5MM Bore Valve Cover Gasket .030” MLS Exhaust Gasket Turbo Inlet Flange Gasket Turbo Outlet Gasket Intake Manifold Gasket Intake Valve Stem Seals Exhaust Valve Stem Seals Turbo Compressor Outlet Throttle Body Gasket Idle Air Bypass Gasket Upper Fuel Injector O-Rings Lower Fuel Injector O-Rings Water Outlet Gasket Turbo Water Inlet/Outlet Washer Timing Chain Gasket Turbo Oil Inlet Line Washers Turbo Oil Drain 1991-94 KA24DE Gasket Set .040” MLS Head Gasket 90MM Bore Air Surge Gasket Intake Gasket With Plenum MLS Exhaust Manifold Gasket Outer Valve Cover Gasket Inner Valve Cover Gasket Intake/Exhaust Valve Stem Seals Water Outlet Gasket Thermostat Gasket Throttle Body Gasket 1995-98 KA24DE Gasket Set .040” MLS Head Gasket 90MM Bore MLS Exhaust Manifold Gasket Intake Gasket With Plenum Outer Valve Cover Gasket Inner Valve Cover Gasket Intake/Exhaust Valve Stem Seals Water Outlet Gasket Thermostat Gasket Throttle Body Gasket EGR Gasket Valve Cover Washers Valve Cover Grommets PM or post up with which headgasket or gasket set you are after to get your Zilvia.net special pricing!!!! Regards, Robert
940-683-8282 x20 Robert Del Angel CLICK HERE FOR OUR FACEBOOK PAGE!!! FOLLOW US ON TWITTER!!! Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!! |
10-05-2010, 05:43 PM | #9 |
MVP JUST RECEIVED A LARGE STOCKING ORDER OF COMETIC!! ORDER NOW AND SHIPS OUT SAME DAY!!!!
Regards, Robert
