08-09-2012, 10:31 PM | #1 |
another KA24 wont start
i have an s14 with a KA24 its my daily always started right up but today leaving work i went to crank it over and it wouldnt so i had to push start it .. drove it home check all the fuses they seemed good.... your can hear the fuel pump priming... you hear the igniton click ... when you turn the key over the lights dim as if it were to crank over but it doesnt.... tried jump starting the battery didnt work... as of now im thinking my starter is either bad or stuck... any suggestions would be helpful.... Thanks in advance.
08-10-2012, 04:19 PM | #3 |
Got out there banged on the old starter and it cranked over ..... So I went out to autozone got a new starter.... Put it on and still won't even turn over all grounds are good .... Anymore ideas? Need some help
08-11-2012, 10:33 AM | #6 | |
Sure connections are tight secure.. Have you try pushing the car.. |
08-13-2012, 09:50 AM | #13 |
Ok here's todays update .... Took the alternator and battery to get tested both passed.... Checked all my wiring to the alt and starter all my grounds are good... Made sure of that.... All my battery grounds are good... Result the car is starting whenever it wants... Such as only turns over after I've tried a couple times sometime it turns on, on the third time sometimes it turns on, on the 20th try... Next step is exchange the starter ... If that doesn't help I'll go through and check my harness see if any cable is chopped or hacked....and also my positive battery terminal.. Thanks
08-13-2012, 08:31 PM | #17 |
When i got my s13 somebody had put new ends on the battery cables. Needles to say they werent crimped securely and i wasnt getting full power unless there were wiggled slightly. i started having a freind turn over my car and i wiggled the ground and power cables, if i pulled on them just right, it would start. i redid the connections and checked the wires to the relays and now have not had a problem since.
08-14-2012, 01:00 AM | #19 |
Now that you know the battery and starter are good. Check the battery terminals itself. Is it clean or dirty? If it is dirty then clean it, a dirty terminal can prevent the starter from getting full power to start and the ecu and everything else on the dash. Are the indicator lights seem dim when you turn the key to the "on" position compared to before.
Does the terminal fit tight and snug, a loosely fitting terminal is not good also, and like someone mention above the cable connection to the terminal should be tight also.
1995 240sx SE 5spd Red/Black 1993 240sx 5spd Coupe Red (SOLD) |
08-14-2012, 03:33 AM | #20 |
I truly hope this is your problem, I know how much of a pita it can be. Look everything over closely and with electrical, if you look at it and say "ehh that should be good enough" chances are its not! Good luck
08-14-2012, 03:56 AM | #21 | |
Just for fun try swapping parts out with another car that works. If you know anyone with the same car as you. Also, the engine, you do have the same engine that came with the car correct?
KA-T ORG-Function over Flush |
08-15-2012, 01:41 PM | #23 | |
08-16-2012, 04:00 AM | #25 |
I also had a s14 ka swapped in, I'm telling you I'm almost sure it's just old worn out electrical issues! Lol I'd look realy close at your connections at every point.ine looked fine untill I realy tore stuff apart and redid stuff. Corrosion in the right place can pull down your voltage/amperage and if your not getting full power your starter is just going to click. It could even be corrosion on the starter relay itself or your ignition wires. Start at the battery and work your way back triple check everything
08-17-2012, 07:59 PM | #26 |
Doesn't ANYONE ever bother to check the "START" position on their ignition switch??? If the contact inside the switch goes bad, then NO current will run from the battery to the starter...Mechanics 101...see attached link...
http://www.ramva.org/dragenwagen/pic...20circuit3.jpg Anyhow, to get an idea as to what to test, (and replace in case it's gone bad), click on the attached link to see what the ignition switch module looks like. 95 1995 Nissan 240SX Ignition Switch - Steering - Beck Arnley, OES Genuine, Standard Motor Products - PartsGeek Hope this helps... ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... |
