Old 08-21-2020, 10:21 AM   #1
asianleful
asianleful is an unknown quantity at this point
2001 Lexus IS300 NA-T (6266, R154, AEM V2, 500WHP)
https://imgur.com/a/NWJt6Fw
Just gonna put a few photos on here and then link the group below, they're really big! Asking 17k obo, very happy to negotiate but no lowballing.
Has cold AC, heat, PS
2001 IS300 GGP Clean Title
200k chassis
70k on build
Engine:
GTE pistons and rods
ACL rod bearings
ACL journal bearings
Arp head studs
Arp rod bolts
GTE MLS head gasket
New valve seals
New valve cover seals
New front, rear, cam seals
New timing belt
New serpentine belt
New water pump and thermostat
New bkr7e spark plugs
New NGK spark wires
New valve cover gasket
New exhaust manifold gaskets
Precision Injectors
Haltech F10X ecu
New precision 6266 powder coated compressor housing
Cerakoted SRT turbo manifold
Cerakoted HKS wastegate
Cerakoted turbine housing
Cerakoted dump tube
New silicone vacuum hoses
Oil filter relocation kit
SRT intercooler
GM IAT sensor
GM coolant temp sensor
AEM 3.5 bar map sensor
Aeromotive fpr
Aeromotive stealth 340 e85 ready
AEM V2 6050
DEZOD pnp harness
Tuned by Trilogy Performance
Transmission:
MK3 R154
Suprasport V3 short shifter
Southbend 600 ft lbs torque clutch
Fresh motul tranny fluid
New output shaft seal
New release bearing
New AISIN slave cylinder
New AISIN master cylinder
New Driftmotion flywheel
New Driftmotion flywheel locking plate
ARP flywheel bolts
OEM pressure plate bolts
Interior:
AEM UEGO wideband
AEM TruBoost gauge and controller
AEM oil pressure gauge
New pioneer Double Din
New JBL component speakers all around
New Rockford fosgate powered sub
2IS steering wheel with working paddles and radio buttons
No seat tears
LED cluster lights
LED climate control lights
Suspension:
Tein street master flex z with electronic damper control
New lower ball joints
New SPL camber bolts
Front upper control arm camber ball joints
New inner and outer tie rods
Megan racing front brace
New gs300 rear upper control arm
New Xcessive diff bushings
New Megan subframe collars
Misc:
Michelin AS3 245/40/18 with only 8k miles
Vibrant ultra quiet resonator
3" downpipe, 4" axleback
New pads and rotors all around
New rear wheel bearings
M98 LSD
Xcessive clutch pedal
Front and rear dash cams
Tow hitch receiver
asianleful is offline   Reply With Quote
Old 08-21-2020, 04:35 PM   #2
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
location and price?
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 08-22-2020, 08:36 AM   #3
asianleful
Originally Posted by s13silvia123 View Post
location and price?
Tampa area 18k OBO very happy to negotiate with a serious buyer non lowballer.
Old 10-10-2020, 01:19 PM   #4
asianleful
https://www.youtube.com/watch?v=Tntf...nel=Asianleful
Bump!
Old 11-14-2020, 02:51 PM   #5
asianleful
Bump, 17k obo
Old 06-02-2021, 01:55 PM   #6
Kirbyz
Kirbyz is an unknown quantity at this point
14k? Cash money
Kirbyz is offline   Reply With Quote
