Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
05-17-2010, 11:45 PM | #241 |
Off topic a little: You said your building a s14? Have you always drifted a s13 and your now switching to a s14, or have you gone kinda back and forth? I have found that the s14 almost drifts itself...just clutch kick, gas, and go, lol. ALMOST. Definately a different driving experience than the s13.
05-18-2010, 01:27 AM | #242 | |
Yup yup! My friend is wanting to do actually for me. We actually got 3 cameras to setup. One for the inside, another being shot from a outside and we dunno where the 3rd should go.
05-18-2010, 01:47 AM | #243 | |
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << |
05-25-2010, 10:31 PM | #244 |
Anyone tried the Yamato garage suspension parts?
06-29-2010, 11:02 PM | #245 | |
Thread kind of died off, was wondering if anyone else had input?
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
06-29-2010, 11:39 PM | #246 |
put the 3rd one on top of the car or somewhere that you can see both wheels of one side, so you can see when it starts sliding and when u counter steer
07-01-2010, 12:23 PM | #250 |
i saw this on a video, i personally havent tried it.
Ur in 3rd gear about to enter the turn, u pull the ebrake going still straight, shift down to 2nd begin to turn and release the ebrake and after that pretty much throttle control and steering... |
07-01-2010, 03:43 PM | #251 | |
Before the introduction of transmission synchronizers (in the 1920s) and helical cut gears, double clutching was a technique required to prevent damage to an automobile's gear system. Due to the difficulty and most often unnecessary redundancy involved in learning the technique, coupled with the advent of synchronized gearing systems, it has largely fallen into disuse. However, drivers of large trucks often use the double clutching technique when unable to keep the transmission unloaded during shifting, as large vehicles are usually equipped with older, simpler and more durable unsynchronized gearboxes. The purpose of the double-clutch technique is to aid in matching the rotational speed of the input shaft being driven by the engine to the rotational speed of the gear you wish to select (directly connected to rotating wheels). When the speeds are matched, the gear will engage smoothly and no clutch is required. If the speeds are not matched, the dog teeth on the collar will "crash" or grate as they attempt to fit into the holes on the desired gear. A modern synchromesh gearbox accomplishes this synchronization more efficiently. However, when the engine speed is significantly different than the transmission speed, the desired gear can often not be engaged even in a fully synchronized gearbox. An example is trying to shift into a gear while travelling outside the gear's speed or directional range, such as accidentally into 1st from near the top of 2nd, or intentionally from reverse to a forward gear whilst still moving at speed. Double clutching, although time consuming, eases gear selection when an extended delay or variance exists between engine and transmission speeds. Although double clutching is a testing requirement when obtaining a commercial driver's license, many experienced truckers have learned when it is possible to shift gears without using the clutch. This is known as float gears or skip shift, which thus eliminates the clutch except for starting and stopping. Conversely, in order to shift down, engine RPM must be increased while the gearbox is in neutral and the clutch is either engaged or disengaged. This requires the driver to shift into neutral, apply throttle to bring the RPM up to a suitable speed, and finally shift into gear. This operation can be very difficult to master, as it requires the driver to gauge the speed of the vehicle and throttle accurately. Double clutching occurs if the clutch pedal is released while matching engine speeds in neutral and again engaged prior to shifting into the next gear. oh, and to answer your question...it should be never. |
07-01-2010, 03:46 PM | #253 | |
that is a pussy way of entering a drift.....aggressive would to clutch kick in 3rd, and down shift to 2nd. but then again...it does depend on the track and how much room you have. If you were entering a turn with a wall, and the turn was a 2nd gear drift, then you would do that. The whole shifting thing does nothing. He's basically slowing the car down using the e-brake to enter the corner at the appropriate speed. obviously this is my opinion since I haven't seen the video. Post the video, and it'll help more on what he is actually trying to do. |
07-01-2010, 09:20 PM | #254 |
Getting that touch of angle, that bit of slide, is the main point of most techniques.
