02-08-2008, 11:03 AM | #61 | ||
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
RIP, 'Oil burning POS'
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
02-08-2008, 11:09 AM | #63 |
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
LOL
Yeah, that's my ideal goal, is to do a ring for tails, and a center for brake, but I don't know that I'll ever get around to it. I'm also kinda scared to go prying/cutting on my set of kouki tails. LOL
02-08-2008, 11:23 AM | #65 | ||
Don't do it to Kouki lights until you've had enough time to take apart a few tails without breaking em... which is why I went with eBay altezzas. Of course, right now I'm trying to get a zenki centerpiece for the tail set so I can mod it with LEDs to illuminate with the brake lights. I can't get one in my price range though.
02-08-2008, 11:27 AM | #66 | |
02-08-2008, 11:43 AM | #68 | |
Took stock S13 hub, knocked out all studs except one Placed stock S14 rotor on top Put in drill press to drill out holes Used an end mill (school I went to had one, all you're doing is removing material) Once holes are drilled, knock in new studs, (you can tack weld each stud if you want) |
02-08-2008, 12:20 PM | #69 | ||
http://www.componentsuperstore.com/s...IGHTING8080368 They're not cheap, I'm warning you guys now. Red/Orange, like I've already said, is more intense than straight red, and when used behind a red lens, they look great.
02-08-2008, 09:10 PM | #70 | |
we did my s13 also. No problems thus far.
Robby Leuer |
02-16-2008, 10:54 PM | #72 |
I know somebody already did this, but i just wanted to show another example of what could be done for some cheap brake ducting, and it actually works!
02-16-2008, 11:25 PM | #73 | |
Trader Rating: (37)
Feedback Score: 37 reviews
Touke <3 Last edited by JDM671; 02-16-2008 at 11:36 PM.. Reason: noob question |
03-03-2008, 12:30 PM | #74 |
Hopefully you guys don't mind me bumping a slightly old thread, but I was talking about the same subject of drilling the hub to create a new pattern in mine.
For those who have done it in the past, why didn't you just thread in new studs into the holes? I am sure you could have used a tap to create threads. This way, it won't be too much of a permanent thing. Then also, if the stud breaks, then it would be somewhat easily replaceable. Also assuming that you are worried about it possibly sliding off of the threads, and want something more secure, why not just put a couple of tap welds on the back of it. This way, it will be secure, but you could always grind the tap welds down, and remove the stud? Just trying to throw ideas out there with you guys.
03-03-2008, 01:06 PM | #76 |
Maybe I am just used to converting over to studs in my other cars. Cause for example, a BMW uses wheel bolts and if you were to convert it over to a stud, all you would have to do is thread in the new studs into the existing threaded holes on the hub.
All that is used to secure them down is some red or blue loctite (don't remember which one at the moment they used). A lot of racers use this method on their cars, to change out wheels quicker, and have no problems with just threading in the studs. This also allows them to change it out every so often if needed, since they experience a lot more wear and tear than normal use.
04-24-2008, 07:59 AM | #81 |
AE92 body style gt-s cars, I just drilled some well placed holes. Seems to help somewhat with the butt G-meter.
04-24-2008, 10:40 AM | #82 |
04-24-2008, 11:00 AM | #83 | |
no, you need a GT-S AE92 Corolla Coupe... The SR5's wont have them (I got one for my girl's SR5 Coupe)
SupraMan!!/1986.5 Sports Package/1989 TURBO/1992 HT/2005 Scion xB |
04-24-2008, 11:29 AM | #84 |
this thread rocks my socks, +rep to you OP
Custom made brake lines for my Z brake swap: Removing the spoiler from the hatch ($#@$ rust!): The 4 to 5 lug conversion is pretty interesting...I might try that in the future if I can find access to a drill press! Also, I am just about to start my interior lights LED conversion, where did you guys buy you LED's?? Also, where can you buy/find information about what resistors you will need?? Thanks! |
04-24-2008, 07:20 PM | #86 |
we took a coat hanger and bent it into the desired shape needed to clear everything
then we took a stainless steel brake line and shaped it (gently) into the same shape as the coat hanger. Make sure you do not disfigure the cross section of the brake line. another picture might help: |
07-27-2008, 01:23 AM | #89 |
Trader Rating: (40)
Feedback Score: 40 reviews
I just did this one: 240z fuel splash guard retrofit
Kinda-sorta-useful for the few who care about trying not to spill fuel onto their paint @ the gas station: Total project time: about 3-5 minutes Equipment required: - Scissors - Rubber material or a 240z fuel splash guard (or whatever it is really called) Step 1: - Trim the splash guard Step 2: - Fit the piece - if you trimmed too much like I did (or just got a rectangular piece), you can wedge it between the fuel sender grommet & the chassis. It actually works, too! Normally I don't spill any fuel. However, yesterday, I went to fuel up & 2-3 drops escaped the fuel sender & landed onto the splash guard instead of my nice paint, YAY!
bew bews! |
