Old 09-10-2020, 12:04 PM   #1
JonThompson
JonThompson is an unknown quantity at this point
KA Ka24det timing problems
Okay so I’m resorting to the forums. Recently I replaced the head gasket on my s13 with a ka-t. I threw the thing back together and didn’t really pay the timing any mind. Soon after I realized that was a big mistake. I then took the whole timing assembly apart and put it back together matching the lower and upper chain with the correct dots on the corresponding links. I also made sure I was at true TDC when doing all this. I tried putting the distributor in multiple positions including the position I‘ve read it should be in (the dot on the gear lines up with the notch on the shaft of the distributor). I have brain crower stage 2 265 cams with adjustable gears but I just put the gears at the stock position. The car turns over but won’t fire or run at all. It’s getting fuel and spark, and after checking the #1 plug after attempting to start there is fuel on the plug. The exhaust also smells like good ole 93. Any help at all would be awesome.
JonThompson is offline   Reply With Quote
Old 09-10-2020, 07:21 PM   #2
NukeKS14
NukeKS14's Avatar
NukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really niceNukeKS14 is just really nice
Disregard. Where is your distributor clocked to? What color/how strong is the spark?
NukeKS14 is offline   Reply With Quote
Old 09-10-2020, 07:35 PM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
check your compression? leakdown?
zombiewolf513 is offline   Reply With Quote
Old 09-10-2020, 09:11 PM   #4
JonThompson
Spark is White and the spark doesn’t seem weak at all. The distributor as of right now is clocked at TDC.
Old 09-10-2020, 09:13 PM   #5
JonThompson
Originally Posted by JonThompson View Post
Spark is White and the spark doesn?t seem weak at all.
Compression should be fine. Before I replaced the head gasket it had 130-140 across all 4. Could it be that I need to mess with my cam timing?
Old 09-10-2020, 09:57 PM   #6
Krazy719
Krazy719 is an unknown quantity at this point
That?s real odd I would try & spray your intake manifold with some started fluid just to role out injectors hope it helps
Krazy719 is offline   Reply With Quote
Old 09-10-2020, 10:19 PM   #7
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
No. When you screwed up your timing chains you did mess with cam timing, and could have crushed your valves.
Why did you replace the head gasket?
mechanicalmoron is offline   Reply With Quote
Old 09-11-2020, 12:40 PM   #8
JonThompson
White smoke and water out of the exhaust.
Old 09-11-2020, 12:46 PM   #9
zombiewolf513
Compression (and leakdown) should be fine.
Ah, the good old assumption test eh?
Old 09-11-2020, 02:39 PM   #10
JonThompson
You got that right. Lol. I really have no clue what it could be though. I?m stumped.
Old 09-11-2020, 05:17 PM   #11
S14rebuild
Whats ur compression now?
Old 09-12-2020, 09:22 AM   #12
JonThompson
130 across all 4
Old 09-12-2020, 01:10 PM   #13
mechanicalmoron
So you changed the head gasket, and your compression is a bit lower?
You know exhaust always makes water? And that your car's smoking because of blowby and the accompanying clogged crappy PCV system?
Old 09-12-2020, 01:24 PM   #14
S14rebuild
130 across all 4
Thats way too low.... please double check your timing
