Old 03-29-2020, 03:41 PM   #1
240boosted
240boosted has a little shameless behavior in the past
Rods/pistons for Sr20det
Hey guys I?ve been looking through a few threads and trying to compare the difference between eagle rods and BC rods. I see that eagle rods can safely hold up to 700 hp and then I CBC rods that can safely go up to 350 which are a lot more money. The motor has a built head by mazwork and a gtx2871 turbo with 1050 cc injectors
https://www.240sxmotoring.com/brian-...s-for-sr20det/
Which are 729
Then there is
Which Are a lot cheaper and I am just wondering are the ones that are cheaper made for race applications and don?t last as long. finally the last thing with pistons do you guys like the CP pistons and I dont mind spending Extra money if needed
240boosted is offline   Reply With Quote
Old 03-30-2020, 07:52 AM   #2
jedi03
i would go with CP...and if you are looking cheaper on the rods i would do manley
Old 03-30-2020, 05:47 PM   #3
240boosted
Not looking for cheap price not really a issue rather spend money once better parts just wonder what everyone think.
Thanks for the help
Old 04-02-2020, 02:11 PM   #4
Kingtal0n
Kingtal0n's Avatar
The $400 rod says it handles 200hp/cylinder
thats around 800hp
A stock rod can handle 450hp~ it is generally accepted up to 500whp in some cases.
Biggest issue with aftermarket rods is... the details. The machining. Matching. Balancing act. Installation procedure.
It isn't impossible but. If you are not doing it yourself... prepare to check every little thing the machine shop does and find a brillion brallion mishtakshes
Old 04-02-2020, 05:36 PM   #5
240boosted
thank you for your input talked with people at real street going manley h beam and cp pistons
