05-27-2008, 05:34 PM | #1 |
SR20DET with air condition ?????
ok so i need some things figure out here
i have an sr20det i want ac , i know about the whole thing about the lines and cutting and re welding , well i dont have the sr pieces that fit in the compressor. soo the questions i need answer is this .. ive ben told that the KA hoses fit the SR but they hose hits a pipe so u cant bolt it up ,, is that true? ive also ben told people use a nissan pathfinder pully on one of the compressors , wether it was a SR or KA compressor im not sure ?? ive ben told that the KA compressor bolts up to the SR but only has like 3 screws that will fit .is that true? then there is these (the first ansd second are the same person but different sites ) http://www.zilvia.net/f/showthread.php?t=153792 http://forums.nicoclub.com/zerothread?id=298648 http://www.geocities.com/acbrackets/ http://www.onetongarage.com/ except everyone making brackets dont sell them or there not made yet soo.. does any one know of other options? or know any one with a cnc machine that can make the bracket? |
05-27-2008, 06:05 PM | #4 |
05-27-2008, 06:07 PM | #5 |
05-27-2008, 06:25 PM | #6 |
Hey buddy I am in the same struggle, I have a redtop in an s14 and want AC. Here is what i did, The s13 redtop bracket bolts up, the s14 ka compressor bolts up with 2 bolts but its 1 1/2 inches away from the belt so I am going to find the pathfinder pulley this weekend and hopefully it works out.
05-27-2008, 06:29 PM | #7 |
Zilvia.net GB Vendor
Trader Rating: (65)
Feedback Score: 65 reviews
i used sr pump and bracket..its best if you can get this
i had jdm suction line i had usdm sohc r12 suction line used conversion oil and charged it with 134a at work..ice cold... i went to a shop that makes ac lines and they cut off the jdm line end with the oil accumulator on it...(tank looking thing) on it cut off the male threaded end on the usdm sohc line bc the line u make needs to mate up with the chassi hardline that runs from the passenger side. then in btw was a rubber crimped line with a r134 low pressure side fitting..make sure you tell the guy low pressure its small than the high pressure line.oh i also used orange high temp fire shielding so the line does not get sinzed....any ? just pm me..Jim |
05-27-2008, 06:37 PM | #8 | |
i can get all KA parts or some sr parts but not sure about the AC line and prolly can get the pathfinder pulley but dont know anything about it and i can do what you did cuz mine is a 89 buut i dont have the JDM side and if im not mistaken the KA low pressure side bolts straight up but its the top part (high pressure) that need the jdm side because of that fitting |
05-27-2008, 06:38 PM | #9 | |
hmm i wonder if i can do that . cept my car was a 89 , might try that |
05-27-2008, 06:56 PM | #10 |
the guy I know has a flair wrench and press and can make custom lines with custom fittings and as long as the thread is standard metric which they all are. I can send you some pics once they are fabed. And no I would not use a different pulley or bracket that could vibrate free and/ or break....
05-27-2008, 07:02 PM | #11 |
look up the user 'codyace' i belive he sells a bracket or kit for having AC on the SR20det. if anything i'm sure he can point you in the right direction
05-28-2008, 05:46 AM | #12 | |
if u read my first post you will see im on both of his threads asking him about them ,,, there not made yet ,,, so still tryna figure out what to do , |
