Old 03-29-2020, 02:35 AM   #1
kk101
kk101 is on the path to ruinkk101 is on the path to ruinkk101 is on the path to ruin
Sr20vet rwd conversion which pistons?
Hi guys I?m building. Rwd sr20vet using p12 head and p12 turbo cam with super tech shimless valves +1mm
I just found out the pistons we using are CP DET pistons so there is no valve relief
The motor is assembled and spun by hand no sound of hitting, but I?ve heard that I need to use sr20vet pistons.
Is this true ?
kk101 is offline   Reply With Quote
Old 03-29-2020, 09:01 AM   #2
RZRSHARP_240SX
RZRSHARP_240SX's Avatar
RZRSHARP_240SX is an unknown quantity at this point
I am currently running det stroker pistons on my vet. And I have no issues as long and your clearances are good you shouldn’t have a issue.
RZRSHARP_240SX is offline   Reply With Quote
Old 03-29-2020, 09:30 PM   #3
kk101
dumb question but does the lift change once the vvl is activated at higher rpm ?
Old 03-30-2020, 09:02 AM   #4
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Yes....hence the variable valve LIFT in the terminology.
You will have to clay your engine WITH the high lobe activated. It serves no purpose to turn the engine over on the low lobes as that tells you zilch on valve clearance......
Old 03-30-2020, 08:09 PM   #5
kk101
How?s this achieved ?
Old 03-31-2020, 07:41 PM   #6
jr_ss
Hook up an air source to the VVL oil feed line to lock the rockers while you turn the motor over
Old 04-02-2020, 04:55 PM   #7
kk101
re checked the clearance and it does hit when the vll is engaged.
is it safe to just fly cut the pistons for the valve relief or am i better of swapping with sr20ve pistons
Old 04-03-2020, 08:15 AM   #8
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
whats your budget? if you have to pay for a shop to disassemble the engine, and a machine shop to cut reliefs, it can get expensive.
if you can do your own disassembly and machine work, then its obv cheaper.
if you want to skip the cost of machining all together, just buy new pistons that are designed for this application.
Old 04-06-2020, 05:20 PM   #9
PRT73
PRT73 is an unknown quantity at this point
what did you use as the thickness of the head gasket?
PRT73 is offline   Reply With Quote
Old 04-14-2020, 07:40 PM   #10
Kaisen
Kaisen is an unknown quantity at this point
You can get the CP SR20VE pistons with the valve relief for a peace of mind
Kaisen is offline   Reply With Quote