I love using the kick to get the rear to pop out, but the ebrake is adjustment on the way in to keep the line right. If I feel the car going to shallow into the turn and I want to run an outside line... hold the ebrake and rev the shit out of the car to bring it up and re-accelerate into it worst case scenario... But if you do it right you don't need to slow down... |
07-02-2010, 12:09 AM | #255 |
Ive been working on my s14 still I didnt get it started due to $ issues but still in the works. have been in my s13 and this thread has done alot for me.
07-02-2010, 01:42 AM | #256 | |
Handy in the snow, wet, racing, or just wanna down shift without the engine braking and making you lean forwards a little. |
07-02-2010, 05:02 PM | #258 | |
The simple answer is, No.
Tanner Foust said it the best. Drifting is like a bunch of emergency stop packed into a few seconds. Or something along those lines. Is there really time to double clutch or to remember? No and there's no real use for it.
07-03-2010, 09:46 PM | #260 | |
07-05-2010, 03:29 PM | #261 |
^^^ same here I figured out that out when I wasnt realy even trying to.. when you have a good set up its kinda just happens if you down shift in almost any turn, its just really hard on the drivetrain when you are doing it at a much higher rpm.
I really dont like the term 'clutch kick' cause it reminds me of when I learned how to do my first burnout. I perfer clutch control lol.... I got a K sport hydraulic ebrake so im gona have get used to it so thats what Ill be practicing on. Any one here drift with a dogbox??? Im assuming you would only be using trany/eng braking or ebrake, but Ive always wanted one
07-07-2010, 04:08 PM | #262 |
dog box still has a clutch. you have to use it to shift down. so "clutch kicking" would also work.
and I kick my clutch...not control it when i initiate. and it's a violent kick. WHAAAAM! |
07-08-2010, 01:29 AM | #265 |
not sayin I dont clutch kick usually initally or if I have slowed down and need to get the wheels spining quick again.
07-08-2010, 02:37 PM | #266 |
since I'm on a KA24E, I will be attempting a 3rd gear entry using the e-brake + clutch kick to initiate. Last time (same track) I wasnt able to get enough speed to clutch kick in 3rd, and 90% of my runs looked like shit. (the other 10% noone was on the track, so I just used the oval to build up speed, and then attacked the first turn)
I want more power after seeing castro's videos though, I feel ashamed of my skills (or lack there of) lol |
07-08-2010, 03:29 PM | #267 |
heres one of the old proverbs... practice makes perfect.. lol na but yea you will need some power to hit the really big, long drifts, there are people that can but they have practiced or been doing it most of their life.
Keep it up man you will get there. Drew
07-09-2010, 02:55 PM | #269 |
yeah i'm still ka too, i'm a kick, and foot to the floor, all about steering control for me. I only lift to scrub speed and then back on the gas.
castro and I have been driving on a ka for over 2 years now....when you have two years of back to back months of drifting and instructing, I hope you can drift as well as us underpowered drivers. and yes, practice makes perfect, I could show you videos of me spinning out all day....now, the only time I spin is because i'm trying to get too much angle, or be too aggressive...but rarely happens. and trust me, there is always room for improvement. p.s. when I say practice makes perfect, castro was never able to clip walls until he learned where they were through bashing his car into haybales. I have also gone through 3 sets of body kits since I started....one time I hit a pilon competing for a 1-2 spot. there was this kit went back to stock then purchased the nismo kit (this was the big plastic barrier) but just like everyone...practice makes perfect little inspiration for you begginers.... nothing in life is easy, you have to fail...before you succeed. below is my ka spinning 18x9.5 heavy ass xxr wheels....so don't blame power...it's line, weight transfer, and balls to the wall for the underpowered guys....its actually takes more effort to drive a higher horsepower car (more finess) |
07-10-2010, 12:14 AM | #270 |
Me three.. its the easiest way to kick it and keep control
