08-26-2020, 10:25 PM | #1 |
Trader Rating: (31)
Feedback Score: 31 reviews
EGT tap on SR manifold
I've seen some FWD pics, but not RWD or the stock manifold. I was thinking #1, but I was looking for some input. Also my sensor has a bung it came with. The sensor stick out is 1 1/8" with the bung, or 1 1/2" without it if I tapped the Mani. Debating which I should do as I'm worried about cracking it.
Sent from my SM-N986U using Tapatalk |
08-26-2020, 11:27 PM | #2 |
Personally I think #4 or above, before the turbo if only using 1 EGT. My understanding of going with a proper EGT setup, 1 at each exhaust port. I only have a single EGT currently because of $$$ and I have mine in my downpipe. 1 because I already have a bung for it and if I do drill into my manifold I plan on all 6 having an EGT.
08-27-2020, 12:53 PM | #4 |
I use O2 sensor bung to hold the EGT sensor
This way it can be removed or relocated easily The exact temperature of EGT is not important for majority of applications; Instead, the DIFFERENCE in temperature is what counts. For example, SR20 @ 18psi of boost and 400rwhp with: 13* Timing = 1280*F 11* Timing = 1280*F 9* Timing = 1290*F 7* Timing = 1370*F 5* Timing = 1480*F Thus: Optimal timing is found for daily driver/ street cars at 9* btdc of timing because this is the minimum amount of timing which still results within ~5% of peak torque/power with reasonable EGT |
08-27-2020, 01:20 PM | #5 | |
He asked for location.....thats all |
