Old 07-02-2019, 11:02 PM   #1
rkd350z
rkd350z is an unknown quantity at this point
FS: C5Z06 2002 Silver, 149k miles, with NEW ENGINE & CLUTCH
Chassis has 149k
Engine / Clutch and flywheel has less than 1000miles (2 oil changes for break in)
Around 420whp with stock headers.
Engine build goal was to have reliability at high RPM operation and good mid range TQ.
Pass CA emission and clean title registered in CA.
Exterior: 7/10
Interior: 8/10
Engine: 10/10
C5 Z06
Blue printed engine rebuilt with all receipts
Engine machine and build
Improved racing Oil pan baffles
Lower pan gasket
New Flywheel bolts
Monster stage 2 clutch kit with light weight flywheel
New power steering hose
New serpentine belt
Pro balancer
Coolant temp sensor
Knock sensor
Knock sensor harness
Engine oil pressure sensor
Engine oil sensor connector
Crank position sensor connector
New denso spark plugs
Spark plug heat shields
GMPP spark plug wires
New 160 thermostat
Exhaust studs
Exhaust nuts
Port and polished 799 heads
Valve springs
Performance seats, seals, dual springs, retainers
Valve cover gasket
Fuel filter
Stainless steel braided teflon racing fuel line and swivel hose ends
Comp cam
Flipped intake mod with K&N intake
Setrab 625 oil cooler with lingenfelter performance sandwich plate
Dewitt radiator
Borla stinger exhaust
And many more...
Hotckis sway bars
Drm aluminum steering rack bushing
DRM spec Bilstein shocks
C4 ZR1 17x19.5, 17x11
NT555 G2 275/40/17F 315/35/17R
ARP wheel studs
Carbotech xp10, xp8 pads
Front brake cooling duct(3") spindle mounted (great for brake cooling)
Lowered on stock bolts
Corner balanced w 170lbs driver & 1/4 tank of gas
Sparco Evo driver seat
Mti racing seat rail
Hardbar harness bar
Cam lock 6pt harness
Vette works harness bottom Anchor
Momo sprint 350mm wheel
Nrg hub & adapter
12" Kicker subwoofer
5ch kenwood amp
Kenwood single din head unit
Aluminum interior door sill C5Z
C6 shift knob
swede shift boot
Aftermarket aluminum pedals and foot rest
passenger side mounted fire extinguisher
Fixed headlight
Aci rear spoiler
Front tow hook
Rear tow hitch receiver 1-1/4” (for towing tire trailer)
Trackspec Hood vents
Had this car since 2013 and garage kept it.
Clean title in hand, registered in CA till sep 2019 and will pass CA smog.
All service record in hand during my ownership, including new engine build receipt.
The car rips and handles awesome.
New engine has less than 1000 street miles.
asking $17,500 OBO
Text @ 818-3O7-3850 Andrew for more info!
more info below!:
https://www.corvetteforum.com/forums...nd-clutch.html
rkd350z is offline   Reply With Quote
Old 07-06-2019, 02:15 PM   #2
rkd350z
Corvette C5 Z06 2002 Silver, 149k miles, with NEW ENGINE & CLUTCH
Chassis has 149k
Located in 91011.
Exterior: 7/10
Interior: 8/10
Engine: 10/10
C5 Z06
Lower pan gasket
New Flywheel bolts
New serpentine belt
Pro balancer
Coolant temp sensor
Knock sensor
New 160 thermostat
Exhaust studs
Exhaust nuts
Valve springs
Valve cover gasket
Fuel filter
Comp cam
Dewitt radiator
And many more...
Hotckis sway bars
C4 ZR1 17x19.5, 17x11 wheels
ARP extended wheel studs
Quantum Front brake cooling duct(3") spindle mounted (great for brake cooling)
Corner balanced w 170lbs driver & 1/4 tank of gas @ Westend
Hardbar harness bar
NRG hub & adapter
5ch kenwood amp
C6 shift knob
swede shift boot
Fixed headlight
Aci rear spoiler
Front tow hook
asking $17,500 OBO
More pics on:
More pics on:
More pics on:
More pics on:
More pics on:
More pics on:
More pics on:
Old 09-05-2019, 03:28 PM   #3
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Merged your two threads.
Your images aren't showing up because your google images are probably private.
