11-12-2006, 12:20 PM | #91 |
The only electrical issue that I got that after I take the key out of the ignition sometimes the Temp gauge and the Ebrake light wont turn off. ohh yeah and I replaced my wiper motor with a USDM one and my wipers are backwards I gotta figure out how ot wire it up to make it work. lol
11-13-2006, 06:20 PM | #92 | |
my current problems are 1.the intermittent wipers won't work and when i turn off the wiper it just stops right where it is. 2.whenever i push the rear defrost button the brake lights come on. but the 3rd brake light doesn't work any other time. |
11-14-2006, 06:43 PM | #93 | |
yeah, i thought it was a short in the housing cause the wires were all melted and nasty from the pre-owner. so i picked up one from the junkyard..replaced it...and still blew the fuse..so im guessing it might be a bad ground somewhere in the wiring of the fuse box.
11-14-2006, 06:55 PM | #94 |
when i push my brakes, my day lights come on, dashlights, turn signals, and tail lights. Also at night when i have my lights on my tail lights are lit as if im pressing the brake, all the time. yay for 240s haha
11-20-2006, 11:10 PM | #95 |
Just recently, my gas gauge has started to act weird. I know gas gauge issues have been mentioned, but only for 95's, and I have a 1991. It reads fine until there's about 1/3 of a tank left, then it just dips down, down, down, until it's below E. I assume it's the sending unit in the tank, do I access it from the trunk? Are there any seals that I need to replace if I open it up from there? One other general question.. Does anyone have any good tips for cleaning up battery terminals? Mine are getting pretty nasty, and I want to do some maintenance.
11-22-2006, 09:53 AM | #96 |
drivers side seatbelt doesnt work sometimes, they only work when the key is in. no inside lights work except cluster and hud. when i press the button for the map light my seatbelt light comes on in the cluster. and my light on the cluster that says the doors are open is always on. lol alot of problems that need to be fixed.
11-22-2006, 10:08 AM | #97 |
Well with the new hatch I have a few:
1. Let off the gas, ebrake light comes on. 2. No gauge cluster lights 3. Pass. seatrail jam's! Thats all I have found in the day I have had it. *a |
11-29-2006, 01:01 PM | #99 |
Well, my gas gauge has decided to work well again, though sometimes it slips up. I'm pretty sure the float in the tank was just getting stuck.. New problem: I turned on my headlights this AM and the gauge cluster did not light up. I gave it a couple of taps and it came on. A few minutes later, I went to get gas and when I turned my lights on that time, the cluster didn't light up again, even after some tapping. It came on after I got on the freeway though. I'm thinking I might have to just pull the cluster and check the connectors behind it. 15+ years and daily driving on coilovers probably knocked something loose. Also, I was looking under the hood and in the corner behind the driver side headlight I found what looked like 50 wires all connected to a bolt. Is this what people are referring to when they say Nissan tends to ground too many connections together? Does anyone have any advice on cleaning this area up? Thanks,
Charlie |
11-29-2006, 01:11 PM | #100 |
well recently on my hatch, which is awaiting an new reubuilt engine by dec,
the freakin head lamp (s13) s both of them will only go down via motor but not up, the motor is fine the arms are fine, the relays have all been replaced wtih new ones, the fuses are fine, the wiring looks to be ain great shatpe, i guess its time for a conversion of some sort.
Like Me on FaceBook ! |
12-02-2006, 01:42 PM | #101 |
so i installed some indiglo gauges. lol. i had them and they burnt out like 8 years ago, and i never had the balls to install them myself cuz it was a real pain. so it rained on night really hard and i left both windows cracked. long story short guttted the whole car. too dash off seats out no carpet. just a one seater now. well turbo times stopped working. not sure but a fuse kept blowing, chime and clock would notwork. anf when it did, i would open the door and they would stop working. a/c lights don't work anymore. thats about it. but ppl say that the greddy turbo timer craps out. not sure if thats what this one did. i'll poke around again later on.
12-02-2006, 03:17 PM | #103 | |
well elec problem i had..fixed =D. had to remove old alarm system(pre owner) that was eating all the power to start my car. brake fuse problem..random wire hangin down in teh trunk.
woot.
12-02-2006, 03:56 PM | #104 | |
12-03-2006, 02:12 AM | #106 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
IF ANYONE CAN HELP.
That's the only reason I'm posting in this thread. My car's climate control venting system doesn't work. The fan's work, and the heat works, but the VENT DUCTS are stuck on FACE and FOOT vent. I can't get my windshield defrost to work, it's really shitty on these cold days. The LEDs above the buttons don't light up, my AC button doesn't work either. I dunno if that can help anyone that knows how to diagnose and/or fix my problem, if you know what to do, please PM me. I don't wanna take my dash apart if I don't have to.
12-03-2006, 02:48 AM | #107 |
There is a back lit issue on my tac. the ones that turn on around the tac are fine but the back lits down kick in. I also have issues with the pivot control modulator.
My last coupe had a wierd grimlen... I'd always take the back roads at night and max out on this one straight away. at around 100mph I'd see all the dash lights/accessories flicker. The car would then start pulling harder then before. x_X really wierd shit.
@schassis.eddi |
12-03-2006, 09:18 AM | #109 |
My HVAC lights decide when they are on/off and also, sometimes my temp gauge trips out if i bring the motor up around 6k.
613DriftWerks.ca |
12-03-2006, 03:37 PM | #110 | |
12-03-2006, 04:50 PM | #111 |
im guessing his battery is in th etrunk ^^^ run some more groun wiring to more places - it stopped my problem just like that
My gremlin - my Wipers no longer work since i got the car back from paint - and im not letting them touch my car again - im guessing somewhere from the wiper amplifier to the rest of th estuff theres a problem... because i am pretty sure i checked continuity between the switch and the wiper amplifier |
12-04-2006, 01:47 AM | #113 |
When its really cold outside like 20 degrees my light on in the gauge cluster for the door flickers.
My temp gauge works when it wants and so does my trip and odometer. If I put my map light to the postition where you open the door and it comes on, it will turn itself on taking corners fast. My open door chime is always on when the door is open even without the key in the ignition. Once in a great while when I push the clutch in the eheck engine light will turn on in between shifts. Im just gonna leave it till I get the SR swap done |
05-01-2007, 02:00 PM | #114 |
sometimes when i turn on my wipers to the first click, the tach stops working. off/2/3rd it works just fine
1998 SE |
05-01-2007, 02:39 PM | #116 |
my pasenger side head light when the high beams are applied doesnt come on well it does every once in a while and when i flash the high beams when pulling back on the head light knob every thing is fine. can someone pm me if they know how to fix this.
05-01-2007, 06:30 PM | #118 |
I got a good one, when I open the passenger door, my gas light comes on... WTF??
I need a new cluster. Car has a JDM cluster and the gas gauge is broke and some of the cluster lights stay dimly lit even with the car completely off. |
05-01-2007, 10:52 PM | #119 |
E-Brake Light Flashes
Oil Light Flashes Headlights Occasionally work Wierd one: Air Cuts off 10-12 seconds after the ignition is turned off. Never had that happen in the 5 S13's I have owned. |
05-01-2007, 11:17 PM | #120 |
if i make a right turn with my headlights on the wipers go on by themselves. the only way to stop it is to put the wiper controller arm down one "click" to the intermitent position. now i no longer have intermittent wipers.
TEAM SUS*PECT |
