Old 03-31-2019, 07:53 AM   #1
Dunsparth
Dunsparth is an unknown quantity at this point
Can not get intake manifold off ka24de
I can not get my intake manifold off, i have removed the fuel rail and from what i can count 10 bolts going into the block from the intake manifold i try to move it and the damn thing barely budges and will not break free as if its still being held on by something.
Here are some pictures of the top of the manifold
https://imgur.com/6RLEBnK
https://imgur.com/a/M6p24JF
Here are pictures under and thru the runners starting right to left.
https://imgur.com/a/XwxWZ8T
https://imgur.com/aFKLy3W
https://imgur.com/RBtAz92
https://imgur.com/DqPVKTm
https://imgur.com/a/MpllXzH
I belive from what research i have done these are all the bolts i have no idea why this thing is not budging off.
Dunsparth is offline   Reply With Quote
Old 03-31-2019, 01:15 PM   #2
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
There should be a supporting bracket that bolts to the block on one end and the plenum on the other. Did you take that off?
Tuners are big bullies
feito is offline   Reply With Quote
Old 03-31-2019, 07:59 PM   #3
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
I'm gonna go with egr tube
EnnEssEnnKAT is offline   Reply With Quote
Old 04-04-2019, 05:35 PM   #4
Dunsparth
I am trying to find exactly where this is at will it be under the plenum?
Old 04-05-2019, 07:54 AM   #5
lalo167
lalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the rough
There's 2 brackets under the plenum. Right around the oil filter area. One is a 3 bolt bracket and the other is only 2. Also mentioned above, make sure the EGR tube is disconnected.
lalo167 is offline   Reply With Quote
Old 04-05-2019, 09:01 PM   #6
Dunsparth
i disconnected the EGR by the 3 bolts and its kind of just dangling there but free
As for these bolts i take it they are the "hidden bolts" that i am now reading and finding out about do you have any suggestion of what would be the best way to get too these?
Old 04-07-2019, 02:25 PM   #7
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
I took the manifold apart, the top section off which made things easier if I remember correctly
andisan is offline   Reply With Quote
Old 04-07-2019, 09:12 PM   #8
Dunsparth
i ended up removing the top of the manifold as well and had to remove the studs i replaced those with bolts and did my deletes and put it all back together and everythings good to go now such a pain in the ass to get that damn thing off without pulling the motor tho since there are those hidden bolts.
